Latest post Sun, Sep 11 2016 9:58 AM by Mark. 38 replies.
Page 2 of 3 (39 items) < Previous 1 2 3 Next >
  • Wed, Mar 2 2016 11:18 PM In reply to
    • elracador
    • Joined on Thu, Aug 17 2006
    • Paris, France
    • Posts 72
    • Points 1,005
    Re: MC 8.5 Playback issue
    I have done as you said and the Console says nothing when the playback stops. No Message at all.
    What does it mean?
    If this can help  the playback issue only happens on Avid. No issues in FCP Pro or playing Quick time or VLC.
    M.C.8.4 HACK PRO i7 4.7 Ghz, 16Gb Ram, Avid Editing Drive: 4 TB Raid 0 (2 discs internal) , Nvidia GT 640 2 Go OSX 10.9.5 (on 128Gb SSD) [view my complete system specs]
  • Thu, Mar 3 2016 1:40 PM In reply to
    • elracador
    • Paris, France
    • Posts 72
    • Points 1,005
    I have decided to upgrade to Yosemite and the issue is still there but this time I am getting an Avid error message and the console is showing something.
    SCREENSHOT OF THE ERROR :http://postimg.org/image/8m1qogfof/
    CONSOLE MESSAGE:
    "[SWDecodeCvtr 0x7f84bf36dc00] AsyncExec::CheckIfReadyToExecuteByInput(sample 85, exec tag 807) - returning false
    PlayLoopThread::CheckForExceptions: Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
    Exception caught in APlayer::Play - Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
    Exception:
    @ Thu Mar  3 14:33:41 2016
    • Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
       Still waiting on input 0 (slot 0), state No Progress Made
    [VideoEffectConsumer 0x7f84bf3705f8] AsyncExec::CheckIfReadyToExecuteByInput(sample 85, exec tag 807) - returning false
    [FrameTransformationCvtr 0x7f84bb5c20c0] AsyncExec::CheckIfReadyToExecuteByInput(sample 990, exec tag 807) - returning false
    [StreamingPlayConsumer 0x7f84ba6c7978] AsyncExec::CheckIfReadyToExecuteByInput(sample 932, exec tag 749) - returning false
       Still waiting on input 0 (slot 0), state No Progress Made"
    I hope It will help
  • Thu, Mar 3 2016 3:13 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 725
    • Points 8,580
    @elracador:
    elracador:
    Ah! Now we're getting somewhere.
    StreamingPlayConsumer::ExecutePass TIMEOUT basically means your system can't keep up with Media Composer. Here are some common troubleshooting steps:
    1. Remove OpenIO_VirtIO.acf. Even if you don't use a breakout box, it's one more thing off the list. Step-by-step instructions are here:
    http://community.avid.com/forums/t/135998.aspx
    2. Media storage checklist:
    • Are you using separate storage for your media?
    • Is it a RAID, 0 or 5?
    • How is it connected? Thunderbolt? eSATA? USB 3?
    (Edit: if your system specs are accurate, you have an internal 4 TB RAID0. Nice.)
    3. Check your media storage for speed:
    • Use Blackmagic Disk Speed Test to see how fast your drives perform.
    https://itunes.apple.com/us/app/blackmagic-disk-speed-test/id425264550?mt=12
    Post a screenshot of the numbers.
    4. Is DaVinci Resolve 12 installed on this machine? If so, it would rescan drives every 5-10 minutes (almost on the button), dragging down drive performance. At least, it used to.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Demo ReelTwitter | Instagram | Vimeo
    Contributor: The Frame.io Workflow Guide - http://workflow.frame.io/
    Postproduction and Workflow Consultant - https://isaact.co/
  • Thu, Mar 3 2016 4:20 PM In reply to
    • elracador
    • Paris, France
    • Posts 72
    • Points 1,005
    1. Remove OpenIO_VirtIO.acf.= DONE ( Issue still there)
    2. Media storage checklist: All on the VIDEO DISK = 4 To RAID 0 ( 2x2To 7200 trs Seagate Barracuda)
    • How is it connected = SATA internal
    3. Blackmagic Disk Speed Test : DONE
    http://postimg.org/image/qab5ely8r/15e63d10/
    4. Is DaVinci Resolve 12 installed on this machine = NO
    Could it be the integrated Audio Card ?
    Do tou think it will be worth a try to use an external avid audio card ?
    I am really getting crazy on this.
  • Thu, Mar 3 2016 4:53 PM In reply to
    • Isaac T.
    • Posts 725
    • Points 8,580
    OOH! Just remembered: did you disable Fast Scrub?
  • Thu, Mar 3 2016 5:19 PM In reply to
    • elracador
    • Paris, France
    • Posts 72
    • Points 1,005
    I have just tried. Disabled Fast Scrub in the " Timeline" Settings and got the same
    issue.
  • Thu, Mar 3 2016 5:37 PM In reply to
    • Isaac T.
    • Posts 725
    • Points 8,580
    One last set of questions:
    1. What kind of a media are you playing back?
    • Codec - e.g. DNxHD? DNxHR?
    • Bitrate? - e.g. DNxHD 220? DNxHD 36?
    • Playback mode? - Yellow/Green mode? Green mode?
