Latest post Thu, Sep 10 2015 7:03 AM by Mondo. 29 replies.
Page 1 of 2 (30 items) 1 2 Next >
  • Thu, Jan 29 2015 4:56 PM
    HP z420 MC 8.3 newblue v1 results in titler.dll not found error???
    Hi Guru's
    I've pinged MM on this one and she contacted newblue but maybe someone out here can help as well.
    On 3 brand new HP z420 Windows 7 64 prof systems with MC 8.3.0 I downloaded newblue titler v1 through the application manager and installed it all under the administrator account. Systems are not a member of a domain. On all 3 systems as soon as I drag the newblue titler effect to a timeline I get a titler.dll not found error. The dll is present though.
    I also tested on a HP Z400 with a fresh install of the windows 7 64 prof (HP dvd's) and on that machine the newblue titler v1 works normal.
    What could be causing this on the HP 420 machines? Could it be the dll's are not being registered correctly?
    Thanks for any help.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Fri, Feb 20 2015 2:50 AM In reply to
    Re: HP z420 MC 8.3 newblue v1 results in titler.dll not found error???
    Hi Jeroen,
    Sorry for the late response, I just saw your post tonight. Are you still having the ".dll not found" error on those systems?
  • Fri, Feb 20 2015 6:41 AM In reply to
    Hi Marcus,
    Yes. Mm contacted newblue but did not get any response with a solution so we still have the issue.
    Jeroen van Eekeres
  • Fri, Feb 20 2015 9:38 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 917
    • Points 11,740
    Jeroen van Eekeres:
    Just a guess: It may be, that the dll is not registered correctly. Try the following:
    From Windows Start Button, run cmd.com in administrative mode. Change the directory to the one where your .dll is located. Type regsvr32 /i titler.dll
    Good luck,
    Joachim
    Joachim Claus
  • Mon, Feb 23 2015 3:44 AM In reply to
    Hi Jeroen,
    Can you please try the following for me, on one of the computers where Titler isn't working correctly:
    - Run the titler 1 installer again
    - When the installation is finished, before clicking Close, right-click and select "copy details to clipboard"
    - Paste the results in a mesage here, or a text file
    With any luck that will give us some idea of what's going on.
  • Tue, Feb 24 2015 9:46 AM In reply to
    Hi Marcus,
    Here's the result.
    Output folder: C:\Program Files (x86)\NewBlue\Titler Pro for Windows
    Delete file: C:\Program Files (x86)\NewBlue\Titler Pro for Windows\ManagerGL.dll
    Delete file: C:\Program Files (x86)\NewBlue\Titler Pro for Windows\NBCustomUI.dll
    Delete file: C:\Program Files (x86)\NewBlue\Titler Pro for Windows\Resources.dll
    Delete file: C:\Program Files (x86)\NewBlue\Titler Pro for Windows\StarterPackOpenGL.dll
    Extract: ManagerGL.dll... 100%
    Extract: StarterPackOpenGL.dll... 100%
    Extract: Resources.dll... 100%
    Extract: NBCustomUI.dll... 100%
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\FrameProcessing.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\ManagerGL.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\OgreMain.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\QtCoreNewBlue4.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\QtGuiNewBlue4.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\quazip.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\RenderSystem_GL.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\Resources64.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\StarterPackOpenGL64.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\Titler.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\UIHost.dll
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\XMLParser.dll
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows
    Created uninstaller: C:\Program Files\NewBlue\Titler Pro for Windows\Uninstall.exe
    Extract: COPYING... 100%
    Extract: FTL.TXT... 100%
    Extract: FrameProcessing.dll... 100%
    Extract: LICENSE... 100%
    Extract: OgreMain.dll... 100%
    Extract: QtCoreNewBlue4.dll... 100%
    Extract: QtGuiNewBlue4.dll... 100%
    Extract: RenderSystem_GL.dll... 100%
    Extract: ReportUtility.exe... 100%
    Extract: Resources64.dll... 100%
    Extract: StarterPackOpenGL64.dll... 100%
    Extract: Titler.dll... 100%
    Extract: XMLParser.dll... 100%
