Latest post Fri, Mar 16 2018 1:33 PM by Terry Snyder. 80 replies.
Page 5 of 6 (81 items) « First ... < Previous 2 3 4 5 6 Next >
  • Tue, Dec 20 2016 12:39 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,315
    Re: Sorenson Squeeze codec problems between MainConcept & x264
    smyers63:
    mjolnarn:
    Too many variables and different problems here , might not be related , last post was about greater than HD , I would suggest to start from the beginning with separate threads.
    The thread subject says nothing about frame size and Mohammed's problem fits the subject of the thread.  There's no reason to start a new thread.  Keeping it here will allow people to learn about more solutions in one place.
    Ok well , for those that not have the time go through the entire thread a minor summarize.
    The thread started with APR to x 264 problems on the PC side , no problems on the Mac side , this with 1080p projects, it then turned also to customized x 264 Squeeze presets problems, same 1080p raster , and have now later on turned to problems with exporting UHD media to x 264.
    My own results already written here, I have now also tested with UHD media.
    To summarize , I have no problems myself with using the standard Youtube 6000 x264 1080 preset on HD or UHD media , I have also customized that same preset to be " same as source " and increased the file speed to 20000 and encoded to X 264 UHD media , this with both the origin GoPro media as source as well as a qt ref out from Avid from DNxHR HQX media .
    This with Win 10 and Quicktime 7.7.9 and SS 11 Pro
    If anyone with about the same setup as mine please could retest the same workflows it would be nice .
    Tomas
  • Wed, Dec 21 2016 3:38 PM In reply to
    • Seth L T
    • Joined on Tue, Mar 25 2014
    • Yorktown, VA
    • Posts 30
    • Points 400
    mjolnarn:
    Are you guys ( with problems ) encoding to mov or mp4 containers.
    If mov , please retest with mp4
    I am attempting to make .mp4 from a Quicktime Reference file. The encoding starts and somewhere a few seconds into it, it starts erroring. You get multiple runtime errors and it spams files you have to go delete in your destination folder.
    HP Z820 Workstation OS: Windows 10 Pro 64-bit (10.0, Build 10240) CPU: Intel(R) Xeon(R) CPU E5-2640 0 @ 2.50GHz (24 CPUs), ~1.5GHz Memory: 16384MB RAM... [view my complete system specs]
  • Wed, Dec 21 2016 3:43 PM In reply to
    • Seth L T
    • Yorktown, VA
    • Posts 30
    • Points 400
    mjolnarn:
    My problem is only with 1080p. Anything else works....however I am not certain with anything greater than 1080p because that is all we shoot. 720p works with x264 and most of the time 1080p works with Main Concept H.264 but even then I have had it happen once.
    The thing I've noticed that is different from our old version 9 to 11 pro is that in the task manager 11 pro has many task running. Something with "external server" in the name and I almost wonder if it is crashing the workstation out because the CPU jumps to 99% (regardless of the speed/usage settings). I wonder if something in the programing is making 1080p so much more of a workload. I am not in the office today but I have a ton of screenshots I had sent to Sorenson (which didn't matter).
  • Wed, Dec 21 2016 3:48 PM In reply to
    • Seth L T
    • Yorktown, VA
    • Posts 30
    • Points 400
    mjolnarn:
    smyers63:
    mjolnarn:
    I can see how my first post was misinterperted. What I meant was 1080p and above assuming that the issue persisted. I have never done UHD content. So please forget that. I was mainly speaking of 1080p.
    I have tried the YouTube presets and get the error. I have tried many different custom x264 settings and get the error. When I am back in the office I will try your settings. I am wondering if there is an issue between hardware and the software because both me and the OP have similar workstations.
  • Wed, Dec 21 2016 4:18 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,315
    Seth L T:
    Ok, thanks , if this is with a QT ref you need to have a correct Avid workflow , some recommend doing mixdowns and replace , my own workflow is to alt drag the sequense to a new bin , transcode to the same dnx codec that it have been transcoded to before , only clips that needs to be transcoded will be that , do a render if that is needed, to the same codec as that transcode of course , and now a QT ref should work brilliant, at least it have done that for me the last 5 or 10 years.
    You could also of course try with some untouched camera media 1080 p to verify that SS 11 not works .
    Awaiting results
    Tomas
  • Fri, Dec 23 2016 3:30 PM In reply to
    • Seth L T
    • Yorktown, VA
    • Posts 30
    • Points 400
    mjolnarn:
    Seth L T:
    Awaiting results
    Yeah so I just kind of figured that's how everyone in here does it. I always make a new sequence with a video and audio mixdown before I create my qt ref.
