Latest post Sun, Jan 11 2015 6:42 PM by AndrewAction. 2 replies.
  • Sun, Jan 11 2015 12:56 PM
    sRGB jpg -> rec709 mxf DNxHD 120
    Hi all,
    Beginners question.
    I have jpg sequences in sRGB colorspace that I want to convert to rec709 mfx files (DNxHD 120).
    I decided MetaFuze was the way to go. It converts a jpg sequence to mxf in a few seconds. However, I'm not sure the colorspaces are correct after the conversion. The "edit lut" button is disabled since I'm using jpgs instead of dpx/tiff.
    What is the way to go? Does metafuze asume jpg to be sRGB by default (so there is no problem at all) or are there any settings that I have to change?
    Or is it possible to tackle this problem later and interpet the footage as sRGB in Avid MediaComposer (the rest of the project is in rec709).
    thanks!
  • Sun, Jan 11 2015 6:23 PM In reply to
    Re: sRGB jpg -> rec709 mxf DNxHD 120
    You can import a JPG sequence into MC justa s easily and there you have access to color levels etc.
    I'd expect metafuse to treat jpgs as full range levels (0-255)
  • Sun, Jan 11 2015 6:42 PM In reply to
    If your jpg files are sequentially numbered you can import them directly into MC.
    File\mport  In the Options\Image choose RGB and check the Sequential Files option.