    Extract: ma32cmd.exe... 100%
    Extract: quazip.dll... 100%
    Extract: turnOffLogs.reg... 100%
    Extract: turnOnLogs.reg... 100%
    Extract: vcredist_x64.exe... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\imageformats
    Extract: qgif4.dll... 100%
    Extract: qjpeg4.dll... 100%
    Extract: qtiff4.dll... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources
    Extract: main.css... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Animations
    Extract: Arrange.transition... 100%
    Extract: Bend.animation... 100%
    Extract: Bounce.transition... 100%
    Extract: Bow.animation... 100%
    Extract: Bulge.animation... 100%
    Extract: CityLights.transition... 100%
    Extract: ComeFromBehind.transition... 100%
    Extract: ComeFromInfinity.transition... 100%
    Extract: Distort.animation... 100%
    Extract: DropSplit.transition... 100%
    Extract: DroppingWords.transition... 100%
    Extract: FadeIn.transition... 100%
    Extract: Falling.transition... 100%
    Extract: Fish.animation... 100%
    Extract: Flag.animation... 100%
    Extract: Float.animation... 100%
    Extract: FloatAndPop.transition... 100%
    Extract: FlyIn.transition... 100%
    Extract: MorphTest.animation... 100%
    Extract: OverlapZoom.transition... 100%
    Extract: Pan.animation... 100%
    Extract: Perspective.animation... 100%
    Extract: Popup.transition... 100%
    Extract: Rise.animation... 100%
    Extract: RollAndCrawl.animation... 100%
    Extract: Shear.animation... 100%
    Extract: ShufflingLetters.transition... 100%
    Extract: SpinBack.transition... 100%
    Extract: StarCrawl.animation... 100%
    Extract: Turn.animation... 100%
    Extract: TurnToFaceForward.transition... 100%
    Extract: TypeOn.transition... 100%
    Extract: Warp1.animation... 100%
    Extract: Warp2.animation... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Animations
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Animations\Float
    Extract: Fall Back.nbeffect... 100%
    Extract: Fast Backward.nbeffect... 100%
    Extract: Fast Forward.nbeffect... 100%
    Extract: Letter Jump.nbeffect... 100%
    Extract: Reset to None.nbeffect... 100%
    Extract: Slow Backward.nbeffect... 100%
    Extract: Slow Forward.nbeffect... 100%
    Extract: Word Jump.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Animations\Pan
    Extract: Falling words.nbeffect... 100%
    Extract: Falling.nbeffect... 100%
    Extract: Fast side.nbeffect... 100%
    Extract: Rising.nbeffect... 100%
    Extract: Slinky.nbeffect... 100%
    Extract: Slow diagonal.nbeffect... 100%
    Extract: Slow side.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Animations\Roll & Crawl
    Extract: Crawl-backward.nbeffect... 100%
    Extract: Crawl-fast.nbeffect... 100%
    Extract: Crawl-medium.nbeffect... 100%
    Extract: Crawl-slow.nbeffect... 100%
    Extract: Roll-down.nbeffect... 100%
    Extract: Roll-fast.nbeffect... 100%
    Extract: Roll-medium.nbeffect... 100%
    Extract: Roll-sitcom speed.nbeffect... 100%
    Extract: Roll-slow.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Animations\Star Crawl
    Extract: Deep Crawl.nbeffect... 100%
    Extract: Shallow Crawl.nbeffect... 100%
    Extract: Tilt Forward.nbeffect... 100%
    Extract: Under Crawl.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Animations\Turn
    Extract: 180 Degree.nbeffect... 100%
    Extract: Slow Turn.nbeffect... 100%
    Extract: Sweep Letters.nbeffect... 100%
    Extract: Sweep Words.nbeffect... 100%
    Extract: Sweep.nbeffect... 100%
    Extract: Turn Letters.nbeffect... 100%
    Extract: Turn Words.nbeffect... 100%
    Extract: Upturn Letters.nbeffect... 100%
    Extract: Upturn Words.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\City Lights
    Extract: Flicker.nbtran... 100%
    Extract: Pop Flashes.nbtran... 100%
    Extract: Power On Words.nbtran... 100%
    Extract: Power On.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Drop Split
    Extract: Blink.nbtran... 100%
    Extract: Drop In.nbtran... 100%
    Extract: Long Fade.nbtran... 100%
    Extract: Pull Apart.nbtran... 100%
    Extract: Scattered.nbtran... 100%
    Extract: Stretched.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Dropping Words
    Extract: Air Bed.nbtran... 100%
    Extract: Droplet Letters.nbtran... 100%
    Extract: Falling Wave.nbtran... 100%