    2. Does this happen with clips in the bin, or in a multi-layered sequence?
    About the Hackintosh thing, I ran MC on Hackintosh's for years. So I'm not automatically going to that. But, like you said earlier:
    elracador:
    Same Ram and almost same everything. Only difference are
    OS, MOBO and CPU.
    it could be the integrated audio card.
    What happens if you open Console in MC and input this command after the exception?
    debugadm
    Tell you anything interesting?
  • Thu, Mar 3 2016 6:59 PM In reply to
    • elracador
    • Paris, France
    • Posts 72
    • Points 1,005
    Codec : DNxHD 36
    Playback mode it happens with any mode: full, half and low quality
    It happens on both clips and sequences
    I have typed you cmd in the COSOLE:
    "The CoreAudio Host Audio & 1394 Audio ADM is stopped. Pos 0 Susp. 0 Speed 1.000000
    The CoreAudio Host Audio ADM is stopped. Pos 0 Susp. 0 Speed 1.000000
    DIO meters okay, srate 48000, strmX 1
    The 1394 Audio ADM is stopped. Pos 0 Susp. 0 Speed 1.000000
    ADM debug value is 0"
  • Thu, Mar 3 2016 7:17 PM In reply to
    • Isaac T.
    • Posts 725
    • Points 8,580
    Sorry. I know this is frustrating. Would you be willing to try something else?
    1. Make a new project. Say 1080p @ 25fps? (25fps in France, right?)
    2. Transcode 1-2 clips in another codec, not DNxHD 36.
    3. Play a clip, see what happens.
    Also, when you go to System Preferences -> Sound, which device is selected for Output? If you have an Avid audio device (mBox preamp?), I'd give it a go.
    Would you be willing to attach your System Report? Kinda running out of ideas. (Sorry.)
  • Thu, Mar 3 2016 7:36 PM In reply to
    • elracador
    • Paris, France
    • Posts 72
    • Points 1,005
    Just to let you know.
    I have just grabbed a Mbox Pro 2 and set Audio in Avid to Mbox.
    The Issue is stille there.
    The strange thing about the Codec or the Project is that We have another Avid Station (hack on OS 10.8.5 with MC 8.4.5 same GPU but different Mobo and CPU ) and it works .
    So it can't be the reels.
    Where I find the system report ?
  • Thu, Mar 3 2016 8:01 PM In reply to
    • Isaac T.
    • Posts 725
    • Points 8,580
    To recap:
    1. Your media drive's fast enough.
    2. The GPU works on your other workstation with this media.
    3. You connected an Audio mBox device.
    4. You disabled Fast Scrub.
    5. You removed OpenIO_VirtIO.acf.
    6. You're using:
      • OS X - 10.10.5
      • MC - 8.4.5
    What's the Mobo model? Got a link to it?
    Or do you know the audio hardware? Did you need to patch AppleHDA.kext to get audio out? Does it work?
    (Sorry. Really grasping at straws here...)
  • Thu, Mar 3 2016 10:10 PM In reply to
    • elracador
    • Paris, France
    • Posts 72
    • Points 1,005
    First of all many thanks really for the help and energy you are putting into trying to solve this issue.
    I really appreciate.
    Answering your points:
    1. Your media drive's fast enough. = YES
    2. The GPU works on your other workstation with this media. = YES
    3. You connected an Audio mBox device. = YES
    4. You disabled Fast Scrub. = YES
    5. You removed OpenIO_VirtIO.acf. = YES
    6.   • OS X - 10.10.5 and 10.9.5 ( 2 SSD trying boths)
         • MC - 8.4.5
    MOBO = GA Z87 XUD3H bios F8
    CPU = i7 4970K
    I had to patch AppleHDA.kext to get audio out and it works so far with no issues ( beside Avid)
    but I have also tried with an external audio card Mbox Pro 2 and didn't change it.
  • Fri, Mar 4 2016 4:16 PM In reply to
    • Isaac T.
    • Posts 725
    • Points 8,580
    elracador:
    You're welcome!
    Here's another thought: its network connection. Is it connected over Ethernet? Wi-Fi? If Wi-Fi, can you disable it and try again?
  • Sat, Mar 5 2016 8:57 AM In reply to
    • elracador
    • Paris, France
    • Posts 72
    • Points 1,005
    Good Tought.
    The computer wasn't on internet neather connected to an ethernet.
    But I removed the ethernet kext and this didn't change the issue.
    I think I will buy a new mobo and give it  a try.
    It's my last resource. After that I will not know what to do.
    thanks for all . I'll let you know as soon as I have it done.
  • Mon, Mar 7 2016 2:58 PM In reply to
    • elracador
    • Paris, France
    • Posts 72
    • Points 1,005
    Here a little update:
    I have changed the Mobo: Now GA Z97 XUD3H ( intead of previous Z87)
    After the change the payback issue disappeared. but Now Avid is Crashing very often
    Heres the screenshot of the Avid errors
    http://postimg.org/image/rnws4zjsp/378ed9b9/
    http://postimg.org/image/faaxmaov1/293747ed/
    If someone can tell me what is producing the error.
    Thank you very much
    Any help is really appreciated.
