Latest post Thu, Jun 25 2015 5:47 PM by mjolnarn. 9 replies.
Page 1 of 1 (10 items)
  • Sat, Jan 31 2015 9:14 PM
    NewBlue Titler Pro render problems in MC8.3
    When trying to render a NewBlue title in a 4k project to play it back, it disappears. I'm sure it's something simple but I'm not seeing it (pun intended). Any help would be much appreciated.
    Filed under: , ,
  • Mon, Feb 2 2015 3:39 AM In reply to
    Re: NewBlue Titler Pro render problems in MC8.3
    Sorry to hear you're having trouble with Titler Pro. Just to make sure I understand, you've added the Titler Pro effect to your project and created a title, and that part is working, right? But, when you render the Titler effect on your Media Composer timeline, the title isn't visible anymore?
    Also, do you know if you're using Titler Pro 1 or Titler Pro 2?
  • Mon, Feb 2 2015 2:12 PM In reply to
    Hey Marcus, thanks for your reply. Yes, creating the title works fine but you can only see it non-rendered when the timeline is in draft or half resolution. Switching to to full or 10bit or if rendered, it disappears. It's version 1.0. I recently upgraded to MC v8.3 from 5.01. Video card is a Quadro 3800. Of the 2 driviers that MC8.3 requires 333.11 is the only one that worked with the 3800. Could that be the problem?
  • Thu, Feb 12 2015 4:43 AM In reply to
    Sorry for the slow response.
    Can you tell me exactly what type of 4K project you're using - the specific resolution and frame rate?
    Also, if you can let me know which build of Titler Pro 1.0 you're using that would be helpful as well. You can find that by opening Titler Pro and clicking on Help - About NewBlue Titler Pro.
  • Wed, Apr 22 2015 4:08 PM In reply to
    • Stu
    • Joined on Mon, Dec 6 2010
    • Washington DC
    • Posts 352
    • Points 4,205
    JC sometimes when using the NewBlue titler, you make a change in the middle of the timeline.
    When you add or create a title in NewBlue, make sure, in the NewBlue interface's timeline, that the BARS at the bottom are connecting the entire duration of the timeline.
    MEANING:  If you drop a NewBlue Titler 2.0 on 5 seconds of filler, but enter the Titler 2 seconds into the NewBlue timeline, it will add a Title starting after 2 seconds.  You just have to slide the bars around at the bottom of the NewBlue interface to make the titles appear.
    Lenovo E31 Thinkstation - MC 8.3.0 - Win7Pro SP1 - 1x Xeon 1275v2 - Kingston 32GB 1600MHz ECC - Quadro2000 /// w540: Win8.1 (not pro) - 4th gen i7 4710MQ... [view my complete system specs]
  • Tue, May 19 2015 1:01 PM In reply to
    I use this Titler too. Because there is no alternative available in 4K... But I have spent many and many hours of frustration. IMO this app does not last what it promises. It is not suitable for a fast title and for more complex tasks it doesn't has the proper functions. - No layout tools: help lines or snap in functions ... - many many bugs (as you can see in the community) - no realtime playback - and many more
    Too bad that Avid not developed further the good old Titler
  • Sat, May 23 2015 10:27 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,640
    • Points 60,630
    I think you'll find that NB is developing Titler Pro - For example, TP 3 now has realtime playback in MC. I haven't looked at TP 4 (if it's out yet) but it will likely have further improvements). Is it perfect? No, but NB seems to be invested in supporting MC.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Jun 25 2015 10:55 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,640
    • Points 60,630
    TP 4 is out. More improvements including alignment tools and title caching for improved realtime performance. Check it out if you're interested.
    Steve
  • Thu, Jun 25 2015 4:18 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Hi Steve,
    I just got the v4 upgrade, and have not had time to fully evaluate, what I have seen so far has been encouraging.
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Thu, Jun 25 2015 5:47 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    If you happen to be lucky enough to have the Sapphire OFX plugin installed , they can be used directly inside the new TP4 titler, both the Standalone version and the plugin .
    add ...  can look like this
    http://raggartv.se/raggartv/bigmeet08.html
    Tomas
