Latest post Wed, Sep 14 2016 9:13 AM by frediko. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Thu, Sep 1 2016 2:32 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,406
    • Points 15,485
    Re: DNxHR SQ playing back in low res
    Hello,
    MC8.6.1., Project 1080 / 50p, UHD source material (h264).
    I've done some tests with the same result. Even there was no difference between LB and the HQ codec settings (same miserable result). The only one use was HQX codec.
    Then I installed MC8.6.2 (indeed I did it without problems) and the error disappeared.
    For clarification, it seems that it is the fault display.
    Material originally transcode in MC8.6.1 at MC8.6.2. is displayed correctly.
    Regards
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Thu, Sep 1 2016 9:01 PM In reply to
    • ManChicken
    • Joined on Mon, Feb 4 2008
    • Denver, CO
    • Posts 258
    • Points 3,265
    • Moderator: MetaFuze
    I just had the exact same thing..
    h264 MOV at 4k UHD/29.97, linked in an HD/23.98 project, transcoded to DNxHR SQ. The resulting transcodes look fine in Yellow/Green mode, but look like crap in Green & 10bit mode.
    I wound up re-transcoding externally with Adobe ME (which is 1000 times faster than MC's terrible transcode anyway) and relinking.
    Avid: Where High-Res Means Low-Res
  • Fri, Sep 2 2016 2:12 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,572
    • Points 45,875
    ManChicken, download 8.6.2 (when it's available again) and re-try. The problem should be fixed.
    Dave S.
  • Fri, Sep 2 2016 3:47 AM In reply to
    • smyers63
    • Joined on Thu, Feb 16 2006
    • Dallas, Texas
    • Posts 3,770
    • Points 44,485
    • Moderator: MCA PC
    DStone:
    Just a clarification: MC 8.6.2 will only be available by special request to Avid support.  The next version to be released will be 8.6.3.
    Scott
  • Fri, Sep 2 2016 2:41 PM In reply to
    • frediko
    • Joined on Sat, Sep 27 2008
    • Norway
    • Posts 80
    • Points 1,055
    So we had the exact same issue.
    MC 8.6.1 win7 64 on hp z440
    1080i/50 project
    mostly XDCAM HD 50Mbits 1080P/25
    Some XAVC 4K Intra VBR Class 300
    Some transcoded to DNxHR SQ
    The XDCAM played back full res
    The XAVC 4k played back single field unless project changed to 1080p/25
    The DNxHR SQ played back single field and draft/SD(?) unless project changed to 1080p/25 and opening on 8.5.3. Played back single field (1920x540) on 8.5.3 1080i/50
    We've downloaded 8.6.2 but have not tried it yet. I have seen the single field in interlaced project before, but never the draft/SD quality.
    Will probably continue workaround with changing machines and project setting for the few shots for now.
    Mostly hp z420/440 on Media Composer 8.x and Symphony 8.x Also Dell Precision m3800 | Win 10 | 16GB memory | Quadro k1100 [view my complete system specs]
  • Mon, Sep 12 2016 9:42 AM In reply to
    • frediko
    • Norway
    • Posts 80
    • Points 1,055
    So 8.6.3 fixed the lowres proxy look of DNxHR footage for us :)
    It still has the problem with UHD progressive footage in a 1080i/50 project showing as 1920x540 (single field) in the timeline. Workaround is rendering/mixdown all UHD/4k shots in 1080p/25 format before mastering in 1080i/50. Weird bug.
  • Tue, Sep 13 2016 6:36 PM In reply to
    • ManChicken
    • Denver, CO
    • Posts 258
    • Points 3,265
    Well that's good, guess I'll download it.. though it's not mentioned as a fixed bug in the release notes.
  • Wed, Sep 14 2016 9:13 AM In reply to
    • frediko
    • Norway
    • Posts 80
    • Points 1,055
    Please be aware of two big changes from 8.6.1 to 8.6.3.
    Secondary color correction is broken:
    http://community.avid.com/forums/p/161282/815331.aspx
    LUT levels are fixed (were offset between 8.5 and 8.6.1), so stuff with luts done on 8.5 to 8.6.1 will look different/wrong going to 8.6.3.
    fred
