Latest post Sun, Apr 12 2015 7:25 AM by persyst. 12 replies.
Page 1 of 1 (13 items)
  • Fri, Apr 10 2015 3:19 PM
    • persyst
    • Joined on Tue, May 27 2014
    • Posts 148
    • Points 1,915
    Which Mac to buy?
    Hello All!
    I am looking to purchase a Mac which will give me smooth full screen at full resolution editing of 4K video in Media Composer and have tested out simply adding 4K and HD (1920 x 1080) footage into the timeline and viewed them at fullscreen but on both the machines below, I get choppy playback. For reference, the videos when played in Quicktime, play perfectly at fullscreen. Would anyone possibly have any recommendations for which Mac I should be looking at, to get the smooth fullscreen or if something else might be the problem?
    Thanks for any help you can provide!!! Stefan
    Notes:
    - I tested the 4K video via AMA (choppy playback) and imported the 4K clip at the 1:1 default setting (extremely choppy). Testing on both machines below yielded the same results for me.
    - My media is stored on a Western Digital My Passport (USB 3.0)
    • Tested on 2015 Mac Pro
    • 3.5GHz 6-core with 12MB of L3 cache
    • 16GB (4x4GB) of 1866MHz DDR3 ECC
    • 256GB PCIe-based flash storage
    • Dual AMD FirePro D500 GPUs with 3GB of GDDR5 VRAM each
    Tested on 2015 MacBook Pro
    • 2.8GHz Quad-core Intel Core i7, Turbo Boost up to 4.0GHz
    • 16GB 1600MHz DDR3L SDRAM
    • 1TB PCIe-based Flash Storage
    • Intel Iris Pro Graphics and NVIDIA GeForce GT 750M with 2GB of GDDR5 memory
    Media Composer 8.4.5 Pro Tools 2018.12 Mac Pro 2013, MacOS High Sierra 10.13.6 • 2.7GHz 12-core with 30MB of L3 cache • 64GB (4x16GB) of 1866MHz DDR3... [view my complete system specs]
    Filed under: ,
  • Fri, Apr 10 2015 3:23 PM In reply to
    Re: Which Mac to buy?
    Uncompressed 4K from a USB3 drive?!
  • Fri, Apr 10 2015 4:23 PM In reply to
    • persyst
    • Posts 148
    • Points 1,915
    Thank you for you're non-helpful comment.
  • Fri, Apr 10 2015 5:15 PM In reply to
    I think Job's point is valid.  To try and play uncompressed 4K from a single USB 3 drive seems like a pipe dream.
    And keep in mind even if QuickTime plays it back, that's all QuickTime has to do...Avid has to be able to do many, many more things than just play a clip in a simple interface.
    Perhaps some sort of RAID would provide you the throughput you need with the CPU you have?
  • Fri, Apr 10 2015 5:46 PM In reply to
    • persyst
    • Posts 148
    • Points 1,915
    So for testing purposes, if I save the 4K clip on the local disk, and try playing it in MC on either of the two Mac machines mentioned above, should it play smoothly? Or does having a RAID drive allow for quicker access than the local disk?
    Or would I just need to get the maxed out $10,000 Mac Pro to acheive what I'm looking for?
  • Fri, Apr 10 2015 8:11 PM In reply to
    • Posts 10,219
    • Points 218,265
    Jobs comment was actually spot on. Depends on what is on the timeline and  the effects etc.... But you can certainly test the software using the trial version and see how that goes.  I can probably get some concrete data for you but may take a da or so as our hardware team is at NAB. I'll check with them on the 2 Mac versions and see what they say. I do know 4k on USB3 isn't really going to work.
    marianna
  • Fri, Apr 10 2015 8:51 PM In reply to
    • persyst
    • Posts 148
    • Points 1,915
    Let me be more clear. Can someone please tell me what Mac machine and external storage I need to buy to get smooth full screen editing of 4K footage using the Media Composer 8 which I own? My budget is $15,000.
    Thank you.