    Extract: Hard Drop.nbtran... 100%
    Extract: Light as a Feather.nbtran... 100%
    Extract: Marionette.nbtran... 100%
    Extract: Soft Landing.nbtran... 100%
    Extract: Yo-Yo.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Fade In
    Extract: Fade Letters.nbtran... 100%
    Extract: Linear.nbtran... 100%
    Extract: Pop Letters.nbtran... 100%
    Extract: Slow Finish.nbtran... 100%
    Extract: Smooth.nbtran... 100%
    Extract: Word by Word.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Falling
    Extract: Bouncy.nbtran... 100%
    Extract: Dropped.nbtran... 100%
    Extract: Moderate Bounce.nbtran... 100%
    Extract: Spilled Letters.nbtran... 100%
    Extract: Trampoline.nbtran... 100%
    Extract: Tumbling.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Float And Pop
    Extract: Cannon.nbtran... 100%
    Extract: Float Down.nbtran... 100%
    Extract: Fly Back.nbtran... 100%
    Extract: Flying Letters.nbtran... 100%
    Extract: Shootout.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Fly In
    Extract: Falling Letters.nbtran... 100%
    Extract: Falling Words.nbtran... 100%
    Extract: Fast Left.nbtran... 100%
    Extract: Fast Right Words.nbtran... 100%
    Extract: Fast Right.nbtran... 100%
    Extract: Fountain.nbtran... 100%
    Extract: Letters Right.nbtran... 100%
    Extract: Peel Letters.nbtran... 100%
    Extract: Pop Words.nbtran... 100%
    Extract: Spray Letters.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Fly Past
    Extract: Drop Letters.nbtran... 100%
    Extract: Drop Words.nbtran... 100%
    Extract: Drop.nbtran... 100%
    Extract: Spin.nbtran... 100%
    Extract: Twist Words.nbtran... 100%
    Extract: Twist.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Infinity
    Extract: Centered.nbtran... 100%
    Extract: Leaping Letters.nbtran... 100%
    Extract: Letter by Letter.nbtran... 100%
    Extract: Swoop Down.nbtran... 100%
    Extract: Swoop Words.nbtran... 100%
    Extract: Vault Up.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Overlap Zoom
    Extract: Fall Back.nbtran... 100%
    Extract: Flashing Letters.nbtran... 100%
    Extract: Popping Letters.nbtran... 100%
    Extract: Scatter.nbtran... 100%
    Extract: Splat.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Popup
    Extract: Big Bounce.nbtran... 100%
    Extract: Bouncing Letters.nbtran... 100%
    Extract: Bouncing Words.nbtran... 100%
    Extract: Cascade.nbtran... 100%
    Extract: Growing Words.nbtran... 100%
    Extract: Spring Up.nbtran... 100%
    Extract: Strident.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Shuffling Letters
    Extract: Musical Chairs.nbtran... 100%
    Extract: Scrambled.nbtran... 100%
    Extract: Shuffle.nbtran... 100%
    Extract: Slide Into Place.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Spin Back
    Extract: Closing Door.nbtran... 100%
    Extract: Dominoes.nbtran... 100%
    Extract: Flip Over.nbtran... 100%
    Extract: Rotating Words.nbtran... 100%
    Extract: Swing Up.nbtran... 100%
    Extract: Timber!.nbtran... 100%
    Extract: Turning Letters.nbtran... 100%
    Extract: Twisty.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Turn
    Extract: About Face.nbtran... 100%
    Extract: Blinds.nbtran... 100%
    Extract: By Word.nbtran... 100%
    Extract: One by One.nbtran... 100%
    Extract: Stealth Letters.nbtran... 100%
    Extract: Twist by Letter.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Animations\Type On
    Extract: preset.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Icons
    Extract: Bold.png
    Extract: Italic.png
    Extract: LetterSpacing.png
    Extract: LineHeight.png
    Extract: Underline.png
    Extract: align-center.png
    Extract: align-justify.png... 100%
    Extract: align-left.png
    Extract: align-right.png
    Extract: back.png
    Extract: color-picker.png
    Extract: cross.png... 100%
    Extract: disclosure_closed.png... 100%
    Extract: disclosure_open.png... 100%
    Extract: eyeClosed.png
    Extract: eyeOpened.png
    Extract: fastforward.png
    Extract: folder.png
    Extract: globe.png... 100%
    Extract: help.png... 100%
    Extract: info.png... 100%
    Extract: lock.png
    Extract: logo.png... 100%
    Extract: next.png
    Extract: pause.png
    Extract: play.png
    Extract: rewind.png
    Extract: selBoxPoint.png
