Latest post Thu, Aug 20 2015 6:15 PM by mtahir. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Aug 13 2015 10:40 PM
    • mtahir
    • UK
    • Posts 479
    • Points 5,840
    Can't import AVCHD - MC8.3.1/8.4
    I've been experimenting with MC8.4 on a PC with the following specs:
    Dell T7500
    2 x Hex Core x5690 CPUs 3.46GHz (3.76GHz in Turbo mode)
    48GB
    512MB SSD
    I can AMA AVCHD and transcode but when I try to do an import, nothing happens. There is no message saying that the file is problematic. In fact, I even downloaded an AVCHD file from the web and it was the same result - no import. These are files that I've imported into MC5.5 (my current system) without a problem. I've also tried MC8.3.1 and exactly the same result. I can import other files without a problem but not AVCHD.
    Any ideas? I presume import should work? I've tried searching around for any info on this but I couldn't find anything.
    MC2018.1 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
    Filed under: , , ,
  • Thu, Aug 13 2015 11:53 PM In reply to
    Re: Can't import AVCHD - MC8.3.1/8.4
    I don't really have an answer to the question, but curious - what's the reason for trying to import?  If AMA and transcode works, that's the preferred way.  It's all I use.
    It's the same end result - you get Avid-native media.  The difference is, if you AMA, you CAN link back to the original if you choose.  Not so with import.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.12.6, Avid Media Composer 2018.5 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
  • Fri, Aug 14 2015 12:19 AM In reply to
    • mtahir
    • UK
    • Posts 479
    • Points 5,840
    I appreciate what you're saying. I've been using MC5.5 for a few years and my only way to get AVCHD footage in  is to import as there is no AMA/AVCHD plugin for that version. Naturally, I was expecting for the same thing to work again. Sure, you can AMA and link back etc. but clearly there is bug here (if others can confirm) that needs addressing.
  • Fri, Aug 14 2015 12:30 AM In reply to
    • DSMaMa
    • Joined on Fri, Jun 29 2012
    • Posts 64
    • Points 765
    i just tried this with MC8.4 with a footage i got online and it imported fine
    here is the link of the footage that i used.
    http://download.shedworx.com/common/snow.MTS
    I tried on the MAC BTW
  • Fri, Aug 14 2015 12:46 AM In reply to
    usatraveler:
    ?? Batch Import has been one of the most useful and reliable options with Avid for decades.
    FWIW MC 8.4 on a homebuilt W7 SP1 computer. DSMaMa's file imported without issuses here to a new 1080 59i project (took about 30 sec's with the hour glass on the desktop before the import progress screen showed up)
  • Fri, Aug 14 2015 4:54 AM In reply to
    • mtahir
    • UK
    • Posts 479
    • Points 5,840
    Thanks for the file and thanks for trying the import. Believe it or not, it doesn't work for me - same results as before. There are no errors, no warning messages, nothing. I've installed, uninstalled the sofware a few times including the video driver, QT... but it makes no difference - I can't import an AVCHD file.
  • Thu, Aug 20 2015 6:15 PM In reply to
    • mtahir
    • UK
    • Posts 479
    • Points 5,840
    Just an update on this. I've got two Win7 x64 partitions - one is with my current MC5.5 setup and the other is a Test partition where I can try out things. AVCHD import doesn't work on this Test partition. However, when I uninstalled MC5.5 in my other partition and installed MC8.4., AVCHD import worked! I would actually argue that my Test partition is an a healthier state than my everyday MC5.5. one. Whatever the reason, something in the Test partition cause importing of AVCHD files in MC8.4. to not work. There are no error message or failed imports - nothing happens. Just one of those things that I can't explain.
    Filed under: , , , ,
