Latest post Tue, Apr 11 2017 4:24 AM by Mondo. 19 replies.
Page 2 of 2 (20 items) < Previous 1 2
  • Mon, Apr 10 2017 10:25 AM In reply to
    • tvsystem
    • Joined on Mon, May 19 2014
    • Posts 42
    • Points 580
    Re: Import image problem
    In your screenshot it's working properly.
    I tried to change the font, but nothing. The problem is also present in the rectangles and in the logo....
  • Mon, Apr 10 2017 11:13 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,633
    • Points 66,110
    In the import settings try to select "Scale from full range to legal" instead of "Do not modify".
    Symphony 19.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Mon, Apr 10 2017 3:29 PM In reply to
    • tvsystem
    • Posts 42
    • Points 580
    Nothing, same problem
  • Mon, Apr 10 2017 5:24 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,729
    • Points 47,770
      Moderator: MCA Mac
    There is actually nothing wrong. If you use an external monitor, you will find that when the image is played it looks correct (both fields get played). It's only when the image is paused, or when played back on the compter monitor you will see only 1 field duplicated (even in full resolution mode).
    DIY quad core I7-4790K, 32Gb, NVidia RTX 2060 Super 8, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Tue, Apr 11 2017 4:24 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    DStone:
    I agree - the problem is the interlaced project. Even playing back Avid only plays every second field - it looks better in playback because it uses duplicated field. I think if you switch to FSP it might combine fields?
    John