    Extract: selBoxRotate.png... 100%
    Extract: trash.png... 100%
    Extract: unlock.png
    Extract: zoom-in.png
    Extract: zoom-out.png
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Shaders
    Extract: FragmentAlphaBlender.frag... 100%
    Extract: VertexBiTexture.vert... 100%
    Extract: phong.frag... 100%
    Extract: phong.vert... 100%
    Extract: phongTextured.frag... 100%
    Extract: rotationSphere.frag... 100%
    Extract: rotationSphere.vert... 100%
    Extract: selectionBox.frag... 100%
    Extract: selectionBox.vert... 100%
    Extract: selectionObject.frag... 100%
    Extract: selectionObject.vert... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Textures
    Extract: 73610tt.jpg... 100%
    Extract: BG003.jpg... 100%
    Extract: BG004.jpg... 100%
    Extract: BRICK4.JPG... 100%
    Extract: BUMP05.JPG... 100%
    Extract: BWRAMP03.JPG... 100%
    Extract: Brick3.jpg... 100%
    Extract: Chiarsa Torley.jpg... 100%
    Extract: Cloud2.jpg... 100%
    Extract: Coat of Cuddles Torley.png
    Extract: Day they Attacked Torley.jpg... 100%
    Extract: Favorite Sound Torley.jpg... 100%
    Extract: Flair closer.png... 100%
    Extract: Flare_1.png... 100%
    Extract: Flare_2.png... 100%
    Extract: Flare_3.png... 100%
    Extract: Flare_4.png... 100%
    Extract: Greeting Card Torley.png... 100%
    Extract: LEAF4.JPG... 100%
    Extract: Luminon Torley.png
    Extract: MARBLE1.JPG... 100%
    Extract: MARBLE2.JPG... 100%
    Extract: MARBLE3.JPG... 100%
    Extract: MARBLE4.JPG... 100%
    Extract: Meta_Refl05.jpg... 100%
    Extract: Metal3.jpg... 100%
    Extract: NaturalT-029.bmp... 100%
    Extract: Paper009.jpg... 100%
    Extract: RE002B.JPG... 100%
    Extract: RE003.JPG... 100%
    Extract: Reflection013.jpg... 100%
    Extract: Reflection015.jpg... 100%
    Extract: SSBALL.JPG... 100%
    Extract: SSBALL2.JPG... 100%
    Extract: STAR.JPG... 100%
    Extract: STAR2.JPG... 100%
    Extract: Sandstone Torley.png
    Extract: Techno-Fetishism.png... 100%
    Extract: Together Stand One Torley.jpg... 100%
    Extract: Wood Torley.png
    Extract: Wood_Texture_Wallpaper_by_sebgonz.jpg... 100%
    Extract: bump048.jpg... 100%
    Extract: bumpf002.JPG... 100%
    Extract: chrome007.JPG... 100%
    Extract: concrete_01.jpg... 100%
    Extract: dirt.jpg
    Extract: dirty.jpg... 100%
    Extract: explosion.png... 100%
    Extract: flare1.jpg... 100%
    Extract: flare2.jpg... 100%
    Extract: flare3.jpg... 100%
    Extract: flare3.png
    Extract: flare4.jpg... 100%
    Extract: horizon_blue.png... 100%
    Extract: horizon_orange.png... 100%
    Extract: moon-bump.jpg... 100%
    Extract: old-stump-2-texture.jpg... 100%
    Extract: orange_drops_01.jpg... 100%
    Extract: pink_drops_01.jpg... 100%
    Extract: red_chenille_fabric_texture_by_beckas.jpg... 100%
    Extract: ref027.JPG... 100%
    Extract: smoke.png
    Extract: speaker-grille-texture.jpg... 100%
    Extract: steel_01.jpg... 100%
    Extract: steel_02.jpg... 100%
    Extract: titanium-texture.jpg... 100%
    Extract: water-texture-2.jpg... 100%
    Extract: wood.jpg... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Textures\_test
    Extract: !sphere.jpg... 100%
    Extract: EnvironmentMap.dds... 100%
    Extract: circle.png... 100%
    Extract: reference2.png... 100%
    Extract: rocky2-normal.jpg
    Extract: rocky2.jpg... 100%
    Extract: zebra.png... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Theme
    Extract: arrows-horizontal.png
    Extract: arrows-vertical.png
    Extract: checkmark.png... 100%
    Extract: panel-shadow.png
    Extract: scrollbar-horizontal.png
    Extract: scrollbar-vertical.png
    Extract: scrubber.png
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Shapes
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Shapes\Circles
    Extract: Blow out.nbshape... 100%
    Extract: Disc-portal.nbshape... 100%
    Extract: Disc-rings.nbshape... 100%
    Extract: Disc-silver.nbshape... 100%
    Extract: Dot-blue.nbshape... 100%
    Extract: Dot-orange.nbshape... 100%
    Extract: Dot-red.nbshape... 100%
    Extract: Dot-white.nbshape... 100%
    Extract: Flare.nbshape... 100%
    Extract: New Circle.nbshape... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Shapes\My Shapes
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Shapes\Rectangles
