Latest post Mon, Nov 21 2016 8:43 PM by Kevin Klimek. 32 replies.
Page 2 of 3 (33 items) < Previous 1 2 3 Next >
  • Thu, Aug 11 2016 4:41 PM In reply to
    Re: Media Composer v8.6 | NOW AVAILABLE
    Hi Kevin,
    This how my App Man looks like: (see attached pic)
  • Thu, Aug 11 2016 4:56 PM In reply to
    Hi Kevin,
    This is what my App Man looks like at the moment:
  • Thu, Aug 11 2016 5:25 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,123
    • Points 23,615
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hi Bart,
       Try cleaning the AppMan Cache files, select the arrow down upper right of the AppMan>Adminstration> Restart AppManhelper followed by Clean cache file.
    Regards,
    Ralph
  • Thu, Aug 11 2016 5:59 PM In reply to
    Hi Ralph,
    Tried it, didn't help, after re-initialising App Man still looks the same....
    Could you guys check if there's something going on with my account? Don't understand why it doesn(t state there's an update.
    kind regards
    Bart
  • Thu, Aug 11 2016 7:12 PM In reply to
    • RalphC
    • Posts 2,123
    • Points 23,615
      Avid Employee
    I checked your Avid master account your MC license is Time Period: Dec 29, 2014 - to - Dec 28, 2016
    And you have 8.6.1 in your downloads. Since reset thru the Appman does not work, can you try these steps a try..
    1. Quit Application Manager from its menu-bar icon at the top of the screen.
              a. Go to MacHD > Applications >Utilites > and open 'Activity Monitor'.
              b. In the activity monitor interface, select the Process Name ‘AvidAppManHelper’ from the column on the left-hand side, Then click the ‘X’ button at the top left to quit the process.
    You should no longer have any ‘Avid Application Manager’ related processes in the ‘Process Name’ column of Activity Monitor.
    2. Delete the following folders:
               HD/Library/Caches/Avid/AppManager/Cache
               HD/Library/Caches/Avid/AppManager/Db
               HD/Library/Application Support/Avid/Licenses
    3. Now once again go to Go to MacHD > Applications > Avid > Application Manager, but this time, double-click on the ‘AvidAppManHelper.app’ file and wait for it to appear in Activity Monitor’s Process list to ensure it’s started.
    4. Restart Machine and launch AvidApplicationManager.app and then re-enter my Activation code and my System ID.
     Resetting Appman does not help pm your systems ID and Avid master account email.
  • Thu, Sep 1 2016 8:46 PM In reply to
    • biegert
    • Posts 19
    • Points 245
    Not sure if I'm posting this in the right place.
    I have a perpetual license with an active support contract expiring in 2017. I just attempted to upgrade to 8.6.1 from 8.5. When I attempt to launch MC, I get the message "This software was released past your contract expiration date."
    Any suggestions for how to fix this?
    T
  • Sat, Sep 3 2016 1:25 PM In reply to
    • RalphC
    • Posts 2,123
    • Points 23,615
      Avid Employee
    Hello biegert,
        Installed the latest AppMan version, after upgrade clear the cache files.
    Regards,
    Ralph
  • Wed, Oct 19 2016 8:08 PM In reply to
    • Jim Allan
    • Joined on Mon, Jun 7 2010
    • Oakville, Ontario, Canada
    • Posts 100
    • Points 1,110
    I was one of the few who manually downloaded 8.6.2 and it worked fine, so I left it alone. Last night the old title tool started acting up (couldn't edit existing files) and so today I uninstalled everything and jumped up to 8.6.3. However, the installer would fail 90% of the way through the process. Had support on board for five hours of remote access, and they went through the work arounds described in this thread, with no success. Even set up a new User Profile.
    Any advice would be appreciated ...
    MC v2019.12 with Phrase Find on a 15" MacBook Pro (2017). OS Mojave v10.14.6, 3.1 GHz Intel Core i7. 16GB 2133 MHz LPDDR3. Radeon Pro 560 4096 MB... [view my complete system specs]
  • Thu, Oct 20 2016 12:35 PM In reply to
    • Jim Allan
    • Posts 100
    • Points 1,110
    Re: my post directly above: I've copied and pasted the "Installer Log".
    Perhaps someone more computer literate than I am can spot a clue:
    Oct 20 08:29:36 Jamess-MacBook-Pro installd[857]: PackageKit: ----- Begin install -----
    Oct 20 08:31:37 Jamess-MacBook-Pro installd[857]: PackageKit: Skipped locking com.avid.mediacomposer because LaunchServices couldn't find it: Error Domain=NSOSStatusErrorDomain Code=-10814 "kLSApplicationNotFoundErr: E.g. no application claims the file"
    Oct 20 08:31:37 Jamess-MacBook-Pro installd[857]: PackageKit: Install Failed: Error Domain=NSPOSIXErrorDomain Code=1 "Operation not permitted" UserInfo={NSFilePath=/private/tmp/PKInstallSandbox.XXXXXX} {
       NSFilePath = "/private/tmp/PKInstallSandbox.XXXXXX";
    Oct 20 08:31:39 Jamess-MacBook-Pro Installer[1401]: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
    Oct 20 08:31:39 Jamess-MacBook-Pro Installer[1401]: Displaying 'Install Failed' UI.
    Oct 20 08:31:39 Jamess-MacBook-Pro Installer[1401]: 'Install Failed' UI displayed message:'The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.'.
  • Mon, Oct 24 2016 3:51 PM In reply to
    Did you download the installer or use AppMan?
  • Mon, Oct 24 2016 4:52 PM In reply to
    • Jim Allan
    • Posts 100
    • Points 1,110
    I went thru AVID support, and it was escalated a level.
    It may have been a problem with my O/S.
    Eventually, I did a full restore from my Time Machine overnight. MC 8.6.2 worked fine. A weird glitch I was experiencing within the old Title Tool seemed to be gone.
    Confident that I could restore everything to 8.6.2, I downloaded and successfully installed 8.6.3 through the Application Manager. Note: I did this WITHOUT un-installing my existing version.
    So, not sure why, but everything seems to be working fine.
  • Sun, Nov 20 2016 9:24 AM In reply to
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 318
    • Points 4,230
    Please, could somebody post here a readme file for MC 8.6.5 which is just became available in trial section of downloads.
    thank you.
    my zoo: NEXIS Pro 40 tb sw v19.12.0.5; MBPro_late_2013 15'' i7 16GBram OSX 10.15.3 MC 2020.1 BMD US monitor (or AJA io XT ), ATTO NT11;Baselight... [view my complete system specs]
    DJFio[DB]
  • Sun, Nov 20 2016 11:59 AM In reply to
    That'd be nice but I only see 8.6.4.
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2019.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Sun, Nov 20 2016 12:08 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 318
    • Points 4,230
    Very strange. It is there -  on the mc-trial page.
    Maybe country-dependent site?
    DJFio[DB]
  • Sun, Nov 20 2016 12:55 PM In reply to
    • Florian
    • Germany
    • Posts 334
    • Points 4,190
    found it over here:
    http://www.avid.com/mc-trial
    MacBook Pro Retina 15", 2.5Ghz QuadCore i7, OS Catalina 15.1, Avid MC 2018.5, 16GB Ram, AMD Radeon R9 M370X [view my complete system specs]
