Latest post Wed, Dec 16 2015 6:36 PM by rory.cook101. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Dec 15 2015 4:33 PM
    MXF will not import MC 7.03
    I bought two MC 7.03 systems a year ago and they have never been used due to IT/ contractor poor setup.
    The support has run out and I am on a mission to get the system working
    Problem: Can't take in / import P2 MXF original files. I can drag and drop XDCAM MXF files but I can't link with AMA or import or drag and drop P2 MXF.
    Plugins will not load as for earlier versions. Do I need to load Panasonic plugins and drivers from Panasonic.
    I am Pro Video with no experience of MC
    Need Help Please! - Thanks.
    Rory
  • Tue, Dec 15 2015 4:49 PM In reply to
    • Pixel Monkey
    • Posts 1,242
    • Points 15,695
    Re: MXF will not import MC 7.03
    Yep. Close Composer. Install this directly from Panny's website (Link). Relaunch. All fixed.
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
    WWLD (What Would Larry Do?)
    WWND (What Would Norman Do?)
  • Tue, Dec 15 2015 4:51 PM In reply to
    Keep the full P2 structure intact (including CONTENTS folder and lastclip.txt) file.
    Download and install the right Panasonic P2 AMA plugin for MC7 - I think you're probably OK with the latest one, 4.5.
    http://www.avid.com/US/products/Avid-Media-Access
    Link to the folder that HOLDS the CONTENTS and lastclip.txt items - one level ABOVE them.  Don't link to the CONTENTS folder itself.
    Clips should all appear in the bin.  You should then be able to consolidate or transcode to Avid-native media as desired.
    Dragging and dropping from Explorer or Finder into the bin triggers the "import" command, a legacy method that has largely been replaced by AMA (which is also known as "Link Media" from MC 8.4 onward).
  • Tue, Dec 15 2015 6:12 PM In reply to
    Many thanks usatraveler. I will do that Wednesday as IT have gone home and I don't have admin rights here. I''ll keep you updated.
    rory
    Filed under: ,
  • Tue, Dec 15 2015 6:13 PM In reply to
    Many thanks Pixel Monkey. I will do that Wednesday as IT have gone home and I don't have admin rights here. I''ll keep you updated.
    rory
  • Wed, Dec 16 2015 6:36 PM In reply to
    Cheers Guy,s Many thanks. Worked like you both said!
    I've now made some progress but still further problems with P2 files so doing more research and tests.
