Latest post Thu, Oct 13 2016 5:29 PM by Frédéric. 7 replies.
  • Tue, Aug 16 2016 10:19 AM
    • Frédéric
    • Joined on Mon, Jan 26 2015
    • Posts 6
    • Points 70
    MFX OP1a transcoded with adobe media encoder
    Hi
    I transcode a lot of footage with media encoder CC 2015.
    When I try to AMA link MXF OP1a transcoded with media encoder in Media composer 5.5.5 I have no sound.
    I have 8 mono empty tracks with no sound Hmm
    I have tried to AMA link with Media composer 8.5 and it works great.
    I run the last version of AMA MXf plugin (1.4.1)
    Does anybody have encountered this issue on media composer 5.5.5 ?
  • Tue, Aug 23 2016 6:39 PM In reply to
    Re: MFX OP1a transcoded with adobe media encoder
    What codec is the video and what is the audio format (bit rate, bit depth, etc.)?
  • Tue, Sep 27 2016 1:51 PM In reply to
    • Frédéric
    • Posts 6
    • Points 70
    Hi
    sorry to take so many time to reply
    I invistaged a little bit more and tried many setting in media encoder.
    Forget about the sound issue, It seems that the MXF OP1a genereted by media encoder CC 2015 is not compatible with the AMA MXF plugin ver 1.4.1 (Which is the last update for Media composer 5.5.5).
    it gives me error when I tried to AMA link.
    it works fine on Media composer 8.5
    Does anybody has the same issue on media composer 5.5.5 ?
    Is there any trik to go arround this issue ?
    thanks
  • Wed, Sep 28 2016 10:33 AM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 185
    • Points 2,040
    In the video tab in media encoder there is a section called Advanced MXF Settings. Try to set Edit Units Per Partition to Custom: 240.
    I don't know exactly what that means but it works here ;-)
    Media Composer 2018.12.5 - Windows 10 - Dell 8520 - Blackmagic Decklink Studio 4K - Interplay and NEXIS storage - Avid Artist Color. [view my complete system specs]
    Kåre Nejmann
    Danish Broadcasting Corporation - DR
    Aarhus, Denmark
  • Fri, Sep 30 2016 10:03 PM In reply to
    • keinan
    • Joined on Thu, Jun 23 2011
    • Posts 33
    • Points 430
    Im sorry but i cant find that section in AME cc2015
    In video settings, there is only aspect ratio, fps and field type using "Avid native MXF" preset...
    Can u tell us more infor about it?
    Thanks in advanced!
  • Mon, Oct 3 2016 4:09 PM In reply to
    • Frédéric
    • Posts 6
    • Points 70
    No, you're right there is a setting called Edit Units Per Partition but it's already set to default 240 :(
  • Thu, Oct 13 2016 12:36 PM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 185
    • Points 2,040
    Have you tried setting it to custom? I'm sure that the number 240 has no effect when Default is selected.
    Try to change the number to anything else and then click Default... The number is not changed.
    Kåre Nejmann
    Aarhus, Denmark
  • Thu, Oct 13 2016 5:29 PM In reply to
    • Frédéric
    • Posts 6
    • Points 70
    humm
    if I set custom and then change the number, if I click again to Default de number go back to 240
