Latest post Wed, Jun 15 2016 10:35 PM by shcuts. 7 replies.
  • Thu, Mar 3 2016 5:40 AM
    • jaygon
    • Joined on Wed, May 2 2007
    • Sydney
    • Posts 63
    • Points 860
    Correct method for Duplicating a Sequence
    How do I duplicate a sequence?
    I thought I'd previously done this by simply right clicking the sequence in the bin and choosing 'duplicate' however this option isn't available (Perhaps I'm getting mixed up with FCP)
    Macbook Pro 2.9 GHz Intel Core i7 16GB RAM OS 10.12.6 Avid Media Composer 8.9.4 [view my complete system specs]
  • Thu, Mar 3 2016 7:26 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,387
    • Points 97,025
    Re: Correct method for Duplicating a Sequence
    Not in front of Avid right now, but I believe that you select the sequence you wish to duplicate in the bin and type Ctrl-D.
  • Thu, Mar 3 2016 8:19 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    jwrl:
    yes , and alt dragging to another bin does the same
    Tomas
  • Thu, Mar 3 2016 5:52 PM In reply to
    jaygon:
    I think this got lost with the MC 8.5 UI "improvements"
    As jwrl says Ctrl D still works in your bin. This is my preferred way as the duplicates name is selected and I can just type in a new name.
    Tomas's suggestion Alt drag to a different bin works but I probably do not want the duplicate to go to a different bin and I have to select the Duplicates name before renamimg
    Right Click in the Composer Monitor and choose Duplicate works and is great for having the duplicate immediately in the Composer window but then I have to be careful which seqence I carry on working with. Also I have to choose which bin and then the new sequence name before I can rename.
  • Thu, Mar 3 2016 9:43 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,572
    • Points 45,865
    The command is under Edit->Duplicate.
    Dave S.
  • Fri, Mar 4 2016 1:52 AM In reply to
    • jaygon
    • Sydney
    • Posts 63
    • Points 860
    Thanks for the reply's.
    But cntrl-D is certainly not working for me. The alt drag is a work around but kinda convoluted.
    Any suggestions why cntl-D isn't working? Just to clarify, I'm selecting my sequence in the bin, then pressing cntrl-D.
    Avid 8.5.0
  • Fri, Mar 4 2016 1:55 AM In reply to
    • jaygon
    • Sydney
    • Posts 63
    • Points 860
    SOLVED everyone.
    Apologies, I should have mentioned I was on a Mac. The shortcut is command-D (not cntrl-D.....I should have known!)
  • Wed, Jun 15 2016 10:35 PM In reply to
    • shcuts
    • Joined on Sun, Feb 12 2012
    • Posts 17
    • Points 175
    You're not getting mixed up with FCP. It does seem to have disappeared with the menu "improvements". command+d works fine for me but I did like the contextual menu option and hope it returns.
