Latest post Mon, May 25 2015 10:42 PM by hbrock. 3 replies.
  • Sat, May 23 2015 4:10 AM
    • Lucas Maia
    • Joined on Sat, May 23 2015
    • Posts 3
    • Points 45
    Playback issues
    Hi Folks
    In our facility, we use a NAS server as our shared storage. It has a very good throughput and an excellent response.
    We were facing some unexplainable playback issues and today i've figured out that the dropped frames happened 2 seconds before a cut with a polyphonic audio, sometimes with an audio dissolve the problem gets more evident. Do someone has the same problem?
    I have already tried almost all console commands related to audio.
    We are using Media Composer 8.3.1 on OSX 10.10.2.
  • Sat, May 23 2015 4:59 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Re: Playback issues
    Wild guess: block sizes on your server.  Good performance for video files (large) can impact audio files (small) in a unpleasant manner as you could be putting a very small file into a very large space and then have to wait until the next block to get the next small file.  In other words, a little bit of something and a whole lotta nothing.
    If you want to try a test, consolidate some audio files to a local drive and see if the problem goes away.
  • Mon, May 25 2015 1:40 PM In reply to
    • Lucas Maia
    • Posts 3
    • Points 45
    Re: Playback issues
    Thank you so much hbrock!
    Excellent shoot.
    Consolidating the audio files to a local drive made it works.
    We are going to do some changes on the server side and i'll keep you in the loop.
    Cheers!
  • Mon, May 25 2015 10:42 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Re: Playback issues
    You might want to consider seperate volumes on the server with smaller block sizes for the audio media.
