Latest post Wed, Sep 6 2017 3:56 PM by Frédéric. 16 replies.
  • Thu, Dec 22 2016 1:01 PM
    Media Composer 8.6.5 + 8.7 XDCAM Export Problem
    We have got Problems when exporting Clips on XDCAM. Somitimes it works, somtimes not.
    AVID knows the XDCAM drive, but won´t export. AVID says, it doesn´t see the XDCAM Drive"Please connct XDCAM device or insert disk".
    Linking and consolidate via ama and XDCAM drive works fine.
    We have actual AMA Plug Ins, also tested this with old versions
    Any Ideas?
    Best,
    Sergej
  • Fri, Dec 23 2016 2:51 AM In reply to
    Re: Media Composer 8.6.5 + 8.7 XDCAM Export Problem
    I have the same problem since i installed 8.6.5. Even after installing the new Nablet plugin on 8.7. It is also not possible to export to a virtual drive.
    Maybe some old stuff from earlier avid versions cause this problem?
    Cheers Andy
    HP Z840 | Xeon 2 x E5-2690v3 @ 2.6 GHz (12 cores)| 64 GB RAM | NVIDIA Quadro M4000 | Win 7 Pro 64 Bit | Blackmagic DNxIO | Artist Color | MC 8.9.3 | Symphony... [view my complete system specs]
    Andy Christen
  • Fri, Dec 23 2016 6:37 PM In reply to
    I've solved the problem. In my case, it was a corrupt user file that caused the problems. Delete it and enjoy Christmas. Looking forward to your answer.
    Andy
    Andy Christen
  • Wed, Jan 11 2017 6:13 PM In reply to
    Thanks for the answer, in my case it did not, even after a complete new installation of the Windows and Avid.
    Best,
    Sergej
  • Fri, Jan 13 2017 12:11 AM In reply to
    As from 8.7 the XDCam plugins and Sony are supplied fromnablet.
    http://www.nablet.com/ama-plugins/
    Desktop PC
    3 Heads Digital Films
  • Fri, Jan 13 2017 12:33 AM In reply to
    The problem with Sony and nablet too
  • Sun, Jan 15 2017 4:24 PM In reply to
    • Pinek
    • Joined on Wed, Jan 7 2009
    • Poland
    • Posts 111
    • Points 1,225
    i have something problem few years ago, I missed it this way
    windows 7 format XDCam disk
    make folder on hdd drive
    go to media composer
    export timeline to folder on HDD
    exit from Media Composer
    copy files using Total Commader from HDD folder to XDCam disk
    i use PDW-U1 drive, but i go to media copmany and check this disk on Sony HD-1500 recoder
    it works Great!
    Workstation: AMC 8.3, Windows 7 64-bit ultimate, 4,0 Quad Core, 8 GB RAM, 4 x 1,5TB internal HDD, Nvidia Quadro 4800, LSI HBA, LG Bluray, MOTU HD-SDI.... [view my complete system specs]
  • Sun, Jan 15 2017 5:03 PM In reply to
    I can confirm the bug but in our cases we have found that it is MC not correctly releasing the XDCAM drive after a link to load media.
    In case we restart MC (not whole PC) and then directly execute the export to the XDCAM it works fine.
    I'm not sure if it's an MC bug or the XDCAM driver and link plugins but from the behavior we see, my thoughts go to MC and not the (AMA) plugin. But this is just a hunch.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Sun, Jan 15 2017 9:01 PM In reply to
    Jeroen van Eekeres:
    MC not correctly releasing the XDCAM drive after a link to load media. In case we restart MC (not whole PC)
    Have you tried turning off and unplugging the XDCAM deck Then Plugging in and restarting the deck?   MAY help to confirm your hunch. Geeked
  • Sun, Jan 15 2017 9:29 PM In reply to
    When XDCAM import everything works fine. But after the first export after a change of disk, the disk no longer finds the need to open multiple times AMA link.
  • Sun, Jan 15 2017 10:29 PM In reply to
    AndrewAction:
    We tried several combinations. The only consistent action with the result that write back was possible was a restart of MC.
    Jeroen van Eekeres
  • Fri, Feb 10 2017 4:10 PM In reply to
    • IF...
    • Joined on Wed, Feb 8 2006
    • Posts 64
    • Points 815
    Hello everyone, I had the same issue, i solved by opening the console Window (ctrl+6) and digit "AllDrives" and press Enter.
    Hope this help.
    Custom PC: MC 5.5.4 | Adrenaline DNxCel| Cooler Master Silencio 550 | Motherboard AsRock Z68 Pro3 Gen3 | Intel i3 2100 3.1Ghz | Ram 16GB Corsair VengeanceLp... [view my complete system specs]
  • Mon, Feb 13 2017 11:32 AM In reply to
    When choosing XDCAM disk displays an error
    When you select a folder on xdcam displays error
    Complete new installation of windows 7 and Avid Media Composer 8.7.2 , plug-in
    Export XDCAM error
    What else can I do? Everything worked fine
  • Fri, Feb 17 2017 7:46 AM In reply to
    • IF...
    • Posts 64
    • Points 815
    Hello, Did you try to open Console Window and digit "AllDrives" and press Enter?
  • Tue, Feb 21 2017 9:36 AM In reply to
    The solution came with the new version 8.8 Avid. Thanks for the advice.
