Latest post Wed, May 15 2019 1:02 AM by fropdaddy. 96 replies.
Page 6 of 7 (97 items) « First ... < Previous 3 4 5 6 7 Next >
  • Wed, Sep 12 2018 2:58 AM In reply to
    • Todd H
    • Joined on Fri, Jun 9 2006
    • Mansfield, Texas
    • Posts 110
    • Points 1,445
    Re: Benchmarks for those who build their own computers.
    I have been trying for over a year...replaced the psu, cpu, mobo...Its still happening.  I have run check disk, clean installs, memtest...etc..
    I am stumped and have not found anyone to help me without paying which i do not want to do.  It just loses power and restarts.  The error codes just point to a power issue which everywhere I have looked have no solutions to.
    Its pretty crazy.
    Yes I am going to install windows 10. I didnt do the upgrade when it was free last year or two years ago because I was told not to because of avid.  I really cant imagine its an operating system issue.
    Windows 10 pro 64 bit MSI x299 sli plus intel i7 7820x EVGA ge force 1060 G.Skill Ripjaws 31 gb 3200 ram Samsung 960 pro 512gb boot drive 4 tb toshiba... [view my complete system specs]
  • Wed, Sep 12 2018 7:50 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 481
    • Points 5,755
    i'ts not the OS if it happens in bios too.
    run mobo outside case.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Thu, Sep 13 2018 4:52 PM In reply to
    • Todd H
    • Mansfield, Texas
    • Posts 110
    • Points 1,445
    So I ordered the PSU, GPU, SSD, CPU Cooler so far.
    I cant decide on a MOBO.  The MSI X299 SLI Plus seems to be a good fit for cheaper than the asus rog strixx 299 gaming board.  I was talking to a guy at frys and usually I feel like the people there know there stuff but not today so I was hesitant.
    I am going to buy the 7820x and then Ram to go with the MOBO when I decide.
    anyone have any thoughts on the MSI board?
  • Thu, Sep 13 2018 7:06 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 171
    • Points 2,045
    Just my two cents -  What you have looks good -   here is what I would look into
    1. Check gigabyte MB with thunderbolt  - just think of future
    2. PSU problay is enough but think about at least an 850 (I got 1000 - maybe overkill?) did calucaltions and thought about future .  You shoud calculate and see if 750 is enough
    3. Consider if your MB has enough slots - for future - maybe a raid card? Masybe BM card.
    4. i9 I think has 44 lanes - I know it is expensive
    5. Make sure you have enough USB 3 and 3.1 - been using it and it is great
    6. I would go for a minium of 32 gigs - I guess you can upgrade when prices drop (question is when?)
    7. Does your case have enough room for additional drives?
    8. Is your case easy to work in?  A tight case is a pain.
    I have built several edit machnes - at timesI went the inexpensive route when I should not have.  But we all have budgets.
    good luck
    Symphony 2018.3 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media, BM Intensity... [view my complete system specs]
  • Thu, Sep 13 2018 8:26 PM In reply to
    • Todd H
    • Mansfield, Texas
    • Posts 110
    • Points 1,445
    yes the PSU should be fine.
    Yes there are enough PCI E slots.
    i9 does have 44 and this i7 has 28 lanes
    Plenty of usb 3.0 and 3.1
    G Skill ripjaw v 2x16 ram right now..if and when it drops I will get two more.
    Plenty of room in the case for more drives.  I am only going to put two more sata drives in the case and then rest of storage will be external in a 4 bay mediasonic case.
    Phanteks Enthoo Pro is a full tower case and should be plenty of space.  I actually am not putting much in there so lot of room!
    Yea budget is an issue right now for me and a catch 22.  We lost our sponsors and most of the funding for the show I have worked on for you 9 years so i only have a little work but the catch 22 is without a stable functioning setup I cant do any!
    When and if work picks back up or I can find some new gigs I can always upgrade the CPU and sell this one add ram.
    I think I am going to put a cooler master 240 radiatior in also.
  • Fri, Sep 14 2018 9:41 AM In reply to
    • Gretski
    • Posts 177
    • Points 2,375
    I am using the X299 A prime and the 7820x - no issues
    If using an air cooler, get the biggest that will fit in the case!
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
  • Fri, Sep 14 2018 5:55 PM In reply to
    • Todd H
    • Mansfield, Texas
    • Posts 110
    • Points 1,445
    I think I am going to grab the cooler master 240 if it is in at frys when I go there in a minute.
  • Mon, Sep 17 2018 12:12 PM In reply to
    Todd H:
    MSI Z370 Gaming i5 8400 Six Core Windows 10 on an Apacer M.2 PCIe MC 2018.9 on a 500 Gb SSD Adata DDR 4 memory  it is an success for me but then I do not extend to long heavy edits I have had good results with MSI boards for some time now
  • Sat, Sep 22 2018 1:22 PM In reply to
    • Todd H
    • Mansfield, Texas
    • Posts 110
    • Points 1,445
    So I ended up with the msi board, 7820x, g.skill ripjaws 32 gb ram...going to grab another 32 soon, samsung pro 960 512 gb, 4tb toshiba drive, evga 1060, phantek enthoo pro case, corsair h110i cooler and windows pro 10 64 bit.
