Latest post Thu, Oct 27 2016 5:13 PM by mjolnarn. 15 replies.
  • Wed, Sep 14 2016 9:24 AM
    • frediko
    • Joined on Sat, Sep 27 2008
    • Norway
    • Posts 80
    • Points 1,045
    Secondary color correction is broken in 8.6.3 [fixed]
    Hi, making a new post for visibility and since it's a separate issue/bug.
    Secondary color correction now returns way wrong results making the tool useless.
    It was already starting to get buggy in 8.6.1 but went all bad in 8.6.3.
    Original replies with info here:
    http://community.avid.com/forums/p/161282/815331.aspx
    We have this problem across several machines all on 8.6.3, hp z440/z420, win 7, working in 1080i/50 projects (same on 1080p/25).
    Realtime playback/viewing looks ok through a safe color limiter (422), but renders are very glitchy.
    Anyone else have success?
    So, secondary color is kind of a big part of the Symphony option, hope this gets worked out soon.
    Fred
    Mostly hp z420/440 on Media Composer 8.x and Symphony 8.x Also Dell Precision m3800 | Win 10 | 16GB memory | Quadro k1100 [view my complete system specs]
  • Wed, Sep 14 2016 4:06 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,833
    • Points 20,230
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Secondary color correction is broken in 8.6.3
    Hi Fred,
     I created a case 03037541 for this issue.
    Regards,
    Ralph
  • Mon, Sep 19 2016 1:22 PM In reply to
    • frediko
    • Norway
    • Posts 80
    • Points 1,045
    So a quick update while Avid is testing this out.
    We found that going into render settings and disabling GPU efects would make secondary color effects look ok. So that's a workaround for now. We have not done a complete system reinstall yet, so if secondary color correction works for anyone else, please let us know about your setup. Win 7/10, driver version etc..
  • Mon, Sep 19 2016 1:25 PM In reply to
    • Posts 10,227
    • Points 218,330
    Frediko
    I added that t the case chris is working on so he has this info for his troubleshooting.
    Thanks tons
  • Mon, Sep 19 2016 3:31 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • Posts 132
    • Points 1,665
    Thanks for letting us know Fred. Was about to make the jump this weekend. Would have been a very miserable Monday trying to figure out what went wrong.
    Charles
    HP Z400, z220, and z420 workstations with 8GB of RAM and nVidia Quadro 2000 graphics cards. Windows 7 64-bit SP1. ISIS 5000 4.2. [view my complete system specs]
  • Mon, Sep 19 2016 8:50 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,199
    • Points 14,390
    frediko:
    FWIW, no problem on a "below-spec" machine (MS Surface 4 Pro, Win10/1607).
    Reason is probably that the GPU is NOT used for Symphony on this machine, the GPU not passing the built-in test during MC start sequence (not enough VRAM).
    Not yet tested on my other system.
    MC 2018.12.1 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (11.0.0.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz -... [view my complete system specs]
  • Mon, Sep 19 2016 9:57 PM In reply to
    • Birck66
    • Joined on Wed, Nov 21 2007
    • Posts 15
    • Points 195
    This is really annoying! We looked like idiots in front of agency when the bug started in approval session. Please help!
    HP Z2 G4 Win10 (1809) Avid Artist | DNxIO 32gig RAM Quadro P1000 [view my complete system specs]
  • Wed, Sep 21 2016 1:36 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,199
    • Points 14,390
    BenoitM:
    Tested on my main system (see my specs), with GPU support enabled: I could not repro the problem described...
  • Fri, Oct 7 2016 12:18 AM In reply to
    • EvanAA
    • Joined on Mon, Mar 7 2016
    • NYC
    • Posts 52
    • Points 685
    FYI, I'm having the same issue on a z840 fully loaded
    Evan
    HP z840, 64gig Ram, 20 cores, GPU k5200, Win10Pro -- Avid Symphony (Since Day 1), Adobe, DaVinci Resolve Studio [view my complete system specs]
  • Wed, Oct 26 2016 9:00 AM In reply to
    • frediko
    • Norway
    • Posts 80
    • Points 1,045
    Just a small headsup if someone is using the "Disable GPU effects" in render settings as a workaround.
    Doing so might not make background renders look ok. Only foreground renders. Thats our experience at least.
    Already shared this info with Avid on the case thread. They are having trouble reproducing the issue, so a fix might still be a while off.
    A small workaround for doing secondary corrections is to use the paint effect.
    Paint -> rectangle entire picture or poly tool a selection -> color adjust -> magic mask your color -> sat/hue. Good thing is actual softening of the selection that you don't have in Secondary color tool. Bad thing is it's a bit harder to work with outside of color correction tool.
    fred
    PS: haven't tried it with 8.6.4 yet, but the bug is not addressed directly - so a fix would be a happy accident :)
  • Wed, Oct 26 2016 1:08 PM In reply to
    • EvanAA
    • NYC
    • Posts 52
    • Points 685
    I see Avid released a update 10.24.2016 and in the Read Me no meantion of fixing this issue. Can we get an update???
    Evan A.
  • Wed, Oct 26 2016 8:19 PM In reply to
    The Problem still exists in 8.6.4 (Quadro M4000)
    But works on my secondary System with a Quadro 4000.
    HP Z-8 | Xeon 2 x gold 5118 @ 2.3 GHz (12 cores)| 96 GB RAM | NVIDIA Quadro P4000 | Win 10 Pro 64 Bit | Blackmagic DNxIQ | MC 12.1 | Symphony Option *... [view my complete system specs]
    Andy Christen
  • Thu, Oct 27 2016 7:53 AM In reply to
    • frediko
    • Norway
    • Posts 80
    • Points 1,045
    So...  It's working again :)
    Did:
    -went from quicktime 7.7.8 to 7.7.9
    -clean installed nvidia 362.13 (install from C:\Program Files\Avid\Utilities\Nvidia\ -> advanced -> clean)
    So either the upgrade from nvidia 353.82 to 362.13 or the clean install of driver most likely fixed it. Should have done that long ago... geez.
    Followed the driver recommendations from documentation too closely:
    http://avid.force.com/pkb/articles/en_US/Compatibility/en267087
    http://resources.avid.com/SupportFiles/attach/README_Avid_Editor_v8.6.pdf
    Those both list nvidia driver version 353.82.
    Although - the workaround way of doing secondary with paint effect will stick with us for many shots.
    Like that it's possible to soften the selection/matte which is not possible within the regular secondary correction tab.
    Fred
  • Thu, Oct 27 2016 10:34 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    frediko:
    Likely the clean install , I even get a BSOD when I did that and then all was working well after a reboot.
    Tomas
  • Thu, Oct 27 2016 4:41 PM In reply to
    • EvanAA
    • NYC
    • Posts 52
    • Points 685
    frediko:
    Doing this worked for me. All fixed! Would be nice if Avid had mentioned this!?!?!?
    -Evan