    Extract: Bar-blue fade.nbshape... 100%
    Extract: Bar-grey fade.nbshape... 100%
    Extract: Bar-red fade.nbshape... 100%
    Extract: Glint-blue.nbshape... 100%
    Extract: Glint-orange.nbshape... 100%
    Extract: Line-black.nbshape... 100%
    Extract: Line-blue fade.nbshape... 100%
    Extract: Line-grey fade.nbshape... 100%
    Extract: Line-red fade.nbshape... 100%
    Extract: Line-white.nbshape... 100%
    Extract: New Rectangle.nbshape... 100%
    Extract: Plate-chrome.nbshape... 100%
    Extract: Plate-grey heavy.nbshape... 100%
    Extract: Plate-grey light.nbshape... 100%
    Extract: Plate-grey.nbshape... 100%
    Extract: Plate-orange.nbshape... 100%
    Extract: Plate-red.nbshape... 100%
    Extract: Plate-silver.nbshape... 100%
    Extract: Plate-soft blue.nbshape... 100%
    Extract: Plate-soft red.nbshape... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Styles
    Extract: 3D Type.nbstyle... 100%
    Extract: A_Shadow.nbstyle... 100%
    Extract: An_Outline.nbstyle... 100%
    Extract: Baseball.nbstyle... 100%
    Extract: Basic Sans Serif Type.nbstyle... 100%
    Extract: Basic Serif Type.nbstyle... 100%
    Extract: Blue Bam.nbstyle... 100%
    Extract: Blue Chrome.nbstyle... 100%
    Extract: Broadway.nbstyle... 100%
    Extract: Bubblegum.nbstyle... 100%
    Extract: Caesar.nbstyle... 100%
    Extract: Chrome.nbstyle... 100%
    Extract: Diamond Plate.nbstyle... 100%
    Extract: Duck.nbstyle... 100%
    Extract: Elfin.nbstyle... 100%
    Extract: Farmville.nbstyle... 100%
    Extract: Firestone.nbstyle... 100%
    Extract: Gold Plate.nbstyle... 100%
    Extract: Heatvision.nbstyle... 100%
    Extract: Leaf.nbstyle... 100%
    Extract: Marshmallow.nbstyle... 100%
    Extract: Melon.nbstyle... 100%
    Extract: Metal.nbstyle... 100%
    Extract: Metallic.nbstyle... 100%
    Extract: Mezz.nbstyle... 100%
    Extract: Modern Wood.nbstyle... 100%
    Extract: Moon.nbstyle... 100%
    Extract: Neon Sign.nbstyle... 100%
    Extract: New Arrival.nbstyle... 100%
    Extract: No Icon.png
    Extract: Olde.nbstyle... 100%
    Extract: Pink Candy.nbstyle... 100%
    Extract: Puff Power.nbstyle... 100%
    Extract: Pumpkin.nbstyle... 100%
    Extract: Pyrate.nbstyle... 100%
    Extract: RWB.nbstyle... 100%
    Extract: Relic.nbstyle... 100%
    Extract: Reset to None.nbstyle... 100%
    Extract: School.nbstyle... 100%
    Extract: Silver Marquee.nbstyle... 100%
    Extract: Spider.nbstyle... 100%
    Extract: Steel Plate.nbstyle... 100%
    Extract: Sticker.nbstyle... 100%
    Extract: Sunrise.nbstyle... 100%
    Extract: Tavern.nbstyle... 100%
    Extract: Timeless.nbstyle... 100%
    Extract: Tool.nbstyle... 100%
    Extract: Toothpaste.nbstyle... 100%
    Extract: Violin.nbstyle... 100%
    Extract: Wedding.nbstyle... 100%
    Extract: Zoom.nbstyle... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Styles\My Styles
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Templates
    Extract: Baseball.nbtemplate... 100%
    Extract: Battle Jitters.nbtemplate... 100%
    Extract: Blue Plasma.nbtemplate... 100%
    Extract: Bold Type.nbtemplate... 100%
    Extract: Broadway.nbtemplate... 100%
    Extract: Bubbly.nbtemplate... 100%
    Extract: Bullet List.nbtemplate... 100%
    Extract: Circumvent.nbtemplate... 100%
    Extract: Epic.nbtemplate... 100%
    Extract: Fighting Words.nbtemplate... 100%
    Extract: Fly Past.nbtemplate... 100%
    Extract: FunFarm.nbtemplate... 100%
    Extract: Hero.nbtemplate... 100%
    Extract: Its a Boy.nbtemplate... 100%
    Extract: Its a Girl.nbtemplate... 100%
    Extract: Lantern.nbtemplate... 100%
    Extract: Metallic.nbtemplate... 100%
    Extract: ModernWood.nbtemplate... 100%
    Extract: Moving Metal.nbtemplate... 100%
    Extract: NeonSign.nbtemplate... 100%
    Extract: Old Times.nbtemplate... 100%
    Extract: Popcorn.nbtemplate... 100%
    Extract: Presenting.nbtemplate... 100%
    Extract: PubHouse.nbtemplate... 100%
    Extract: Pyrates.nbtemplate... 100%
    Extract: Running Large.nbtemplate... 100%
    Extract: Rush In.nbtemplate... 100%
    Extract: Scary.nbtemplate... 100%
    Extract: Searchlight.nbtemplate... 100%
    Extract: See Through.nbtemplate... 100%
    Extract: Shuffle.nbtemplate... 100%
    Extract: SilverMarquee.nbtemplate... 100%
    Extract: Spotlight.nbtemplate... 100%
    Extract: Sticker.nbtemplate... 100%