    Ive been up and running for a few days with no issues.  Ive had no problem editing HD or 4k clips so far.  Avid, after effects, photoshop and mpeg streamclip...the tools I use the most have all been smooth.  Installed my aja kona 3g card and that is also issue free....hopefully i wont jinx it by saying that.
    Thanks for all the help in this thread.  I have noticed quicker render times and incredible differnece in boot time and shut down time.  I havent really noticed overall a huge performance boost however when encoding or importing  but that is ok what I needed was a setup that would work when I turn it on everyday and so far it has.
    Now to find some work, the real hard part.
  • Sat, Sep 22 2018 5:31 PM In reply to
    • Gretski
    • Posts 177
    • Points 2,375
    I was also dissapointed in the inport / export times on my new 7820 setup but I think the bottleneck is Quicktime which appears to use only 1 core.  MFX was much quicker.
    One thing that did make a big difference to QT  export was overclocking.
  • Sun, Sep 23 2018 5:46 AM In reply to
    • cls105
    • los angeles
    • Posts 433
    • Points 5,655
    “Importing” is obsolete.
    link then transcode, this method will use all your cores. I always have my task manager pinned to task bar so I can see my cpu usage with a click of a button.  This will show the percentage of your drives use too.  So if your drive is showing 90% obviously that’s your bottle neck. Small usb powered drives will usually max out before cpu.
    but yeah never “import” and only export using Avid processor or whatever it’s called, never using QuickTime export.
    Also your ram will be used more if you bump up you media cache, video cache settings in mc (this is just a playback tip, not ingest or export)
    MC 2018.12.1, diy x299 7940x 4.7ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
  • Tue, Dec 11 2018 12:05 PM In reply to
    • irwinpks
    • Joined on Wed, Jun 22 2011
    • Posts 74
    • Points 870
    Whatever happened to your Ryzen system(s)? ...did you get a i9-9900k?
    I'm looking to do a new build...asking about both of the above.
    AVID Media Composer 8.5 / Windows 10 Pro 64-bit / Intel i7-3820 3.6ghz, 16gb RAM, AMD Radeon HD 7700, 256gb SSD (OS & App only), 512gb SSD (Media)... [view my complete system specs]
  • Wed, Jan 30 2019 10:28 PM In reply to
    • cls105
    • los angeles
    • Posts 433
    • Points 5,655
    My latest build upgrade.
    Asus ATX motherboard in a 2u Chenbro rm24100 (the few 2u's that fit an atx board)
    14 core 7940x with 128gb ram.
    Low Profile 1080ti, and a LP 10gb nic that hooks up to my 10gb diy freenas server.
    I finally got a EKWB liquid cooling setup with a Black Ice Nemisis 480mm radiator
    I now get a 4.5ghz overclock on 14 cores!
    I'll update a picture once I have it in my 2u gator case.  The radiator will always be external, but I have qdc connectors that are quick release.  This thing will be a traveling beast!
    I'll make sure the 1k watt psu gets proper venting.
  • Wed, Feb 27 2019 10:25 PM In reply to
    • cls105
    • los angeles
    • Posts 433
    • Points 5,655
    I keep looking at the new Intel 28 core w-3175x cpu.
    That will be my next build this year.
  • Fri, Mar 1 2019 1:19 AM In reply to
    I like the original topic:
    For benchmarks I recommend we form a little sub-group of us to all use the same exact benchmarks which...great quality very high end bench marks are
    A) the same exact RED raw R3d files that we put up on dropbox or goodle drive or somehow provide a link so that we can all report the exact time from our stop watch
    B) the benchmark files at the blender website.  i. Pavellon Barcellona;  ii. Classroom;  iii. BMW27
    My system (i've always built my own) gets thoroughly pushed near it's limits with the files listed in B above
    Asus Prime X299 Deluxe II
    i9-9980XE 18 physical cores
    128GB DRAM4, Corsair at 3,400Mhz
    2TB SSD, samsung internal
    Nvidia Titan RTX (incredibly intense GPU by the way)
    I sometimes work with R3D files from my RED camera.  Or a couple of other 4K cameras.
    I received an email response from Avid (after pushing them to get me to someone that actually had the official answer)...and Media Composer will use no more than 24 physical cores but it will use all 24 if you have them.  But I can't see paying for more than 18 at this time.
    that system is a fire breathing dragon ...or should I say; a bit breathing dragon
    i9-9980XE; Asus Prime x299 Deluxe II; 128GB DRAM4; Nvidia Titan RTX; SSD 2TB [view my complete system specs]
