Latest post Mon, Mar 2 2015 4:14 PM by SamDogDigital. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Feb 28 2015 10:17 PM
    What's the best/fastest way to watermark outputs with text?
    Let me explain the current workflow I have, and I'd love to hear any and all thoughts about how to speed this process up.
    We output a same as source quicktime with a "Property of Company" as well as the reel name, date, and LFOA information as a title graphic over the picture. That single quicktime then runs through MPEG streamclip to compress for a few different people and we have MPEG add another overlay with their individual names on there. This process takes time.
    I've heard that compressor can do this, and I'd love to be able to export one clean SAS file and drag and drop onto various droplets with all this stuff set up, but there are two issues I'm running into:
    1. The dreaded "Compressor can't handle DNx codecs." In my experience, and many others, for some reason it fades to a reddish hue and doesn't actually compress the video.
    2. Every time I try and set up compressor to compress to DNx36 it crashes instantly when I select that codec from the list. This seems to be a more localized issue with me, but I think others have experienced this as well.
    Any help you guys can provide in beefing up this workflow would be helpful!
  • Sat, Feb 28 2015 10:38 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,407
    • Points 41,115
    Re: What's the best/fastest way to watermark outputs with text?
    You can add a watermark inside MPEG Streamclip.  Look under adjustments.
    Very limited, but free.
    Jef
    Jef Huey
  • Sat, Feb 28 2015 11:04 PM In reply to
    Check out Squeeze. Allows you to add watermarks, save your own presets (including the watermarks), and the pro version lets you compress watch folders. Create a preset for each name, export the SAS to the watch folder, and Squeeze will output the various versions.
  • Mon, Mar 2 2015 5:27 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    Job ter Burg:
    Job - you don't need the Pro version for watch folders, just the desktop version. The only difference I can detect with the Pro version is the ability to render directly to MXF files...
    John
  • Mon, Mar 2 2015 6:44 AM In reply to
    Ah, thanks, I stand corrected then.
  • Mon, Mar 2 2015 4:14 PM In reply to
    I use and like the latest version of Adobe Media Encoder which will read and write DNxHD as well as inserting the watermark.
    Lee
    Daytime Gig Gear Hardware: HP Z820 32gb ram • AJA Kona LHi • Xtore 5tb RAID • NVidia Quadro 5000 • JVC 24" HD-SDI monitor • Avid Artist Color &... [view my complete system specs]
