Latest post Wed, Aug 3 2016 12:44 PM by Marianna. 10 replies.
Page 1 of 1 (11 items)
  • Sat, Apr 23 2016 7:08 PM
    • Rabotti
    • Joined on Thu, Nov 6 2008
    • Munich
    • Posts 18
    • Points 210
    Activation required after application crash
    Today I activated my copy of MC 7 on my Laptop. I sometimes do that when I do not work at home. Everything worked fine in the beginning. When I left the application after some two hours work, it crashed. I did not care, because AVID crashes often when quitting, and turned the computer off. When I wanted to resume work a couple of hours later, MC suddenly told me that it wasn't activated. Then a message came up telling me that there was a problem in the licensing engine and I was told to delete some files. When I then tried to reactivate the software I got the response, that I wasn't able to activate two copies. What can I do? I'm in a kind of hurry as there are projects to finish. Any help would be much appreciated. Thanks! Ralf.
    PC WIN 7(64 Bit), XW8600, 2 * XEON x5460 @ 3,16 Ghz, 16 GB RAM, MC 7.0.4, NVidia Gforce GTX 760 [view my complete system specs]
  • Sat, Apr 23 2016 7:18 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,814
    • Points 20,015
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Activation required after application crash
    Hello Ralf,
         Send me a pm with your Avid master account email address and MC systems ID, I will sort this out for you.
    Regards,
    Ralph
  • Tue, Apr 26 2016 4:01 AM In reply to
    • Rabotti
    • Munich
    • Posts 18
    • Points 210
    Hi Ralph,
    did you get my message from yesterday?
    Ralf.
  • Tue, Apr 26 2016 1:48 PM In reply to
    • RalphC
    • Posts 1,814
    • Points 20,015
      Avid Employee
    No, I did not, can you email me raff.condalor@avid.com
  • Tue, Apr 26 2016 8:32 PM In reply to
    • RalphC
    • Posts 1,814
    • Points 20,015
      Avid Employee
    Hello Ralf,
     I got your PM, I've taken care your activation status, you should be good to go.
    Regards,
    Ralph
  • Wed, Apr 27 2016 6:35 AM In reply to
    • Rabotti
    • Munich
    • Posts 18
    • Points 210
    Ralph, thanks so much! Everything works again - great.
    Is there anything that I could do to prevent this from happening again?
    All the best!
    Ralf.
  • Sat, May 7 2016 6:20 PM In reply to
    • RalphC
    • Posts 1,814
    • Points 20,015
      Avid Employee
    Rabotti:
    All the best!
    Ralf.
     Be sure to deactivate first your MC when you plan to activate to other computer.
    Regards,
    Ralph
  • Mon, Aug 1 2016 8:58 PM In reply to
    • Rabotti
    • Munich
    • Posts 18
    • Points 210
    Hi Ralph,
    sorry to bother you again - but it happened again, although I did not do anything wrong; It was exactly like last time: I sometimes have to deactivate Avid 7.0.4 on my big machine to use it on my laptop when away. It works perfectly well, apart from activating obviously.
    On Friday I deactivated MC on the Win 7 Pro PC, and then activated it again on the Win 8.1 Laptop - everything was normal - I got a success message from License Control when deactivating and when activating again. I could work the whole day through. Then I switched off the laptop and wanted to resume work on the same machine on Saturday morning. I started MC and got the following message: "There was an error initializing the licensing engine" - it also told me to delete the folder SystemDrive/ProgramData/Avid/Licenses. I did this and ended up in a vicious circle. Because after deleting the folder, I had to activate the license again, but when I try this the system keeps telling me "101 Activation failed. 20062: Add-on "XXXX-XXXX-XXXX-XXXX" cannot have more copies assigned than total available. But there are no copies activated right now.
    I really want to understand the mistake - or is it just a bug. Do I have to do something differently? This happened three times now and always in the middle of a project. I would be really thankful if you could help me once more. And maybe you have an idea to prevent this in the future.
    Sorry & thank you very much.
    Ralf.
  • Tue, Aug 2 2016 3:34 PM In reply to
    • RalphC
    • Posts 1,814
    • Points 20,015
      Avid Employee
    Hello Ralf,
      I deactivated the license.
    Regards,
    Ralph
  • Wed, Aug 3 2016 8:07 AM In reply to
    • Rabotti
    • Munich
    • Posts 18
    • Points 210
    Hi Ralph,
    thanks a lot - again!
    A coworker suggested to reinstall MC once I get the "There was an error initializing the licensing engine"-message, instead of deleting the License-Folders. Is this something you would recommend traying once it happens again?
    All the best!
    Ralf
  • Wed, Aug 3 2016 12:44 PM In reply to
    • Posts 10,160
    • Points 217,415
    I would try that - uninstall, reinstall - but make sure you also delete the licensing folders as well that time in case they are causing the app to get wonky in some way
