Latest post Thu, Mar 9 2017 4:12 PM by Marianna. 4 replies.
  • Wed, Mar 8 2017 7:52 PM
    nablet XAVC XDCAM
    I uninstalled Sony PDZK-MA2 Plugin (no longer present in System/Programs & Features) and wanted to install nablet XAVC XDCAM P4.0.2 Plugin. A message says "uninstall PDZK-MA2".
    I wanted to go back to my original PDZK-MA2 v3.51, but then again the same message "uninstall PDZK-MA2" appeared.
    How can I solve this problem?
    MB: ASUS P6TD Deluxe, ATX, Intel X58, QPI 6.4GT/s, Intel LGA1366, 6xDDR3 1600MHz, PCI-E V2.0, On-board Soundkarte. CP: Intel Core i7 920 (2.66 GHz) Quad... [view my complete system specs]
  • Wed, Mar 8 2017 8:41 PM In reply to
    • Posts 10,214
    • Points 218,175
    Re: nablet XAVC XDCAM
    Roland,
    You need to install the last version which I believe you indicated as 3.5.1 as there must be something still left there. You need to uninstall all previous AMA plugin, prior to installing any updated AMA plugin.
    The nablet plug-ins and the legacy Sony plug-ins cannot coexist on the same system. Having them both installed will result in unpredictable behaviors of the editing application and issues such as this.
    what I woud do is reinstall the sony and then uninstall again just to make sure.  Then install nablet only
  • Thu, Mar 9 2017 8:59 AM In reply to
    • fkurz
    • Joined on Wed, Jan 23 2008
    • Posts 31
    • Points 380
    Hi Roland,
    look at this thread: http://community.avid.com/forums/p/161060/837773.aspx#837773
    There was a solution deleting a folder at: C:\Program Files\Avid\AVX2_Plug-ins\AMA
    Regards
    Florian
    Avid MC 2018.2 symphony option HP Z820 Win 7 64Bit, SP 1 Mojo-DX Interface [view my complete system specs]
  • Thu, Mar 9 2017 10:59 AM In reply to
    Hi Marianna and Florian
    Thank you both for your help. It solved my problem.
    After unstalling PDKZ-MA2 a message said "uninstall not complete, you can do it manually". What "manually" means is explained in Florian's link http://community.avid.com/forums/p/161060/837773.aspx#837773, where Marianna describes how to delete the XDSDeck folder from C:\Program Files\Avid\AVX2_Plug-ins\AMA.
    Roland
  • Thu, Mar 9 2017 4:12 PM In reply to
    • Posts 10,214
    • Points 218,175
    Roland.
    YES!  Great news.  Florian you rock
