Latest post Wed, Feb 8 2017 5:31 PM by tpowell. 2 replies.
  • Mon, Feb 6 2017 1:57 AM
    Can't change target video resolution!
    After transcoding a week's worth of footage with no trouble, my drive dies. Not a problem -- I turn it back on and start transcoding all over again...except I can't. I go to transcode a new folder of ama footage and I can't choose the correct resolution. I'm working in a 1080p/23.976 project, so I can click the transcode button without a problem, but when I go to choose the resolution, everything is greyed out. The default setting is DNxHD 115, so I can do that, but I can't choose anything else -- not AVC, not ProRes, not even DNxHD 36, which is the resolution that I've been transcoding in all weekend. It's forcing me to do DNxHD 115. I tried a few other ama files too, just to make sure it's not a corrupt folder, but I'm getting the same problem.
    Am I missing a setting or something?
    Avid Media Composer 8.6.0 • MAC OS High Sierra 10.13.4 • iMac (Retina 5K, 27-inch, Late 2014) • 4 GHz Intel Core i7 • 16 GB 1600 MHz DDR3 • AMD Radeon... [view my complete system specs]
  • Mon, Feb 6 2017 2:54 PM In reply to
    Re: Can't change target video resolution!
    Can you see the new drive as a target drive?
    Did you try changing the target drive to see if your options increase?
  • Wed, Feb 8 2017 5:31 PM In reply to
    • tpowell
    • Joined on Wed, Dec 10 2014
    • Posts 36
    • Points 415
    If Kevin's idea doesn't work, you might also try a new project and user settings. My first go-to troubleshooting for problems like this is creating a new project with new user settings, then opening the bin/sequence in this new project to see if it helps. A corrupted project or user settings sometimes show inconsistent behavior with many things working properly and it is quick to rule this out as a possible cause.