    I'm still leaning to a hardware issue with the Z800ish stations...Maybe the Sorenson software since 10 can't handle dual processors and errors out? This is beyond my knowledge though but seems to be the only similar thing me and the OP have. Your PC looks custom built?
  • Fri, Dec 23 2016 3:39 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,315
    Seth L T:
    Jepp , one Cpu , 12 cores X +4 Ghz is around 50 Ghz and Squeeze uses it all at 100 % during encodes .
    Did you try with just Source media , maybe direct from a card , I want to shorten the test workflow if possible
    Tomas
  • Tue, Feb 13 2018 8:33 AM In reply to
    • Andi
    • Joined on Wed, Feb 20 2013
    • Germany
    • Posts 2
    • Points 10
    If the audio get sync problems you have to make sure that the COMPRESSION SYSTEM LOAD is set all the way to Light.
    Go to Squeeze - Edit - Preferences - Advanced - Compression System Load -- slider to Light
    Sadly then you don´t have multi transcodes, but audio and video is syned. (you could open more squeeze windows to get more transcodes at a time)
    HP z820, m4000, MC 8.10 [view my complete system specs]
  • Fri, Feb 23 2018 4:16 PM In reply to
    • Bingo
    • Joined on Thu, Aug 24 2006
    • Posts 10
    • Points 130
    Have same same issue from changing station to z640. Cannot compress 1080P with x264 codec. All other format works but not in 1080P. So i compress x265 and do a another pass in Handbrake but it took a longer time in x265.
    Z640
    CPU E5-2630 v4@ 2,20GHz dual
    64Gb Ram
  • Fri, Feb 23 2018 4:56 PM In reply to
    • scocklin
    • Maryland
    • Posts 640
    • Points 7,670
    I gave up trying to make this work since my first post on this subject.  I set up a network between my Z800 PC and my MacBook via thunderbolt gigabit ethernet adaptor.  I now export from Avid to a folder on my Z800 internal raid drive that networks to my Macbook.  Squeeze compresses the file on my PC and saves the  x264 compressed file to a USB 3.0 drive connected to my Macbook.
    HP Z800 2x 3.46GHz Hex Core X5690, 48GB Ram, Windows 10, Samsung SSD 850 Pro 512GB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K,... [view my complete system specs]
  • Tue, Feb 27 2018 4:33 PM In reply to
    • mtahir
    • UK
    • Posts 479
    • Points 5,840
    I found out that Squeeze 11 requires Windows 10. Out of curiosity, I installed Squeeze 10 on a Windows 10 virtual machine running under VirtualBox. I discovered that the x264/1080p encode works!
    I've got the same x264/1080p encode not working on a Windows 7 x64 partition, even on a new, clean partition with no other software installed. Does this mean that Squeeze 10 needs Windows 10? Not according to these reqirements: it clearly states Windows 7 or 8.
    Interestingly, before I knew about the Windows 10 requirement for Squeeze 11, I had tried it on a Windows 7 partition and the x264/1080p encode failed - everything else seemed to be working. I can't remember if it failed in the same way as Squeeze 10.
    MC2018.1 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
  • Tue, Feb 27 2018 5:12 PM In reply to
    • scocklin
    • Maryland
    • Posts 640
    • Points 7,670
    mtahir:
    I have Windows 10 installed and it fails on my Z800
  • Wed, Feb 28 2018 2:05 PM In reply to
    mtahir:
    I never realized this and upgraded to Squeeze 11 Pro last year.   I'm still on a Win7 Z800.   I don't use X264. I use H.264 to create MP4's or I create MPEG-2's for broadcast.  So far, I haven't noticed any problems, but I'll have to remember to resist the next Sorenson upgrade offer as long as I'm still on my Win7 machine.
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Wed, Feb 28 2018 4:26 PM In reply to
    • mtahir
    • UK
    • Posts 479
    • Points 5,840
    Let me correct that, Terry: if you look at the requirements here, it says Windows 8 or 10 but Windows 7 is not on the list.
  • Wed, Feb 28 2018 4:35 PM In reply to
    • mtahir
    • UK
    • Posts 479
    • Points 5,840
    scocklin:
    Steve - it might be worth trying it on a clean Windows 10 partition as a test. I don't know how easy that is with your setup. Just to see if it's something that you may have installed that's broken it. I had to go back to rebuilding my Windows partition when I discovered that I couldn't transcode multiple files without errors: I tried a clean Windows 7 partition as a final check to find that everything was working fine, so I knew my partition was broken.
    The x264/1080p issue has failed me every time on a new Windows 7 partition but not on a new Windows 10 one. I've raised all of this with Sorenson support and let's see what they have to say.
