Latest post Mon, Apr 11 2016 2:37 PM by Michael from cologne. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Apr 5 2016 10:35 AM
    serious performance problem after update 8.5.1
    I've updated to 8.5.1 from 8.4 or 8.3 (can't really remember). Suddenly I can't playback Multicams (Group Clips) even with only three cameras in the quadsplit.
    Never had issues of these kind before!
    Can anybody help? Thanks,
    Michael
    MC 8.8.5, WIN 10 x64, HP z840, dual E5-2640v3 2.6Ghz, 8x4GB RAM, Nvidia Quadro M4000, MXO2 LE, Artist Mix [view my complete system specs]
  • Tue, Apr 5 2016 10:38 AM In reply to
    Re: serious performance problem after update 8.5.1
    add information:
    the musltcam playback starts, but stops after a couple of seconds randomly without error message. sometimes Avid including the mouse freezes for a couple of seconds.
  • Tue, Apr 5 2016 11:05 AM In reply to
    • n3bur
    • Joined on Wed, Jun 3 2015
    • Brussels
    • Posts 26
    • Points 315
    I also experienced random playback stops recently. In my case it turned out to be the system drive not having enough free space. You really need more than a few GBs.
  • Tue, Apr 5 2016 11:15 AM In reply to
    ive got more than 50gb free on C, should be enough??
  • Tue, Apr 5 2016 1:02 PM In reply to
    Create a new user to see if it makes a difference and make sure you have the correct nvidia driver.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Tue, Apr 5 2016 1:48 PM In reply to
    I just downgraded to 8.4.5 and all is working without problems again. Seems to be a performance/compatibility issue of 8.5.1 ???
    Anybody shares the same experience?
  • Tue, Apr 5 2016 4:35 PM In reply to
    worked for 3 hours in a row without problems on 8.4.5!
    So is anybody else encounting performance problems with multicam clips in 8.5.1 and having an ideo to solve this?
    Or do I really have to buy a new PC to take advantage of avid beyond 8.4.5...
    Michael
  • Tue, Apr 5 2016 4:50 PM In reply to
    Are you storing your media files on your system drive?  If so, that doesn't sound like a good idea at all - the system is trying to pull all system commands, from all programs, PLUS three streams of multicam media, from the same drive, all at the same time.
    And what kind of media is it?
    Regardless, still not sure why you're seeing a performance difference between 8.4.5 and 8.5.1.
  • Tue, Apr 5 2016 7:34 PM In reply to
    certainly the media files come from a different fast raid drive. they are dnxhd 85 or 120 but that really does not matter. as I wrote there are absolutely no problems in mc 8.4.5. the problem occurs only with mc 8.5.1...
    thanks for help,
    michael
  • Mon, Apr 11 2016 2:37 PM In reply to
    it looks like 8.5.2 has solved my problem - performance is back and nearly as good as in 8.4.5.
    Cheers
    Michael
