Latest post Thu, Feb 23 2017 4:23 PM by mjolnarn. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Feb 23 2017 8:45 AM
    • markyramone
    • Port Lincoln, Australia
    • Posts 143
    • Points 2,030
    Tape-like drop outs in timeline
    After over 10 years using Avid, first time I've encountered this. Drop outs in the timeline, every few clips. Clips are clean in the source monitor. Only started happening this week. Nothing has changed in my workflow, no hardware changes. The only change has been up grade to MC 8.8.
    Re-inserting affected clip usually fixes the problem but that's becoming tedious particularly if affected clip was corrected or had an effect on it. Have to do all that work again!
    Sample frame below at an edit but also happens mid way through clips.
    Has anyone encountered this? Suggestions to fix?
    Mark.
    Avid Media Composer 8.8, Intel Core i7-4790, 3.6 GHz, 16gb RAM NVDIA GeForce GTX 960 Microsoft Windows 10 Home 64 bit [view my complete system specs]
  • Thu, Feb 23 2017 10:32 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,406
    • Points 15,485
    Re: Tape-like drop outs in timeline
    Hello,
    it looks like a known problem with GPU rendering.
    Disable GPU rendering.
    V.
    http://community.avid.com/forums/p/180176/839305.aspx#839305
    http://community.avid.com/forums/t/180202.aspx
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Thu, Feb 23 2017 11:37 AM In reply to
    • markyramone
    • Posts 143
    • Points 2,030
    Thank you Vilem. I'll try that. Looks like Avid are aware of problem so we might see a fix in next upgrade?
  • Thu, Feb 23 2017 12:05 PM In reply to
    • Vilem
    • Prague
    • Posts 1,406
    • Points 15,485
    Yes,
    Avid knows about the problem.
    V.
  • Thu, Feb 23 2017 4:17 PM In reply to
    • Posts 10,282
    • Points 219,150
    Yes we are aware and the development team i working on it. Didnt make it to 8.8 but here is hoping the fix makes it to the next release.
  • Thu, Feb 23 2017 4:23 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Marianna:
    Seems like it isn´t mentioned in the Readme MM
    Tomas
