Latest post Fri, Feb 5 2016 6:51 PM by AndrewAction. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Feb 5 2016 4:13 AM
    • marluc
    • New York State
    • Posts 362
    • Points 4,465
    Video noise reduction
    I have managed to import some footage from old 3/4" tapes into Media Composer.  It actually looks pretty good except for a lot of visual noise in very high color or dark areas.  Can anyone recommend a visual noise reduction plugin or app?
    marluc
    DESKTOP: 27" iMac/3.5GHz Quad Core i7/ 32 GB 1600 MHz DDR3, 8GB/1TBFlash Storage/NVIDIA GTX 780M 4GB, running OS X 10.9.2 and MC7.06. 1x 10TB Glyph... [view my complete system specs]
  • Fri, Feb 5 2016 3:47 PM In reply to
    • marluc
    • New York State
    • Posts 362
    • Points 4,465
    Re: Video noise reduction
    I'm bumping this.  Someobdy else must have experience with older video footage that has noise.  We used to be able to reduce it when editing from 3/4" to 1" tape, but that was back in the dark ages!  You'd think, in this super-digital time, that there would be something akin to what Photoshop has for images that could be applied to video.
    marluc
  • Fri, Feb 5 2016 3:48 PM In reply to
    Haven't used it, but there is a Noise Reduction plugin as part of Boris Continuum Complete.
  • Fri, Feb 5 2016 3:51 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,344
    • Points 159,265
    Sapphire , Boris or NeatVideo , not necessary in that order
    Tomas
  • Fri, Feb 5 2016 5:49 PM In reply to
    • marluc
    • New York State
    • Posts 362
    • Points 4,465
    I have downloaded Neat and will give that a try.  Other have recommended it too.
    Thanks.
  • Fri, Feb 5 2016 6:03 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,344
    • Points 159,265
    Neat should do the job well , the others are doing it to, different type of noise might need both differnt filters , settings and workflow and that´s the reason to why it´s hard to describe a solution that always works but Neat should be a good compromize doing it all in one step, you might want to look at the advanced settings once the filter is applied and configured, also a value above 65 - 70 might be recommended, if possible, when you are trying to find the correct noise profile.
    Tomas
  • Fri, Feb 5 2016 6:51 PM In reply to
    marluc:
    With HiBand UMatic here I have had some success MC's CC with reducing the overall saturation and then using curves to control the peak reds,  For the dark areas using curves to reduce the blue level in the shadows has helped me. (Resolve's NR does a better job if I have time)
