Latest post Wed, Oct 10 2018 3:26 PM by DStone. 6 replies.
Page 1 of 1 (7 items)
  • Tue, May 9 2017 2:59 PM
    • BoomRob
    • Joined on Wed, Mar 9 2011
    • Posts 5
    • Points 75
    Enable GPU
    Since render bug in 8.7 I found a script on the avid website that disabled GPU. I have since upgraded to 8.8.2. On MC start I see message GPU disabled. Can not find documentation on how to enable GPU. Any help appreciated.
    MC 8.8.2
    HP 840
    Intel Xeon ES-2660 v3 x2
    64 Gig RAM
    Windows 10 Pro version 1607
    Quadro M4000
    NVidia Tesla
  • Tue, May 9 2017 3:26 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,459
    • Points 44,560
    Re: Enable GPU
    Goto Settings->Render to bring up the render dialog. There's a checkbox there to disable GPU effects. Uncheck it.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Tue, May 9 2017 4:10 PM In reply to
    • BoomRob
    • Posts 5
    • Points 75
    Re: Enable GPU
    I have tried that. The box is there and it is checked but, it is greyed out. I can not click it.
  • Tue, May 9 2017 9:09 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,459
    • Points 44,560
    Re: Enable GPU
    Exit MC and delete the file ​C:\Program Files\Avid\Avid Media Composer\DisableGPU.txt. Start MC and you should be able to change the checkbox.
    Dave S.
  • Wed, May 10 2017 2:58 PM In reply to
    • BoomRob
    • Posts 5
    • Points 75
    Re: Enable GPU
    Thank you very much for your help! Promblem solved!
  • Wed, Oct 10 2018 11:54 AM In reply to
    Re: Enable GPU
    I know this is quite old, but I have the same problem here, and I cannot find a solution since I am on a MAC. I am on Avid MC 8.6.3 and my system is a Mac OS HIGH SIERRA, 16 GB RAM, AMD Radeon R9 M370X
      Type: GPU
      Bus: PCIe
      PCIe Lane Width: x8
      VRAM (Total): 2 GB
      Vendor: AMD (0x1002)
      Device ID: 0x6821
      Revision ID: 0x0083
      ROM Revision: 113-C5670E-945
      VBIOS Version: 113-C567A1-006
      EFI Driver Version: 01.00.945
      Automatic Graphics Switching: Supported
      gMux Version: 4.0.20 [3.2.8]
    Could you please help and guide me to UNCHECK DISABLE GPU EFFECTS?
  • Wed, Oct 10 2018 3:26 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,459
    • Points 44,560
    Re: Enable GPU
    Go to the Project dialog box (this is the one with the Bins, Volumes, Format etc. tabs). Click on the Settings tab. Scroll down to Render and click on it. There's where you'll find the Disable GPU button. If you can't uncheck it, look for a file called DisableGPU (may or may not have an extension on it for the Mac) in the same directory where Media Composer is installed and delete it.
    Dave S.
