Latest post Sun, Dec 17 2017 9:40 PM by twstew. 14 replies.
Page 1 of 1 (15 items)
  • Thu, Jul 13 2017 3:02 PM
    • rocketman7
    • Joined on Tue, Jul 11 2017
    • Posts 6
    • Points 90
    Install issue: "Your system does not support this version of Media Composer. Please consult the Specifications information..."
    Cannot get Media Composer First to install.
    Everything will install untill it the application manager. Then it will get a popup error: "Your system does not support this version of Media Composer. Please consult the Specification information ....."
    My syste is running Windows 10 Pro 64-bit and has 16 GB of memeory.
    All drivers are current (as far as I can tell).
    Need some help on getting this to install
    DIY AMD Phenom II X4 955 Processor, 16GB, Radeon HD 5450, Win 10 Pro [view my complete system specs]
  • Thu, Jul 13 2017 3:15 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,567
    • Points 45,810
    Re: Install issue: "Your system does not support this version of Media Composer. Please consult the Specifications information..."
    We need a bit more information in order to help you. What system (PC or Mac), CPU, Graphics Card, etc. Please look at the bottom of this post for an idea of what we're looking for.
    Dave S.
  • Thu, Jul 13 2017 3:43 PM In reply to
    • rocketman7
    • Posts 6
    • Points 90
    My system is DIY AMD Phenom II X4 955 Processor, 16GB, Radeon HD 5450, Win 10 Pro
    I downloaded the file Media_Composer_First_8_8_5_Win_97990_.zip from the Avid site, unzipped and ran the setup.
    As I said, everything seems to install until it gets to the final install of the applications manager.
  • Thu, Jul 13 2017 6:17 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,833
    • Points 20,230
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    rocketman7:
    Please refer to this earlier post. FAQ
    RalphC
  • Thu, Jul 13 2017 7:01 PM In reply to
    • rocketman7
    • Posts 6
    • Points 90
    I had seen the earlier post and as I said, all relevent drivers are up-to-date.
    If there are specific drivers to check let me know.
    From the FAQ and then the qualified systems, I only see pre-built systems and ALL are Intel based. I do not see any AMD based systems. I also see that you want SSE4.1 which I think is only an Intel supported thing.
    If you are really only targeting the Intel based systems, you should have said that in the requirements. Also the requirement said nothing about the SSE4.1 support.
    At this point I just need to know how to uninstall that other items that were installed by your setup so they will not take up space.
    Please provide a list of all the programs that this would have installed.
    Also, until you actually support non-Intel platforms, you need to state that on the requirements and main page.
    If you ever decide to support the other half of the PC market, let me know I might give this a try then.
  • Thu, Jul 13 2017 7:39 PM In reply to
    • Posts 10,214
    • Points 218,160
    Rocketman
    What I want you to do is remove MC First.   Then downlaod MC 8.8.5.  Then immediately uninstall it using the UNISTALLER.
    Then install MC First and it shoud work
  • Sat, Jul 15 2017 2:04 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,322
    • Points 53,440
    It is not a matter of drivers, It is hard coding within the microprocessor, referred to as SSD "instructions" That AMD processor does not have those instructions.
    This is not unique to Media Composer. New versions of Edius also will not run on older AMD CPUs.
    The new AMD FX series work just fine
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Sat, Jul 15 2017 3:24 PM In reply to
    • rocketman7
    • Posts 6
    • Points 90
    NSS. As a computer architecture expert (Master of Science in Electrical Engineering from Stanford specilty in computer architecture and orginization and more then 25 years as a system design engineer with many different processors including Intel and AMD), I know that SSE are micro-coded instructions and that until the latest FX part, AMD did not support this.
    My issue is that Avid did not have this as a system requirement and effectily is limited to Intel based systems.
    I am not about to build a new system just to run "FREE" software when I can run many other products including many other free editors that have not limited their market.
    I need to know how to get this uninstalled as I do not see an uninstall option.
    If there is not an uninstall, I need to know what all was installed (all programs and support files) so I can remove them.
    If Avid ever decides to support all the PC market (or if I ever build a new system) I might consider installing this then.
  • Sat, Jul 15 2017 7:59 PM In reply to
    • RalphC
    • Posts 1,833
    • Points 20,230
      Avid Employee
    rocketman7:
    It never got installed in the first place. Normally all temp files a remove/rolledback when installation aborted.
    RalphC
  • Sat, Jul 15 2017 8:38 PM In reply to
    • rocketman7
    • Posts 6
    • Points 90
    RalphC,
    I might agree except there were new icons added to my desktop, items added to the start menu and I see several other items that were installed the same days I tried to do the install. Given that, it did NO cleanup or rollback anything.
    That is why I need a list of what would be installed so I can remove them.
  • Sat, Jul 15 2017 8:45 PM In reply to
    • RalphC
    • Posts 1,833
    • Points 20,230
      Avid Employee
    What's the icon's name? items name on the start menu?The start menu should have "AVID" icons should name Avid Media Composer First and AppMan or Application Manager.
  • Sat, Jul 15 2017 9:05 PM In reply to
    • rocketman7
    • Posts 6
    • Points 90
    There is an icon for "iLok License Manager" but do not see this in the installed programs.
    In the start menu, there is the Avid entry and then Applictaions manager.
    In the installed programs, there are several installed the same day I first tried, including: PACE License Support Win64, Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.40660 and an (x64) one - 12.0.30501, and Sentinel Protection Installer 7.6.6. Not sure which of these were from the Avid installer.
    These are the ones that I can see. Not sure if there were others that might be in the background (just saying).
  • Sat, Jul 15 2017 9:57 PM In reply to
    rocketman7:
    Have you looked in the Program Files (x86) folder? For me (not from a MC \ First install) the iLok License Manager does not show in All programs from the Start menu but does show up in the Program Files (x86) folder which is where I usually start it from.   (W7 64 Pro SP1)
  • Sun, Jul 16 2017 12:22 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,322
    • Points 53,440
    A system-wide search in Windows Explorer for files of type *.exe with a Created Date of, say, the last month or so will tell you which new executable files have been created in that time.
  • Sun, Dec 17 2017 9:40 PM In reply to
    • twstew
    • Joined on Sun, Dec 17 2017
    • Posts 1
    • Points 5
    Just out of curiosity, is it just SSE* that is the issue? I think the X4 955 supports most SSE versions. My 940 does. And I still get this error at install.
