Latest post Fri, Mar 27 2015 9:46 AM by andym. 3 replies.
  • Thu, Mar 19 2015 1:04 PM
    • tiidavid
    • Joined on Thu, Mar 19 2015
    • Posts 13
    • Points 165
    checkSequenceIsReadyForXfer returns error when sequence include audio only master clips.
    In case:
    Sequence has audio rendered effects. Audio rendered effects do not have video. When CheckSequenceIsReadyForXfer issued by Web API to such kind of sequence, API returns error even if all of other master clips have correct video format.
    Are there any way to avoid this error?
    For example, sequence contains two media files.
    Master clip 1: It has 3 trackes, V1 A1 A2. V1=DNxHD145, A1=PCM, A2=PCM
    Master clip 2: It has 2 trackes, A1 A2. A1=PCM, A2=PCM (Audio dissolve rendered effect)
    CheckSequenceIsReadyForXferType [..... targetResolution=DNxHD 1080 115-120-145] returns Error size: 1, CheckSequenceIsReadyForXferEx noAudioRealTimeEffectCheck=false
    Are there any way not to check audio only master clips by CheckSequenceIsReadyForXfer call?
    Version: Interplay Engine 3.0.8, Interplay Web Service 3.0.9.
  • Fri, Mar 20 2015 8:01 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
    • Avid Developer Moderator
      Avid Employee
    Re: checkSequenceIsReadyForXfer returns error when sequence include audio only master clips.
    tiidavid,
    I spoke to our team here and got this response:
    "Short answer: No there is no way of omitting anything from the sequence check as far as I know. However, there is an additional, undocumented function ‘CheckSequenceIsReadyForMixdown’ in the WSDL which is less restrictive, maybe that could be an option."
    - Rob
  • Fri, Mar 27 2015 9:24 AM In reply to
    • tiidavid
    • Posts 13
    • Points 165
    Hi, Rob, Thank you for replay.
    Is following correct to use CheckSequenceIsReadyForMixdown? I am asking because it is not documented. Following example is for XDCAM HD 50mbps video availbility.
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:typ="http://avid.com/interplay/ws/transfer/types">
      <soapenv:Header>
          <typ:UserCredentials>
             <typ:Username>administrator<typ:Username>
             <typ:Password>is-admin<typ:Password>
          </typ:UserCredentials>
      </soapenv:Header>
      <soapenv:Body>
        <typ:CheckSequenceIsReadyForMixdown>
          <typ:InterplayURI>interplay://WGA?mobid=060a2b340101010101010f0013-000000-4967a5831e180135-060e2b347f7f-2a80</typ:InterplayURI>
          <typ:TargetResolution>XDCAM-HD 50mbps 1080i 60</typ:TargetResolution>
        </typ:CheckSequenceIsReadyForXfer>
      </soapenv:Body>
    </soapenv:Envelope>
  • Fri, Mar 27 2015 9:46 AM In reply to
    • andym
    • Joined on Thu, Jan 13 2011
    • Posts 117
    • Points 1,405
    Hi tiidavid,
    CheckSequenceIsReadyForMixdown works exactly like CheckSequenceIsReadyForXfer from the outside, just internally the checks are modified to match the capabilities of Interplay Transcode (instead of Transfer).  The call you have been using with CheckSequenceIsReadyForXfer should work with CheckSequenceIsReadyForMixdown without any modifications.
    Hope this helps
    Andy
