Latest post Tue, Mar 12 2019 7:42 PM by Jasper Quispel. 32 replies.
Page 3 of 3 (33 items) < Previous 1 2 3
  • Fri, Jan 4 2019 3:18 PM In reply to
    • Aren Hansen
    • Joined on Tue, Mar 15 2016
    • Toronto
    • Posts 71
    • Points 765
    Re: Avid Artist Mix - cannot disable fader motors...
    Hi there,
    Turning off the mixer takes about a second, turning it on takes about 3. It's not really any slower than it was when I had to reach over and press the buttons. I've also now made macros to switch the AVID mixer mode ie. from Clip to Auto. And I've made one that records keyframes (moving the playhead back 10 seconds, selecting all tracks and then hitting the REC button on the AVID mixer). Pretty fun! Here's how my old ipad looks running lemur with buttons assigned to these macros: https://imgur.com/hSlH4BP
    It's true, getting this workaround up and running on different systems is not practical.
    The MIX is overall terribly implemented on AVID MC and also terribly documented. I bitterly wrote a manual for it/MC myself: https://community.avid.com/forums/t/181622.aspx
    I'm going to go check out xkeys now...
    2018.12.7 // OS10.14.5 // iMac 2019 3.6 i9 // 72GB Ram // Vega 48 // [view my complete system specs]
  • Fri, Mar 8 2019 8:31 AM In reply to
    Hi Marianna,
    Any word on this?
    The latest version of MC i'm running is 2018-10 and now the Artist Mix will stop the Avid during playback if I so much as touch a fader, let alone actually make an adjustment with it.  It then works, well kind of...
    I still can't upgrade past 3.3.2 because of the fader movement issue, so can't take advantage of the improvements of latency/compatibility.  The distraction is too much for any of the directors I have worked with.
    Is there any way to get this moved forward?  it really does need to be addressed.  Surely after 2 years they could do something?
    Thank you.
    Jonno
    iMac (27", Late 2013, 3.5 GHz Intel Core i7, 32 GB, OS X 10.12.6) Connected to 27" Thunderbolt Display, BlackMagic UltraStudio Express (10.7... [view my complete system specs]
    www.fusspotfilms.com
  • Tue, Mar 12 2019 7:42 PM In reply to
    I'm also still on 3.3.2 because of the suspend faders issue... Sad
    Mac Pro late 2013 3,5 Ghz 6-Core, 64Gb, OSX 10.10.5, Avid MC 8.4, Blackmagic Ultrastudio Express Macbook Pro retina 2012 15 inch i7, 16Gb, OSX 10.10.5... [view my complete system specs]
