Latest post Sun, Mar 19 2017 3:57 PM by Vilem. 30 replies.
Page 2 of 3 (31 items) < Previous 1 2 3 Next >
  • Wed, Feb 22 2017 12:07 PM In reply to
    • scocklin
    • Maryland
    • Posts 652
    • Points 7,840
    Re: MC 8.8 Now Available!
    Same here, I'm running Avid 8.8 on Windows 10 with a Quadro 4000 card and GTX 780 card with the latest Nvidia driver 376.53 and so far no crashes.
    I was experiencing system crashes a few weeks ago when Windows automatic updates was attempting an update, I did a clean install for the first time on my system and it has been working fine so far.
    HP Z800 2x 3.46GHz Hex Core X5690, 48GB Ram, Windows 10, Samsung SSD 850 Pro 512GB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K,... [view my complete system specs]
  • Wed, Feb 22 2017 6:20 PM In reply to
    scocklin:
    Your system specs indicate you have a Quadro K4000 card, which is a generation newer than my Quadro 4000.  It has 1 GB additional memory (3 GB total, compared to my 2 GB), which may explain why you are not getting the "out of memory" messages.
    Media Composer 2018.12 w/Symphony | OS X 10.13.6 | iMac 2017 (Retina 5K, 27-inch, 2017) 4.2 GHz Intel Core i7 | 40 GB 2400 MHz DDR4 | TerraMaster 16TB... [view my complete system specs]
  • Wed, Feb 22 2017 6:32 PM In reply to
    Vilem:
    Yes stable here. After a week of use yet did not notice problems with the graphics card.
    The crashes seem to occur only when opening a project created with an earlier version of Media Composer.  I was able to create a new project, ingest some media, lay a few clips on the timeline, and play them without encountering any "out of memory" issues or crashes.  Unfortunately, I have several projects in progress, some of which go back a few months.  So I guess my choice is to revert to an earlier version of Media Composer or run the current version with an earlier NVIDIA driver.  That or upgrade my video card on this 4-year-old system.
  • Wed, Feb 22 2017 6:39 PM In reply to
    • Posts 10,151
    • Points 217,265
    Michael
    Can you pin point the earlier versions? i.e what version where the projects created in.
  • Wed, Feb 22 2017 7:09 PM In reply to
    Marianna:
    The most critical project is a big multicam one that I started a year ago and edited for three months.  I had the most current version of Media Composer at that time.  I tried to open several earlier projects, and they crashed as well with the "out of memory" message.
  • Wed, Feb 22 2017 7:17 PM In reply to
    • Posts 10,151
    • Points 217,265
    Michael Ray Brown:
    That mot likely was 8.4.x.  Want to try a temp version of that and see if it allows you to open?
  • Wed, Feb 22 2017 7:54 PM In reply to
    Marianna:
    Sure, I'll try it.  Does it matter that 8.4.x was not qualified for Windows 10?
    Michael
  • Wed, Feb 22 2017 8:05 PM In reply to
    • Posts 10,151
    • Points 217,265
    Crap - forgot you were on 10.  Did you try 8.5.x?  if not thats compat with 10.
    Advise?
  • Wed, Feb 22 2017 8:32 PM In reply to
    Marianna:
    I probably was on 8.5.x.  Going to the Download Center, I see that its release date coincides with the time frame of that project.  If I remember correctly, though, 8.5.x wants to use NVIDIA driver version 353.82.  If I roll back my video driver to that version so that I can run 8.5.x, I really won't be learning much.  It's the later NVIDIA drivers that are causing "out of memory" errors.
    Michael
  • Wed, Feb 22 2017 10:06 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 591
    • Points 6,695
    michael,
    like you i have an old quadro 4000 with 2gb of memory, and i'm back to 353.82, on win 10pro.
    i had the same problem trying 375.86 with 8.8, and also before that, the driver that was supplied with 8.7.2, whatever number it was...
    i never bothered to try any other drivers by the way.
    symphony 2018.12.1 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
  • Thu, Feb 23 2017 7:57 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,404
    • Points 15,465
    Michael Ray Brown:
    With that, I was in the past, about three months back, also met. But I do not remember the exact parameters. I feel that I had turned on some version of the "Turbo Mode" setting W10. (Set using an external AVG). Maybe this direction is the way to solve the problem. Currently, the standard mode is set.
    Regards
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Thu, Feb 23 2017 11:07 AM In reply to
    Is there a list of non-Avid storage that will work with the new project sharing options?
    I currently use a Lumaforge Jellyfish and Mimiq software to emulate project sharing.
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Sat, Feb 25 2017 11:56 PM In reply to
    • bobpiech
    • Poland
    • Posts 105
    • Points 1,210
    Unfortunately maybe I am a malcontent, but now I found in MC 8.8 new limitation. New version of Media Composer don't import properly 16 bit RGBA TIFF with compesion Deflate type sequences with Alpha channel (Black screen). An old After Effects CS 6 still can do it and don't know what goes now wrong? Maybe other type TIFF compresion with Alpha Channel must be? Someone, something?
    MC8.8, Win764, QTime 7.7.9, NVIDIA Driver 375.86, Asrock P67 Extreme 6, Intel 2600K, 16GB RAM, Deckink HD Extreme 3D+, NVidia Quadro K4000, M-Audio Mbox... [view my complete system specs]
  • Sun, Feb 26 2017 1:35 AM In reply to
    FWIW a quick check here using a RGB logo on a transparent background. Saved from Photoshop as a 16bit tif with compression set to None and PC byte order opened fine here with MC 8.8 on a W7 SP1 computer
  • Sun, Feb 26 2017 10:06 AM In reply to
    • bobpiech
    • Poland
    • Posts 105
    • Points 1,210
    AndrewAction:
    OK. Compresion = none. It's works. THX AndrewAction.
