Latest post Mon, Sep 7 2015 9:50 AM by Julius Klingel. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Sep 4 2015 6:37 PM
    • hwilliams
    • Joined on Fri, Dec 12 2014
    • Posts 20
    • Points 275
    Data Model documentation: TYPE_DIGITSRIGHT or TYPE_DIGITSAFTER?
    I think it's just a typo, but the docs I have for Interplay MAM v5 ("Interplay | MAM Data Model Format Reference", p. 26) says that for ModelAttributes,
    If TYPE is float, TYPE_DIGITSRIGHT contains maximum number of digits right of the decimal point.
    ConfDMLib: DMAttribute.type.floatDigitsRight
    In looking at the XML I get from the web service, it looks like that should be TYPE_DIGITSAFTER. Is that just a doc error or is something changing between versions?
  • Mon, Sep 7 2015 9:50 AM In reply to
    • Julius Klingel
    • Joined on Fri, Feb 15 2013
    • Kaiserslautern, Germany
    • Posts 4
    • Points 40
    • Avid Developer Moderator
      Avid Employee
    Re: Data Model documentation: TYPE_DIGITSRIGHT or TYPE_DIGITSAFTER?
    You are right it is a typo in the documentation.
    The XML Element name must be TYPE_DIGITSAFTER nevertheless the property name in ConfDMLib is correct.
    Actually it should read:
    If TYPE is float, TYPE_DIGITSAFTER contains maximum number of digits right of the decimal point.
    Thank you for informing us we will update the Data model reference accordingly for the next release of Interplay | MAM.