  • Fri, Apr 10 2015 9:24 PM In reply to
    • Tiger_XP
    • Joined on Fri, Feb 2 2007
    • California
    • Posts 460
    • Points 5,075
    persyst:
    So for testing purposes......
    1. Download these two apps so you will know the speed of the drives that you have                                                              a. BMD      https://itunes.apple.com/us/app/blackmagic-disk-speed-test/id425264550?mt=12                                               b. AJA       https://www.aja.com/en/products/aja-system-test
    2.  Know the speed it takes to use certain footage. And no 4K is not on this chart, but if your "drive speed" is below these numbers there is a good chance 4K will struggle to play.   (attached)
    3. Getting a maxed out $10,000 nMP would be the most expensive "test" available! Read here about nMP's and the 2011 GPU's and such    http://forums.macrumors.com/forumdisplay.php?f=1  (use the search engine)
    4. When "testing", use multicam playback as a template using a. R3D  b. Alexa  and c. GH4    In the end you will know where your system stands or crawls. Smile
    PS: It should/will not take $15,000 to play 4K on a Mac. Just a little thought, research and the right configuration.
    MacPro 2008 3.1 | 34GB Ram | Quadro 4000 980ti 960| MC 8.10 | OS 10.6.8 10.13.6 | MOTU HDX-SDI | ATTO R644| LaCie 324 [view my complete system specs]
  • Sat, Apr 11 2015 3:36 AM In reply to
    • Greg K
    • Joined on Mon, Apr 14 2014
    • Posts 64
    • Points 670
    What is the source of the 4K and 1080p footage, in other words, from which camera does it come from and what format and codec does it come in?
    I ask, as I was able to play back 4K RED footage via transcoding to the DNxHR HQX in Media Composer 8.3.
    Playing one clip back seemed to take 93 MB/s in MC, which can be done with an external USB 3.0 drive.
    Also what MC version do you use, what project settings did you use and how did you transcode the footage to Uncompressed (which is probably overkill depending on the source)?
    how old is this forum software?
  • Sat, Apr 11 2015 9:05 AM In reply to
    • Tiger_XP
    • California
    • Posts 460
    • Points 5,075
    persyst:
    Thank you.
    You were very clear in your original post. There are a couple of ways to approach your work flow.
    The 5,1 cMP (classic Macpro) and the 2013 (there is no 2015 nMP,yet) 6,1 nMP (new Macpro)
    Attached is a chart comparing the speed of PCIe and TB2. Hopefully someone will chime in with an nMP stating practice not theory.
  • Sat, Apr 11 2015 10:29 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Try using one of the DNxHR codec settings rather than 1:1 when bringing in your 4K material.  As you haven't yet stated what the source is, I'm going to guess that it's fairly compressed which would explain why your USB 3 drive speed is not the limiting factor.  If that's the case, you're unlikely to lose any resolution using a DNxHR codec.  You can try the different flavors of DNxHR to see which one(s) work best, then depending on your results, you'll know what kind of throughput you'll need from external drives.  A single USB 3 drive is going to struggle above 130-180 MB/s.  Note that the internal flash memory on the new Macs are crazy fast but of limited capacity, so external storage is probably a necessity for longer projects.  If you want to do 4K, conisder a Thunderbolt RAID.  If you want to edit in 4K consider a Mac Pro or a iMac Retina, not a laptop.
  • Sun, Apr 12 2015 2:22 AM In reply to
    • Tiger_XP
    • California
    • Posts 460
    • Points 5,075
    A take from "the other side" @ Creativecow (Keep dates of posts in mind)
  • Sun, Apr 12 2015 7:25 AM In reply to
    • persyst
    • Posts 148
    • Points 1,915
    Thank you for all the info everyone. I purchased a G-tech 6TB Raid with thunderbolt connection to try out, and I definitely noticed great improvement both with AMA and DNxHR HQX transcoded 4K playback vs storing on the USB 3.0, but is there a way to save to and run bin media from my internal drive just to test the video playback performance that way? The "filter out" button is unchecked, but my internal drive is grayed out and I can't select it as a drive to transcode or import to. I'm i missing something here?
