Latest post Fri, Sep 11 2015 2:50 AM by dmfreeman. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Aug 15 2015 11:26 AM
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Uninstall New Blue Titler Pro 3 Before Installing v 4
    Hopefully someone will let me know this.  When I installed NB Titler Pro 4, I already had version 3 installed on my computer.   My assumption was (wrongly) that the new install would uninstall the prior version.  I noticed in Control Panel>Programs and Features, still lists both.  Should v3 be uninstalled, or would this cause issues with v4?
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Sat, Aug 15 2015 11:33 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,627
    • Points 60,455
    Re: Uninstall New Blue Titler Pro 3 Before Installing v 4
    Hi Denny - I noticed the same thing (and made the same assumption). I haven't tried uninstalling TP3 so I can't tell you if it will damage your TP4 installation but I suspect that it would. You might have to deactivate and uninstall both and then install TP4 again. Personally, I'm just going to leave it as-is for now.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Aug 15 2015 12:20 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    My thoughts are the same, "If it ain't broke, don't fix it".  Perhaps Marcus from NB might give us some direction on this.
    Denny
  • Thu, Aug 27 2015 1:27 PM In reply to
    dmfreeman:
    Denny
    Hi Denny,
    It's possible you had our original version of Titler Pro 3 installed. Back at the beginning of the year we moved to a unified activation manager for our products, which also changed the installers and update process. So if you had a version of TP3 that was loaded with the old installer, that might be why the Titler Pro 4 installer didnt remove it.
    Anyway as long as it's not causing you any problems I wouldn't worry about it. Out of curiosity are you seeing more than one Titler Pro entry in your effects palette, or just the one for Titler Pro 4?
  • Fri, Aug 28 2015 12:44 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Hi Marcus,
    Titler Pro, and Titler Pro 4 both appear in the effects palate.  When I try to put Titler Pro 3 to the timeline, Media Composer crashes and I go to the desktop.  Would this indicate that I should uninstall TP 3? or just not use it?
    Denny
  • Fri, Sep 11 2015 2:50 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Hi Marcus,
    I see both v3 and v4 in my effects palate.  Trying to load v3 will crash MC.  Should I uninstall v3, and if I do, what will happen to v4?  Will it continue to function properly, or would I have to reinstall it?
    Denny