    Extract: Swoop In.nbtemplate... 100%
    Extract: Tavern.nbtemplate... 100%
    Extract: Type On.nbtemplate... 100%
    Extract: Underwater.nbtemplate... 100%
    Extract: Zoom In.nbtemplate... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Templates\My Templates
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack
    Extract: setup.sxml... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack\Colored Pencil
    Extract: Colored Lines.nbeffect... 100%
    Extract: Dark Colors.nbeffect... 100%
    Extract: Faded.nbeffect... 100%
    Extract: Night.nbeffect... 100%
    Extract: Pastels.nbeffect... 100%
    Extract: Pencil Fill.nbeffect... 100%
    Extract: Penciled Lines.nbeffect... 100%
    Extract: Rubbed Charcoal.nbeffect... 100%
    Extract: Silky Fog.nbeffect... 100%
    Extract: Strange Dream.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack\Dream Glow
    Extract: Aqua.nbeffect... 100%
    Extract: Black Light.nbeffect... 100%
    Extract: Darkroom.nbeffect... 100%
    Extract: Gray Dream.nbeffect... 100%
    Extract: Lemon Jello.nbeffect... 100%
    Extract: Night Vision.nbeffect... 100%
    Extract: Poltergeist.nbeffect... 100%
    Extract: Soft Glow.nbeffect... 100%
    Extract: Strong Glow.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack\Film Camera
    Extract: Camera, Hand Cranked.nbeffect... 100%
    Extract: Earthquake!.nbeffect... 100%
    Extract: Electrical Storm.nbeffect... 100%
    Extract: Fire Light.nbeffect... 100%
    Extract: Newsreel from the War Front.nbeffect... 100%
    Extract: Reset To None.nbeffect... 100%
    Extract: Slight Camera Shake.nbeffect... 100%
    Extract: Train Ride.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack\Lens Correction
    Extract: Big Bulge.nbeffect... 100%
    Extract: Fun House.nbeffect... 100%
    Extract: Inner Twist.nbeffect... 100%
    Extract: Intoxicated.nbeffect... 100%
    Extract: Jumbotronic.nbeffect... 100%
    Extract: Patternic Planet.nbeffect... 100%
    Extract: Phantasm.nbeffect... 100%
    Extract: Reduce Fisheye.nbeffect... 100%
    Extract: TV In Space.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack\Reflection
    Extract: Angled Left.nbeffect... 100%
    Extract: Angled Right.nbeffect... 100%
    Extract: Lake Reflection.nbeffect... 100%
    Extract: Pond Ripple Left.nbeffect... 100%
    Extract: Pond Ripple Right.nbeffect... 100%
    Extract: Ripple Behind.nbeffect... 100%
    Extract: Rough Winds.nbeffect... 100%
    Extract: Simple Reflection.nbeffect... 100%
    Extract: Upside Down.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack\Shear Energy
    Extract: Angled Energy.nbeffect... 100%
    Extract: Apparition.nbeffect... 100%
    Extract: Bad Dream.nbeffect... 100%
    Extract: Beam Me Up.nbeffect... 100%
    Extract: Foreground Blur.nbeffect... 100%
    Extract: Slit View.nbeffect... 100%
    Extract: Smear.nbeffect... 100%
    Extract: Tilt Left.nbeffect... 100%
    Extract: Tilt Right.nbeffect... 100%
    Extract: Vacuumed Up.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack\Spotlight
    Extract: Arthouse Dreams.nbeffect... 100%
    Extract: Black N White Center.nbeffect... 100%
    Extract: Blind Spot.nbeffect... 100%
    Extract: Blurred Spot.nbeffect... 100%
    Extract: Bright Oval Spot.nbeffect... 100%
    Extract: Bright Spot.nbeffect... 100%
    Extract: Burnt Peephole.nbeffect... 100%
    Extract: Ceiling Light.nbeffect... 100%
    Extract: Center Boost.nbeffect... 100%
    Extract: Circle Overlay.nbeffect... 100%
    Extract: Classic Portrait.nbeffect... 100%
    Extract: Classy Emphasis.nbeffect... 100%
    Extract: Clear Spot.nbeffect... 100%
    Extract: Cross Band.nbeffect... 100%
    Extract: Dark Spot.nbeffect... 100%
    Extract: Dark Vignette.nbeffect... 100%
    Extract: Focus Attention.nbeffect... 100%
    Extract: Frosted Snow Globe.nbeffect... 100%
    Extract: Glowing Orb.nbeffect... 100%
    Extract: Home  Movies.nbeffect... 100%
    Extract: Isolate.nbeffect... 100%
    Extract: Lava Lamp.nbeffect... 100%
    Extract: Light Vignette.nbeffect... 100%
    Extract: Monochrome Band.nbeffect... 100%
    Extract: Rack Focus.nbeffect... 100%
    Extract: Red Ball.nbeffect... 100%
    Extract: Searchlight.nbeffect... 100%
    Extract: Sepia Sides.nbeffect... 100%
    Extract: Show Must Go On.nbeffect... 100%
