Latest post Wed, May 3 2017 3:50 PM by jef. 5 replies.
Page 1 of 1 (6 items)
  • Wed, May 3 2017 12:24 PM
    Mixing DNX codecs on same timeline
    Hello,
    Is it possible to mix video footage with two different codecs on the same timeline in Avid V.8? So mixing DNX-HD 175, DNX-HD 175X and DNX-HD 36 - would there be any problems?
    Thanks!
    Michael
  • Wed, May 3 2017 1:03 PM In reply to
    Re: Mixing DNX codecs on same timeline
    Yes, no problem – you can mix these differnt bitrates and resolutions.
    HP Z-8 | Xeon 2 x gold 5118 @ 2.3 GHz (12 cores)| 96 GB RAM | NVIDIA Quadro P4000 | Win 10 Pro 64 Bit | Blackmagic DNxIQ | MC 12.1 | Symphony Option *... [view my complete system specs]
    Andy Christen
  • Wed, May 3 2017 1:06 PM In reply to
    The downside will be that when you export, a Same As Source export will be slower as it will require transcoding.
  • Wed, May 3 2017 1:16 PM In reply to
    Thanks for your response. What codec will it transcode to? What will the 'same as source' codec be?
  • Wed, May 3 2017 2:37 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 470
    • Points 5,565
    system will ask upon export.
    default suggestion is 115/120.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Wed, May 3 2017 3:50 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,375
    • Points 40,765
    Job ter Burg:
    My experience / understanding of Same As Source is different.  It may not be correct.
    I have seen and been told that if you have mixed codecs in a sequence and do a SAS export, Avid looks at the first codec and assumes that is the codec for all clips.  It then flags the resulting file as such.  But the actual media inside can be changing from clip to clip.
    When this is the case, third party aps can get very confused.  Resolve can acutally show certain clip as Media Unavailable.
    Now, this is all said as of MC 8.5.3.  I have not upgraded past there yet so things may be different.
    Also, I am NOT describing what happens in an AMA File Export.
    So it would be good to find out what is really going on here.
    Jef
    Jef Huey
