Latest post Thu, Jul 30 2015 11:18 PM by myersam1. 0 replies.
Page 1 of 1 (1 items)
  • Thu, Jul 30 2015 11:18 PM
    • myersam1
    • Joined on Thu, Feb 23 2012
    • Posts 41
    • Points 465
    FS7AMA Audio TC issue
    Update: I have been able to bring in with the correct TC on the audio if I change the AMA plugin to file type to SONY XAVC_Xdcam(*.mxf) in the AMA window. I can not use the (folder) to bring it in and get the correct timecode on the audio part of the files. Also this is annoying as I have to go all the way into the clip folder to bring the mxfs in. Selecting the folder should work but doesn't. Any ideas would be appreciated.
    Hello
    I am working on an IMAC 3.5GHZ I7 with 32gb of ram and 10.8.5 OS with Avid 7.0.4
    Footage is on a Promise Pegesus but also have the same issue off lacie drives both are thunderbolt.
    I have been having an interesting issue with AMAing FS7 footage. The Audio timecode on NON_SPanned clips is incorrect when using my computer. My boss used his and they were fine. We checked AMA plugins and they are mostly the same or mine are more recent. I was unable to mutligroup because of this issue. The Non Spanned clips also have a data track which the Spanned clips do not. The data track has the  correct timecode on it. Trying to narrow down why this has occurred for the future. Also When I get info on the clips the Spanned is missing the Video section, but does show it is the same codec in the bin. This is all before transcoding. The audio is PCM, 48khz, 24 bit depth, 9216kbps bit rate and 8 channels.
    Here are the plugins I have
    AVCHD MSP Plug-In Avid Technology, Inc. 1.3.2.6475
    AVCHD MVP Plug-In Avid Technology, Inc. 1.3.2.6475
    QuickTime Plug-In Avid Technology, Inc. 1.3.2.6475
    AS-11 Plug-In Avid Technology, Inc. 1.0.2.6475
    MSP_MXF Plug-In Avid Technology, Inc. 1.10.1.6475
    WaveAiff Plug-In Avid Technology, Inc. 1.1.0.6475
    MVP_CanonXF64 CANON INC. 2.0
    MVP_MSP_ARRI_MXF Hamburg Pro Media GmbH 1.4
    AS-02 Plug-In Avid Technology, Inc. 1.2.2.6475
    IkegamiGFCam Plug-In Avid Technology, Inc. 3.7.0.0
    PanasonicP2 MVP_MSP Plug-In Panasonic. 4.2
    RED R3D Plug-In (R3DSDK v4.6) Avid Technology, Inc. 1.11.0.6745
    MVP_MSP_SonySRDeck_64bit Sony Corporation 2.2155
    MVP_MSP_SonyRaw_64bit Sony Corporation 2.3102
    MVP_MSP_SonyXDCAMEX_64bit Sony Corporation 1.7053
    SonyXDCAM_64bit Sony Corporation 3.2011
