Latest post Wed, Jun 3 2015 10:50 PM by Smallan. 4 replies.
  • Wed, Jun 3 2015 2:22 AM
    • Smallan
    • Queensland, Australia
    • Posts 252
    • Points 3,390
    Avid FX 6.4, can't move my tracks
    I've been working on an effect in Avid FX 6.4, it has about 10 tracks and suddenly today I can't move any tracks up or down.  None of them are locked.  Presumably I've inadvertently changed a setting or something.
    Any ideas?
    Thanks.
    MB: Asus P9X79 PRO. CPU: Intel Core i7 3930K. Power Supply: Corsair AX850. Ram: 16GB(4x 4GB). GPU: Nvidia GTX670. Boot Drive: Intel 520 Series 120GB Solid... [view my complete system specs]
    Call me Al.
  • Wed, Jun 3 2015 4:05 AM In reply to
    • Posts 10,993
    • Points 228,335
    Re: Avid FX 6.4, can't move my tracks
    Smallan:
    Any ideas?
    Thanks.
    You had the same problem back in February 2014
    Did you fix the problem then?
    If so, try and remember what you did.
    Regards
    Douglas
    PS. I don't remember if you posted here on the forums or if it was through direct contact with BorisFX.
  • Wed, Jun 3 2015 4:42 AM In reply to
    • Smallan
    • Posts 252
    • Points 3,390
    Yes and no Douglas.  Yes I fixed it, but at this point, no, can't remenber how.
    Call me Al.
  • Wed, Jun 3 2015 6:49 AM In reply to
    • Posts 10,993
    • Points 228,335
    Here are a couple of "copy & pastes" from the previous round:
    From me to you around 16th Feb 2014:
    I've asked Boris about your problem.
    The wonder which version of Avid FX you are on.
    They have a vague recollection that the problem you describe existed in a previous version.
    The latest version is 6.4
    I can see it in the Download Centre at Avid, under Avid FX.
    I am not sure about the serial number for it.  If your previous version was downloaded from Avid, then I guess that it should install without needing a serial number, as that should already be on your system.
    I usually uninstall the older version before installing a new one - but that may not be necessary.
    Your reply, the following day
    All working perfectly thanks Douglas =D>.
    Regards
    Douglas
  • Wed, Jun 3 2015 10:50 PM In reply to
    • Smallan
    • Posts 252
    • Points 3,390
    Thank you Douglas, yes that was the solution.  Part of the reinstall process was to install 3 Microsoft Visual C++ items.  This would be due to the fact that I'm working on an OS from June 2013 to which I've reverted, a Macrium Reflect image.  I'm in the process of updating it.  This was obviously part of the update Smile.
    I appreciate the help Douglas.
    Call me Al.