    Extract: Soft Soother.nbeffect... 100%
    Extract: Subtle Accent.nbeffect... 100%
    Extract: Swamp Alien Eye.nbeffect... 100%
    Extract: Sword Slice.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Effects\Starter Pack\Video Tuneup
    Extract: Black N White.nbeffect... 100%
    Extract: Dull.nbeffect... 100%
    Extract: Green.nbeffect... 100%
    Extract: High Contrast.nbeffect... 100%
    Extract: Moody.nbeffect... 100%
    Extract: Psychedelic.nbeffect... 100%
    Extract: Saturated.nbeffect... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Starter Pack
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Starter Pack\3D Page Turn
    Extract: Foil Page From Above.nbtran... 100%
    Extract: Foil Page From Below.nbtran... 100%
    Extract: Foil Page From Left.nbtran... 100%
    Extract: Foil Page From Right.nbtran... 100%
    Extract: Hatch Up.nbtran... 100%
    Extract: Last Page - Book.nbtran... 100%
    Extract: Last Page - Calendar.nbtran... 100%
    Extract: Next Page - Book.nbtran... 100%
    Extract: Next Page - Calendar.nbtran... 100%
    Extract: Page Away Bottom.nbtran... 100%
    Extract: Page Away Left.nbtran... 100%
    Extract: Page Away Right.nbtran... 100%
    Extract: Page Away Top.nbtran... 100%
    Extract: Wilt.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Starter Pack\3D Wiggle
    Extract: Alien Interrogation.nbtran... 100%
    Extract: Big Wiggle.nbtran... 100%
    Extract: Dream.nbtran... 100%
    Extract: Extreme.nbtran... 100%
    Extract: Fun House.nbtran... 100%
    Extract: Jello Ghosts.nbtran... 100%
    Extract: Metal Wash.nbtran... 100%
    Extract: Shake In, Ease Out.nbtran... 100%
    Extract: Shimmer.nbtran... 100%
    Extract: Warp.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Starter Pack\Dot Matrix
    Extract: Gray On Black.nbtran... 100%
    Extract: Gray On Transparent.nbtran... 100%
    Extract: Gray On White.nbtran... 100%
    Extract: Half Tone.nbtran... 100%
    Extract: Huge Dots.nbtran... 100%
    Extract: Numbers.nbtran... 100%
    Extract: Pixelate.nbtran... 100%
    Extract: Small Dots.nbtran... 100%
    Extract: Tiny Numbers.nbtran... 100%
    Extract: Valentines.nbtran... 100%
    Extract: Vivid Tone Transparent.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Starter Pack\Halo
    Extract: Gentle Glow.nbtran... 100%
    Extract: Gnarled.nbtran... 100%
    Extract: Halos.nbtran... 100%
    Extract: Reset To None.nbtran... 100%
    Extract: Sharp Edges.nbtran... 100%
    Extract: Shower Glass.nbtran... 100%
    Extract: Water Colors.nbtran... 100%
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\Resources\Library\Transitions\Starter Pack\Smear
    Extract: Bottom Left.nbtran... 100%
    Extract: Bottom Right.nbtran... 100%
    Extract: Down.nbtran... 100%
    Extract: Horizontal Stretch.nbtran... 100%
    Extract: Left.nbtran... 100%
    Extract: Right.nbtran... 100%
    Extract: Top Left.nbtran... 100%
    Extract: Top Right.nbtran... 100%
    Extract: Up.nbtran... 100%
    Extract: Vertical Stretch.nbtran... 100%
    Execute: "C:\Program Files\NewBlue\Titler Pro for Windows\vcredist_x64.exe" /q
    Delete file: C:\Program Files\NewBlue\Titler Pro for Windows\vcredist_x64.exe
    Output folder: C:\Program Files\Avid\AVX2_Plug-ins\NewBlue\NewBlue Titler Pro for Windows
    Extract: MCTitlerProHost.avx... 100%
    Output folder: C:\Program Files\Avid\AVX2_Plug-ins\NewBlue\NewBlue Starter Pack for Windows
    Extract: StarterPack64.avx... 100%
    Extract: UIHost.dll... 100%
    Create folder: C:\Program Files\NewBlue\Titler Pro for Windows\avx64
    Output folder: C:\Program Files\NewBlue\Titler Pro for Windows\avx64
    Extract: ActivationHelper.dll... 100%
    Create folder: C:\Program Files (x86)\Common Files\Avid\CustomDataAppMan
    Output folder: C:\Program Files (x86)\Common Files\Avid\CustomDataAppMan
    Extract: Newblue_Titler_Pro_1.xml... 100%
    Completed
    Jeroen van Eekeres
  • Fri, Feb 27 2015 4:36 AM In reply to
    Hmm, I'm not seeing any obvious issues with the installation. I tell you what, I've got a slightly older Titler 1 build I'd like you to try downloading and installing:
    http://www.newbluefx.com/downloads/Avid/NewBlueTitlerProForAvidMC8Setup-141031.exe
    It should be a version older than what's on the Avid Application Manager right now. Let me know if it works.
