Latest post Wed, Jun 20 2018 10:02 PM by BobRusso. 16 replies.
  • Fri, Dec 30 2016 2:40 AM
    • oze
    • New Zealand
    • Posts 574
    • Points 6,790
    ISIS/Nexus Mac OS 10.12 (Sierra) compatibility. When . . ?
    I understand from the following link that Sierra client systems and ISIS/Nexus are not yet compatible. We have ordered a bunch of new iMacs due in the New Year and are in the process of aquiring a 60TB Nexus setup that will run alongside our ISIS 5000 and it would be great to know if the described work around in fact works and when Avid expects full compatibility now that Media Composer is up and running on Sierra systems.
    Does anyone from Avid know any more about this issue. All help is much appreciated . . .
    http://avid.force.com/pkb/articles/en_US/compatibility/MacOS-Sierra-and-Avid-NEXIS
    ***UPDATE December 20, 2016***
    Engineering continues to work on this issue and at this time this is officially NOT supported.
    You can run a command to make this work, but it is not officially supported by AVID.
    1.  Install the NEXIS 7.1 client on your MAC OS X Sierra system.
    2.  Open a terminal and run this command:
    sudo -b /Applications/AvidNEXIS/AvidNEXISClientManager.app/Contents/MacOS/AvidNEXISClientManager
    This allows you to mount drives using the NEXIS 7.1 client.
    CAUTION: If this does not work for you, Avid cannot troubleshoot.  Avid expects to support Sierra soon.
    2017 27" iMac i7 4.2, 2TB PCI memory, 64GB RAM, OS 10.13.6, MC 2018.10 [view my complete system specs]
  • Fri, Dec 30 2016 1:43 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,234
    • Points 27,615
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: ISIS/Nexus Mac OS 10.12 (Sierra) compatibility. When . . ?
    With MacOS Sierra Apple removed the ability for third parties to mount a volume under /volumes. Only a Root user can mount a volume under /volumes. That is all this terminal command does and it has been used extensively.
    I don't have a date for when we'll have an official MacOS Sierra release but suspect it will be in early next year.
  • Mon, Jan 23 2017 11:48 PM In reply to
    • oze
    • New Zealand
    • Posts 574
    • Points 6,790
    Thanks Bob, our Nexus is still a few weeks away . . . is there a command line option for our ISIS 5500?
  • Tue, Jan 24 2017 12:18 AM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,234
    • Points 27,615
    If you ISIS is running 4.7.5 or later (and it should be) the NEXIS 7.1.1 client can connect to it. You would use the NEXIS client; this would also allow you to connect to both. I hope to have a MacOS Sierra client out very soon.
  • Tue, Jan 24 2017 2:41 AM In reply to
    • oze
    • New Zealand
    • Posts 574
    • Points 6,790
    Thanks Bob, much appreciated . . . Big Smile
  • Tue, Jan 24 2017 2:52 AM In reply to
    • oze
    • New Zealand
    • Posts 574
    • Points 6,790
    Getting the following error . . .
    Any thoughts . . ?
  • Tue, Jan 24 2017 3:08 AM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,234
    • Points 27,615
    Is this connecting to an ISIS? It must be running 4.7.5 or later.
    Did you launch the Client with the Terminal Command? This is the error you'd receive if you simply launch the client.
  • Thu, Jan 26 2017 1:07 AM In reply to
    • oze
    • New Zealand
    • Posts 574
    • Points 6,790
    Thanks Bob, that was the problem.
    Cheers
  • Wed, Feb 1 2017 4:32 PM In reply to
    • jeffct
    • Joined on Thu, Jan 30 2014
    • Posts 7
    • Points 125
    Has there been any updates on if this problem?
    I've tried to talk to people from Avid and they haven't told me an answer about it. The only answer I have gotten is reading this article.
  • Wed, Feb 1 2017 4:37 PM In reply to
    • Posts 10,018
    • Points 215,715
    Jeffct
    The client should be done next week in support of Sierra.   We do have problems with the Mgt Console.... MacOS Sierra won’t accept our self signed certs.   Apple no longer allows third parties to mount a volume under /volumes only root
    We have a bypass that will be listed in the ReadMe when the new client is out soon.
  • Wed, Feb 1 2017 4:43 PM In reply to
    • jeffct
    • Posts 7
    • Points 125
    Thank you very much for answering my question.
  • Wed, Feb 1 2017 5:00 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,234
    • Points 27,615
    We are working on a client that will work with MacOS Sierra. It should be released shortly.
    This will not require a terminal command. Today if you need to use MacOS Sierra you can use this terminal command:
    1.  Install the NEXIS 7.1.1 client on your MAC OS X Sierra system. This is on the download center.
    sudo -b/Applications/AvidNEXIS/AvidNEXISClientManager.app/Contents/MacOS/AvidNEXISClientManager
    Chrome and Safari are not working to connect to the management console if encryption is enabled. It is off by default with NEXIS and the ISIS|5500. It is on by default with the ISIS|7500.
    Firefox is working on Sierra with encryption.
  • Thu, Feb 16 2017 9:36 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,234
    • Points 27,615
    The Avid NEXIS 7.2 client has been posted on the Avid Download Center. This has support for macOS Sierra.
  • Tue, Jun 19 2018 11:17 PM In reply to
    • Geo77
    • Joined on Mon, May 31 2010
    • Posts 19
    • Points 285
    Hi Bob,
    We're upgrading our base OS to Sierra this year with the goal of using the 7.9.1 Nexis client and Media composer 8.8.5. Does this configuration sound workable to you? Reading the ISIS 4.7.11 documentation, the official support stops at El Capitan. Does the document refer to the ISIS client or to the engine itself? We're looking at 12 people connecting to the engine so I want to be certain we aren't going to run into compatability issues.
  • Wed, Jun 20 2018 1:57 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,234
    • Points 27,615
    I suggest using the latest NEXIS client available - this is currently 18.5. There are a few Mac specific fixes in this release which would make it valuable to use.
    The documentation for support is specific to the ISIS client. The NEXIS client is available on the Avid Download Center.
