Latest post Thu, Jun 21 2018 7:47 PM by Telegram!. 12 replies.
Page 1 of 1 (13 items)
  • Wed, Jun 15 2016 8:45 PM
    • yon1
    • Joined on Sat, Apr 15 2006
    • Posts 317
    • Points 4,540
    Sorenson Squeeze 11 - creating mxf files
    Sorenson Squeeze 11 has the capability of creating a directory with files that can be directly dragged into the
    E:\Avid MediaFiles\MXF\1 folder, this means that you can prepare files for import outside of MC - cool - right ?
    Well almost. The problem is that sometimes it doesn't work, when you try to play a clip that was imported this way you get an error "PMM_INSUFFICIENT_MEDIA() Player Version of frame duration is longer than actual [7464] (7464)
    When I examine the media files and clip in the media tool I see that the clip duration is one frame larger than the media duration - so I can understand the error.
    The big problem is that when I approached Sorenson, they said that my version of MC is old (true) and they don't support it. I gave them access to the files and asked them to try it on whatever version of Avid they test on - but for some reason, they ignore my request and give me a link to Avid support.
    So now I'd like your help
    Can someone please spend a couple of minutes doing this in the V8 and tell me if they have the same problem ?
    1) Copy the files from the link below into an empty folder e.g. \Avid MediaFiles\MXF\9999   (203MB)
    https://www.dropbox.com/sh/iuvotpf0cv9c2bo/AACSWhYwxHTQf9NaNI9xdySCa?dl=0
    2) Open Avid, and then open Tool/Media tool select the drive where you put the mxf files and "current project"
    3) In mediatool you will see 4 files that start with 201604041. Double click the clip file 20160404141024_DNxHD_185 and see if it will playback or if you get an error PMM_INSUFFICIENT_MEDIA....
    4) Another thing you can check is to see if the values of the "Duration" column. In my case the 3 media clips have a  duration of 9:03, and the clip has a duration of 9:04 (one frame off)
    5) Delete the files you added in \Avid MediaFiles\MXF\9999
    6) just in case - If you have any problem with Avid after this then you should delete the msmFMID.pmr and msmMMOB.mdb in all the MXF directories and restart Avid
    7) tell us what happens
    Many Thanks
    Yonatan
    MC 5.04 windows 7, Core i7 CPU, MoBo Asus P6X58D , 6GB RAM, Quadro 2000D, 512GB & Raid 0 1TB, [view my complete system specs]
    Yonatan
  • Thu, Jun 16 2016 4:23 PM In reply to
    • yon1
    • Posts 317
    • Points 4,540
    Re: Sorenson Squeeze 11 - creating mxf files
    Let me ask a different question
    Is anyone using squeeze to generate MXF files ?
    Does it always work, or has anyone seen the problems I've described below ?
    Yonatan
  • Fri, Jun 17 2016 6:36 AM In reply to
    I encountered the same problem when transcoding AVCHD clips to DNxHD.  The video ended up being a frame longer than the same clip imported into Avid, and the audio didn't quite match.  Consequently, I don't use Sorenson Squeeze anymore for creating rapid-ingesting Avid media.  Instead I use ClipToolz Convert (version 2, which is free).  It's much faster, has a filter for deinterlacing, and preserves timecodes and reelnames.  HD Cinematics just released Convert V3, which has a stabilizer module, direct Blu-ray burning, and 4K support, among many other features.  It can even convert 5.1 channels from stereo.  Not bad for a $49 program that is Windows 10 compatible:
    http://hdcinematics.com/Convert-V3.html
    Media Composer 2019.12 w/Symphony | OS X 10.14.6 | iMac 2017 (Retina 5K, 27-inch, 2017) 4.2 GHz Intel Core i7 | 40 GB 2400 MHz DDR4 | TerraMaster 16TB... [view my complete system specs]
  • Fri, Jun 17 2016 3:01 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,410
    • Points 15,525
    Hello,
    I tested clip in MC8.4.2. Is playing ok. Only the last two frames shows "Media Offline".
    9:04 clip length.
    V.