  • Tue, Apr 7 2015 4:54 PM In reply to
    Hi Marcus,
    Sorry for the delay. I haven't been able to visit the customer since your last post until today.
    I tried with the older version and the result is exactly the same.
    I've also tried the trial of v2 and this works normal.
    Regards,
    Jeroen van Eekeres
  • Tue, Apr 7 2015 5:40 PM In reply to
    Joachim,
    I thought I had replied to your post... but it seems I didn't. Sorry as your help is appreciated.
    Manually attempting to register the titler.dll results in an error saying that:
    "The module titler.dll is loaded but the entry point DIIRegisterServer was not found. Make sure that titler.dll is a valid DLL or OCX file and try again."
    Jeroen van Eekeres
  • Mon, Apr 13 2015 2:56 AM In reply to
    Hi Jeroen,
    Sorry to hear that it's still not working. We've got a new beta version of Titler Pro 1 available, when you get a chance please try it:
    http://www.newbluefx.com/downloads/Avid/NewBlueTitlerProForWindowsSetup-150330-VFX2.exe
    I'd suggest uninstalling any previous Titler Pro versions if they're still installed. When you run the installer it will list a few different NLEs, just make sure only Media Composer 64-bit is checked.
    Let me know how this version works for you.
  • Thu, Apr 16 2015 8:57 AM In reply to
    Thank you Marcus,
    That link gives me an error 404 not found. Could you check why?
    Jeroen van Eekeres
  • Thu, Apr 23 2015 2:08 AM In reply to
    Jeroen van Eekeres:
    Thank you Marcus,
    Hmm, it seems to be working okay for me. I know it's been a few days since your comment, can you try downloading again? Might be best to copy and paste the link into your browser to make sure nothing's getting "translated" incorrectly by the forum software.
  • Sat, Apr 25 2015 3:15 AM In reply to
    ok i've jumped in looking for the same fix and if this did't work it because they didn't copyed and paste that line in the browser i think it was jeroen just has to add to the correct line .all that to say it worked for me thanks what about the new blue ver 2.0 as i said i'm was haveing the same issue
    (video)Gigabyte Ga-Z87X-UD5H 4TH GENERATION I7 4770K INTEL 4600 ON BOARD GRAPHICS NVIDEIA Asus GeForce GTX 780ti (GPU 3gb ddr5 Memory)On board sound blaster... [view my complete system specs]
    "When Everybody goes Right I Go Left" I Move "Just" a little Different
  • Sat, Apr 25 2015 6:10 AM In reply to
    Hi Marcus,
    The download link now works indeed. Will be testing soon.
    Jeroen
    Jeroen van Eekeres
  • Sat, Apr 25 2015 3:07 PM In reply to
    Hi again Marcus,
    I have good and bad news. First the bad. The new version did not fix the problem. Behaviour was exactly the same.
    But then something happened that gave me a hint. When I uninstalled the new beta version and the working titler version2 the remote VNC session I was using (today is saturday and I had a few hours to try somethings out) stopped working.
    On all machines tightvnc 2.7.10 32 bit was installed. I removed it (after enabling RDP) and tried again. Now on 2 machines the error is gone. (about to try on the 3rd) When I apply the titler is gives me a white srceen and when I enable the effect editor in MC it expands titler pro and shows the "Launch User Interface" text.
    But whatever I try it does not launch the user interface. I have again tried uninstalling/installing etc... but so far no luck.
    Now because I'm logged into the maches through RDP I'm not 100% sure what I'm seeing is trustworthy. Maybe the UI is hidden somewhere because it uses the graphic card/open GL so RDP might not work at all and maybe that's also the underlying reason why there is a conflict with (tight)vnc and it pops up the titler.dll error while there is no error with the dll at all.\
    EDIT: and indeed. On the 3rd machine after removing tightvnc the error is gone but I can't open the user interface. On monday I will ask the editors on site to check if the UI works.
    Jeroen van Eekeres
