Latest post Fri, Aug 10 2018 5:47 PM by Marianna. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Aug 4 2016 8:15 PM
    • Mark J
    • Joined on Wed, Aug 3 2016
    • Los Angeles
    • Posts 4
    • Points 70
    Weird export issue. H.264 export
    Hello Avid world,
    So I am having the issue of exporting my 8 minute sequence out of Avid. It is only taking about 5mins to export. My issue is why does it keep re exporting by its self. Is that somekind of bug that needs to be fixed in the next update? I am guessing the only work around is the export qt reference at this point and make it a solid file using Mpeg stream clip or something equivalent to it.
    Anyone else having this issue. I can't seem to wrap my head around this.
    Mac Pro (Late 2013) 3.7 GHz Quad-Core Intel Xeon E5 12 GB 1866 MHz DDR3 ECC AMD FirePro D300 2048 MB [view my complete system specs]
    P.V. Productions
  • Thu, Aug 4 2016 8:33 PM In reply to
    Re: Weird export issue. H.264 export
    Welcome to the forums...
    We need more information, and it's helpful if you update your profile to include your systems specs. What version of MC / OS?
    In addition, what kind of media are you using in your timeline? Linked or Avid media?
    If you export "Same as source" does this export loop occur?
    ALSO, in your export settings, are you using multi-pass? Each time the bar completes is a single pass, so you will see that happen mutliple times.
  • Thu, Aug 4 2016 8:52 PM In reply to
    • Mark J
    • Los Angeles
    • Posts 4
    • Points 70
    I updated all the goods. So to answer your question the export finished. I am using the most recent Avid software, nothing is linked ( thank goodness) all avid files. So what is weird is, Im not sure if this is new for Avid export but it loops like 3 times and then does the final Making movie to complete the file. Just bizzare how it takes 3 loops to export an H.264.
    I have a feeling this problem will occur more then once.
    P.V. Productions
  • Thu, Aug 4 2016 9:00 PM In reply to
    Kevin Klimek:
    Then that is it.
    Open your export setting, then Format Options, then under "Video" select Settings. In the lower-left corner of the Settings box, you probably have Best Quality (multi-pass) selected, instead of Faster Encode (single pass).
    There's nothing wrong with leaving it the way you have it, but understand what is happening is supposed to happen. The encoder is analyzing the footage several times and determing the quality needed at each particular moment to keep the quality up and the file size down.
  • Thu, Aug 4 2016 10:20 PM In reply to
    Kevin is correct - a multi-pass encode will make multiple passes.
    That said - Avid is not a very efficient H.264 encoder.  Generally, once all the media in your sequence is Avid-native media, it's best to output a QuickTime Reference, and then encode your H.264 using a third-party program.  Sorenson Squeeze is an option that comes with the "subscription" (not perpetual with support) version of MC.  There's also Apple Compressor, and multiple other ones that do a good job as well (careful of shady ones though).  The added benefit of this is that once the file is out of Avid, it frees you up to continue editing while the other software does the encode.
  • Tue, Oct 3 2017 7:12 PM In reply to
    • Seibel
    • Joined on Wed, Dec 18 2013
    • Los Angeles
    • Posts 22
    • Points 230
      Avid Certified User
    Exporting with multipass selected doesn't go through a status bar multiple times, it just estimates a longer time.  It will estimate a 10 min time to finish versus a 5 min estimate.  It doesn't finish and then start over again.
    I'm having this same issue.  The correct estimated time is shown and it finishes and then just loops around again and starts over again.  If you cancel it's as if you didn't finish exporting and there's nothing left at the end.  I'm able to export a Same As Source quicktime (and AAFs but that's different), but I can't do an H264 export from Avid 8.8.5.  We are on Mac OSX 12.12.6 Sierra and I'm exporting to the desktop.  The Avid media is transcoded and we are working off an ISIS.
    Anyone else figure this out?  Super annoying.
  • Wed, Oct 4 2017 9:27 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Aberystwyth, Wales
    • Posts 436
    • Points 5,040
      Avid Certified User
    I've never had good results getting h264 out of avid (at leats with any sequence over ~5mins). I'd always do a QTref or SaS and then convert in MPEGStreamclip/Compressor/Reolve etc.
    MC Symphony 8.8.5 on MacPro 3GHz 8-Core Xeon 12GB RAM, OS 10.12.6, Blackmagic Ultrastudio 4K MC Symphony 8.8.1 on iMac [view my complete system specs]
  • Tue, Oct 10 2017 11:34 PM In reply to
    • Seibel
    • Los Angeles
    • Posts 22
    • Points 230
      Avid Certified User
    2017 and Avid can't handle an H264 export, which every TV show uses to send cuts out.
  • Wed, Oct 11 2017 1:43 PM In reply to
    • Posts 10,018
    • Points 215,705
    Seibel
    MC 8.9.1 added ---  H.264 (.mov and .mp4) support.   I assume you are on 8.9.1 or higher?     In MC 8.9.2 - a bug was fixed that in some instances, would cause transcoding long H.264 media using the Avid Generic plugin resulted in an exception error.
    Are you able to update?
  • Thu, Nov 9 2017 5:14 PM In reply to
    • iliagin
    • Joined on Tue, Oct 17 2017
    • Posts 4
    • Points 50
    I'm running 8.9.2 and I've the same issue with different projects while exporting in different formats.
  • Tue, Aug 7 2018 1:49 AM In reply to
  • Fri, Aug 10 2018 5:47 PM In reply to
    • Posts 10,018
    • Points 215,705
    added work was done in 2018.x - specifically 2018.8 coming soon.
    Bug Number: MCCET-2513. (Mac) You might have received an “Exception: std::exception” error when transcoding spanned AVCHD clips.  FIXED