    AVID MC2019.11 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 441.28, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Fri, Jun 17 2016 3:58 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,633
    • Points 66,110
    Hi, tested on 8.5.3, Avid scans the media files and quarantines two files out of four, the clip shows up un the media tool as video offline, two channels of audio, duration is reported as 9:04. Switch Media Player refuses to play the files.
    Symphony 19.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Fri, Jun 17 2016 4:54 PM In reply to
    • jcfrance
    • Joined on Wed, Apr 21 2010
    • Posts 31
    • Points 300
    Same here : tested on 8.5.3
    Import AAF => only 20160404141024_DNxHD_185
    track V1 A1-2
    Start 00:00:00:00
    Duration 9:04
    audio 48000
    Last 2 frames are offline
    - double click on clip send to source viewer and create an empty TL Untitled Sequence.01
    Insert button
    Same result :
    V1 video
    A1/A2 audio channel but no sound
    Test with Davindi Resolve : same results.
    1 video 201604041V01C1E0D997.mxf
    2 audio channel A1 and A2 are -50db
    A1=201604041V01C1E0D998.mxf
    A2=201604041V01C1E0D999.mxf
    Duration 9:04
    I use Squeeze + MXF plugin from the V9 and I never had a problem..
  • Sat, Jun 18 2016 8:58 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    jcfrance:
    Same for me but with Squeeze Pro 11 , maybe it´s the source media , have you tried with other media , pick a short one to make sure that the issue not is related to spanned clips
    Tomas
  • Mon, Jun 20 2016 7:51 PM In reply to
    • yon1
    • Posts 317
    • Points 4,540
    This is only a 9 second clip. Creating a .mov in squeeze worked fine.
    It happens on about 50 % of my (Canon) .mte files.
    I reckon it's a bug in squeeze and that different versions of MC have different ways of dealing with it.
    I got someone in in Sorenson QC to check it out, the reply was 'I did notice the slight discrepancy between the length of the audio and video files, but that is expected when encoding, and isn't affecting performance. That t/100 second difference isn't enough to make the file import invalid. "
    I suppose that's a matter of opinion, I would expect both the audio and the video to round down to a common duration. The way it  forces me to clip the length - or in my V5 MC - not to use MXF creation.
    Yonatan
  • Tue, Jun 21 2016 5:38 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    You told that you used the media tool to bring the files in separately , what happens if you instead import the aaf that Squeeze creates to bring the media in as a clip
    Tomas
  • Thu, Jun 21 2018 4:18 PM In reply to
    • Michael Watts
    • Joined on Tue, Sep 15 2015
    • Alexandria, VA
    • Posts 5
    • Points 65
    Does anyone know if there is something like the HDCinematics converter for Mac?  Having a tough time figuring out a converter that can create DNxHD .mxf files on Mac.  Thanks.
    2019 27" iMac Retina 5K 3.6 GHz Intel Core i9 128 GB Ram 2667 MHz DDR4 Radeon Pro Vega 48 8 GB [view my complete system specs]
  • Thu, Jun 21 2018 7:22 PM In reply to
    I use Squeeze to MXF here and there. not with Canon media though. Did you try background Link/Transcoding within MC?
    Squeeze v11 eol Pro AJA i/o Express Ignite FX; Plural Eyes 4.0 HitFilm Pro; Windows10 Pro x64 Dell XPS 8930 Special Edition Tower i7-8700 3.2... [view my complete system specs]
  • Thu, Jun 21 2018 7:31 PM In reply to
    • Michael Watts
    • Alexandria, VA
    • Posts 5
    • Points 65
    Thanks.  Background transcoding is great when it works but I find it pretty unreliable, and my version of Squeeze is older so it doesn’t have the .mxf option, at least not that I can find.  And of course, to further complicate matters, most of my media is Canon.
  • Thu, Jun 21 2018 7:47 PM In reply to
    I don't know if this will help but video toolshed is a great resource
    https://www.videotoolshed.com/product/avid-mxf-creator/
    not for sale but demo version seems full featured.. or ask there for MAC-based ideas?
