Latest post Fri, May 25 2018 3:52 AM by Brian Berdan, ACE. 39 replies.
Page 1 of 3 (40 items) 1 2 3 Next >
  • Fri, Mar 11 2016 11:07 AM
    Record Monitor not updating while trimming in MC 8.5 or 8.5.1
    I'm having problems with my record monitor not updating while trimming in jkl mode or frame by frame. This is happening with a (realtime) mask effect on the top layer for a 1:2.35 mask. MC 8.4 works fine...
    Target masks isn't an option, because of my blackmagic output (only shows on Avid hardware).
    Anyone experiencing the same?
    Jasper
    Mac Pro late 2013 3,5 Ghz 6-Core, 64Gb, OSX 10.10.5, Avid MC 8.4, Blackmagic Ultrastudio Express Macbook Pro retina 2012 15 inch i7, 16Gb, OSX 10.10.5... [view my complete system specs]
  • Fri, Mar 11 2016 3:37 PM In reply to
    Re: Record Monitor not updating while trimming in MC 8.5 or 8.5.1
    Do you have Composer > Render on the Fly and Settings > Trim > Features > Render on the Fly both checked?
  • Fri, Mar 11 2016 3:43 PM In reply to
    Hi Kevin,
    Thanks for the suggestion. Yes, both checked, but no luck.
    Can you try to reproduce my problem?
  • Fri, Mar 11 2016 3:47 PM In reply to
    There have been reports of intermittent montior updating issues with trimming. For me, it appears more frequently when I am slipping and sliding tracks.
    At this moment, my system is not replicating your issue.
    Do you see a difference when you monitor the mask and when you don't?
  • Fri, Mar 11 2016 3:59 PM In reply to
    Yes, when i disable the top layer with the mask the viewers are updating fine.
    I tried it on several projects, user settings and even systems. But they all have the same problem with MC 8.5
    Another weird this is when I jkl-trim on the left side it displays my sequence instead of the rest of the clip (with mask monitoring).
  • Fri, Mar 11 2016 4:01 PM In reply to
    I tried slipping and sliding, but that's not updating either as you mentioned Sad
  • Fri, Mar 11 2016 4:37 PM In reply to
    For fun, can you try restarting the computer? As I've said, it seems to come and go, and right now I can't replicate it, but I know tomorrow might be another thing.
    Just curious if a full reboot makes it disappear for a while.
  • Sat, Mar 12 2016 9:41 AM In reply to
    With me it doesn't come and go. The problem always exsits on both vesions of the software and on both systems. Weird that you can't replicate it. Maybe it's because I'm still on OSX 10.10.5?
  • Sun, Mar 13 2016 7:10 AM In reply to
    I also get the error when in slip mode with trimming if I have a mask (2.35) on the top layer across the cut. Monitor doesn't update in real time at all. Can't see the edit, just get the first incoming frame of the next shot displayed.
    If I change the monitor to the layer beneath the mask then trim mode works correctly.
    I also use 10.10.5, AVID MC 8.5.1
    MAC - AVID 8.5.1, OS X 10.10.5, iMac 2011, 8 GB ram, Blackmagic Thunderbolt Express | PC = AVID 8.2, Windows 7 HP Z420 Workstation, 16 GB ram
  • Tue, Mar 15 2016 8:12 AM In reply to
    Thanks Simon for letting me know I'm not the only one.
    Can anyone else reproduce this so we can escalate it to Marianna/AVID?
    In the meantime I will try to update to Mavericks, maybe that helps since Kevin doesn't have this problem.
  • Sun, Mar 20 2016 6:31 PM In reply to
    • jdrouette
    • Montréal, Canada
    • Posts 415
    • Points 5,440
    I can confirm this as well. My monitors take a few seconds to update in Trim Mode and JKL trimming becomes practically useless since I can't see the I/O frames.
    The problem is consistent on m system whether I'm using my UltraStudio Express or not or have a target mask on or off.
    Marianna, PLEASE look into this. It's a workflow killer for many of us. Thank you!
    Avid Media Composer 2019.12 Symphony option, Avid Artist DNxID (DNxID Desktop Video Application v11.5), macOS 10.14.6, iMac Pro (2017) 10-Core, 3.0GHz... [view my complete system specs]
  • Wed, Mar 23 2016 7:26 PM In reply to
    • jdrouette
    • Montréal, Canada
    • Posts 415
    • Points 5,440
    Well, I figured out the problem on my system: the monitor update delay was being caused by a lower third graphic on V2. If I monitor only the track with straight video, JKL trimming behaves normally. The guess MC couldn't update screen properly in Slip/Slide mode with the alpha channel graphic.
    Live and learn.
  • Wed, Mar 23 2016 8:33 PM In reply to
    That's not normal behavior, is it? Until 8.4 this wasn't a problem, it's a real time effect.
  • Wed, Mar 23 2016 8:36 PM In reply to
  • Thu, Mar 24 2016 2:17 AM In reply to
    • jdrouette
    • Montréal, Canada
    • Posts 415
    • Points 5,440
    Jasper Quispel:
    I don't remember it being a problem before, no. I was beginning to question my memory. I can't roll back to compare now that I've upgraded to El Capitan.
