Latest post Fri, Sep 2 2016 8:56 AM by Vilem. 57 replies.
Page 1 of 4 (58 items) 1 2 3 4 Next >
  • Tue, Aug 30 2016 12:03 AM
    8.6.2 Update Crashes on Launch
    I just upgraded from 8.6.0 to 8.6.2 via Application Manager on a HP z420 using Windows 10. We have a Quadro 2000 and 16BG of RAM.
    After the update, Media Composer crashes after the initial start-up. It is just about to show the User/Project window when it quits unexpectidly. I only get a Windows error "Avid Editor stopped working."
    I tried to restart twice. This box is connect to MojoDX hardware. This system appears to still be supported.
    Marc
    Windows 10 Enterprise - Dell Precision 7810 - 32GB RAM - DNxIO - Nvidia Quadro M5000 [view my complete system specs]
  • Tue, Aug 30 2016 1:10 AM In reply to
    Re: 8.6.2 Update Crashes on Launch
    Did you say yes to Installing DX hardware?
    I had a crash on launch with 8.6.2 and W7 SP1. with a quadro 2000. Restarting cured it.
    By choice I do not let the App manager update anything here.
    If you need the App Manager for the download then stop it straight after the download finishes.
    Move the download to C:\ and unzip it to C:\
    Install from the there. (C:\Media_Composer_8.6.2_Win )
    I choose the manual install.
    Good luck.
  • Tue, Aug 30 2016 1:59 AM In reply to
    • RGU
    • Joined on Thu, Jul 24 2008
    • Posts 8
    • Points 120
    Exactly the same problem here.  Upgrade from 8.61 to 8.62 via application manager on Win7 machine, Quadro 400 and Quadro K2200 with 32GB system RAM.  Tried a couple of retsrts as well. no difference.
    Is there an easy way to revert to previous version 8.6.1?
    RGU
    Win7pro V6.1.7601 Service Pack 1 Build 7601, ASUS P9X79WS, I7-3930K 3.2GHz Hex core, Quadro 4000 and Quadro K2200, 32GB RAM, C:512GB SSD, S:1TB RAID 1... [view my complete system specs]
  • Tue, Aug 30 2016 2:07 AM In reply to
    Did you uninstall 8.6.1 via the Control Panel Programs and Features before installing 8.6.2?
    RGU:
    Do you still have the 8.6.1 download or installer?  If so uninstll 8.6.2 and reinstall 8.6.1
  • Tue, Aug 30 2016 2:56 AM In reply to
    • RGU
    • Posts 8
    • Points 120
    I did not uninstal 8.6.1, just used the Aplications Manager to do the upgrade as I usually do.  But I did download the the full version of 8.6.1 a short while ago.  If I uninstall 8.6.2 will I also nee to reinstall and reactiavte all the plugins (i.e. Boris FX, Isotope... etc.)?
    RGU
  • Tue, Aug 30 2016 3:12 AM In reply to
    RGU:
    I have never had to so no they should all just show up.
  • Tue, Aug 30 2016 3:54 AM In reply to
    • RGU
    • Posts 8
    • Points 120
    OK will give it a go tomorrow...
    RGU
  • Tue, Aug 30 2016 4:25 AM In reply to
    • RGU
    • Posts 8
    • Points 120
    Couldn't wait.  Deactivated - uninstalled - restarted - installed 8.6.1 - restarted - tested a few times.
    All OK, back to normal, very smooth reinstallation.
    RGU
  • Tue, Aug 30 2016 4:29 AM In reply to
    • ZFigas
    • Joined on Tue, Jan 31 2006
    • Poland
    • Posts 94
    • Points 1,300
    I had same problem in Win 10. Normal intallation works OK.
    Regards
    Zb.
    HP Z820, 2xE5-2697, 64 GB RAM, Win 10 Pro, Nvidia Quadro K5200, Boris Red 5.6, BCC 11.0.2, Saphire 11.0.2 [view my complete system specs]
  • Tue, Aug 30 2016 5:46 AM In reply to
    • rtbauer
    • Joined on Sat, Feb 4 2006
    • Indianapolis, IN
    • Posts 39
    • Points 505
    I also tried to update MC  8.6.1 to 8.6.2 through AppManager.  Tried starting MC after the reboot and crashed.  Tried rebooting and starting again, same issue of crashing.  Manually installed MC 8.6.2 from the folder that AppManger saved it in.  After reboot, MC stsrtd and worked as normal.
    Crazy AppManager strikes again.  All in favor of firing the AppManager?
    P6TD Deluxe Quad Core i7 2.8ghz 12Gb Ram 3x1Tb hard drive nVidia Quadro FX 1800, Pioneer BD Burner, VIA Chipset 1394 Firewire MC 8.9.3 Windows 10 NVidia... [view my complete system specs]
    Rich
  • Tue, Aug 30 2016 5:54 AM In reply to
    • markyramone
    • Port Lincoln, Australia
    • Posts 143
    • Points 2,030
    Marc,
    I tried Andrew's manual installation advice, worked for me:
    Uninstall 8.6.2
    Find 8.6.2 install zipped folder inside Upgrade folder, move it to root of C drive.
    Unzip to C drive, manually install with Install.exe file
    Throughout process, no need to deactivate if prompted.
    It's worth trying this before rolling back to 8.6.1.
    Good luck,
    Mark.
    Avid Media Composer 8.8, Intel Core i7-4790, 3.6 GHz, 16gb RAM NVDIA GeForce GTX 960 Microsoft Windows 10 Home 64 bit [view my complete system specs]
  • Tue, Aug 30 2016 6:04 AM In reply to
    • gitzit
    • Joined on Fri, Jan 20 2012
    • Posts 4
    • Points 70
    RUG
    RGU:
    I just uninstalled 8.6.2 and went back to 8.6.1 and my bcc and mocha pro plugins were still there and working.
  • Tue, Aug 30 2016 6:59 AM In reply to
    • smyers63
    • Joined on Thu, Feb 16 2006
    • Dallas, Texas
    • Posts 3,770
    • Points 44,485
    • Moderator: MCA PC
    rtbauer:
    It's not AppMan that's at fault.  I never use AppMan.
    Installing 8.6.2 completely separate from AppMan without AppMan even running got the same result here.  No trouble with 8.6.1, then installed 8.6.2 and MC won't run without a crash before getting to the open project dialog.
    Scott
  • Tue, Aug 30 2016 7:23 AM In reply to
    smyers63:
    Top clarify did you also unzip the download whilst it was at the root level of your C: drive? though from rtbauer experience it seems that you could also unpack it from C:\Avid Downloads\
    Did you uninstall MC from the control panel before installing 8.6.2?
    There's another thread about this problem, and one of the users there moved the downloaded 8.6.2 zip file to the root of the C: drive, and extracted and installed from there and it worked. Although he posted in the Mac forum, he appears to be using a PC, so it's worth a look:
    http://community.avid.com/forums/t/161453.aspx
    x-posted with Andrew
    Media Composer 2018.12.2 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
