Latest post Sat, Feb 11 2017 4:39 PM by JD Marlow. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Feb 24 2015 7:30 PM
    • JD Marlow
    • Joined on Tue, Jan 1 2013
    • NYC
    • Posts 75
    • Points 805
    Cloning a clip in Avid WITHOUT keyboard modifier
    Hi everyone,
    I have a very specific question, which I'm hoping someone knows the answer to.
    I am trying to CLONE clips in Avid (the process of holding ALT/OPTION + dragging a clip to a new bin). I find it's a brilliant way to work if you want clips in more than one bin and make sure metadata carries across everything. To be clear, this is NOT the same as Duplicating a clip (COMMAND + D).
    Unfortunately, I have a snag, which is that using the remote connect software I use (GoToMyPC) the ALT/OPTION modifier isn't working for some reason. So I cannot properly CLONE clips using that software. Does anyone know of any other way in Avid to CLONE a clip without using that keyboard modifier? Can this be re-maped somehow?
    P.S.Working on MC 7.0.3, Mavericks 10.9.5, Mac Pro 4,1
    Mac Pro 10.9.5 (Dual Quad-Core 2.26 Ghz), 16 GB RAM, Media Composer 7.0.4.3 [view my complete system specs]
  • Tue, Feb 24 2015 9:11 PM In reply to
    Re: Cloning a clip in Avid WITHOUT keyboard modifier
    Not sure, but I use TeamViewer and that does allow me stuff like ALT-dragging.
  • Tue, Feb 24 2015 9:29 PM In reply to
    • JD Marlow
    • NYC
    • Posts 75
    • Points 805
    That's awesome to hear -- I'll give TeamViewer a try!
  • Wed, Feb 25 2015 12:53 AM In reply to
    • JD Marlow
    • NYC
    • Posts 75
    • Points 805
    Gave this a try on Team Viewer and did not have much success.  Holding down ALT + DRAG results in the clip just moving from one bin to the other.  It doesn't clone like it should.  Any ideas?  Are you also on a Mac?
  • Thu, Feb 26 2015 1:15 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    Use Save Bin Copy As and create all your clips in a new bin. Close the source bin. Create a new bin for your cloned clips. Drag them from the copied bin to the new bin. That way both bins can be open at the same time (you cannot open a opied bin and the original bin at the same time)
    John
  • Sat, Feb 11 2017 4:31 PM In reply to
    I'm running into this problem today on Team Viewer on a Mac.
    Were you able to find a solution or other workaround besides creating a bin copy?
  • Sat, Feb 11 2017 4:39 PM In reply to
    • JD Marlow
    • NYC
    • Posts 75
    • Points 805
    I never got to the bottom of this, no.
