Latest post Sun, Aug 27 2017 11:39 PM by jef. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Aug 14 2017 8:58 PM
    • SR555
    • Joined on Mon, Oct 28 2013
    • Posts 218
    • Points 2,455
    How to automatically highlight bin field when logging
    A little (but big) thing that is driving me nuts:
    I am logging several thousand clips to choose selects.   The workflow is:
    1)arrow-select clip in bin
    2) Control-enter to open in source window (I"m on a mac)
    3) Space bar to play and stop
    4) Command-tilde ~ to toggle window to make the bin active again
    5) Click in the "scene" column field to make a clip note
    6) Enter, to 'set' the comment and go to the next clip, or tab to go to next column to mark it with an x as a select (or esc if something is just selected, to deselect it so I can arrow)
    7) Arrow to next clip and repeat 1-6.
    Here's the question.   Step #5 is a major hassle having to do it for each clip, with the mouse.   Can this step somehow be eliminated?  Is there a way to have the fields auto-highlighted in the bin when switching back to it, so I can just tab over to the scene column?  Or to press a key that would highlight it so I don't have to mouse click it?
    Tab does not work, and nothing else seems to either.
    Thank you
    Avid Media Composer 7, Macbook Pro Retina, Mountain Lion [view my complete system specs]
    Filed under: ,
  • Mon, Aug 14 2017 10:01 PM In reply to
    • TrevorA
    • Posts 1,142
    • Points 12,925
    Re: How to automatically highlight bin field when logging
    I think step 4 could be 'find bin' then step 5 should be enter (should go into entry mode on name I think) then tab across to your scene column.
    Pretty sure that the 'enter' behaviour varies between versions/platforms though.
  • Mon, Aug 14 2017 11:01 PM In reply to
    • SR555
    • Posts 218
    • Points 2,455
    AAUGH!  It won't do it on mine. Darn it.
    I tried find bin (shift-1 on my system) from the source window, and it does highlight the clip, but enter brings the source window back up.
    Thanks Trevor for your reply though.
    note: added 'find bin' to the workflow and it does make things faster even if it doesn't solve the highlight issue. so thx
  • Tue, Aug 15 2017 1:13 PM In reply to
    • SR555
    • Posts 218
    • Points 2,455
    So at this point, is the consensus that there is no workflow that will auto-highlight those fields or highlight them with the keyboard?
    thx
  • Wed, Aug 16 2017 3:03 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 224
    • Points 2,370
    Try a macro progra, I use keyboard maestro, the others I know of are quick keys and quadro running on an iPad.
    its well worth the effort to get around these repeated tasks in the user interface.
    in  keyboard maestro you use the coordinates of X and Y on the screen to  click the mouse,  there is a little trick with putting the bin in the same place in the interface and making the bin small so the click is consistently in the right place.
    i am happy to send the relevant macro if you try keyboard maestro
    M
  • Wed, Aug 16 2017 3:18 AM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 224
    • Points 2,370
     If you want to see the power of macros watch this YouTube from Avid supergrouper for multicam grouping using quick keys
    https://m.youtube.com/watch?v=MK4FAcF5Kp0
  • Wed, Aug 16 2017 3:43 AM In reply to
    Maybe think about a different way of logging by using Markers.  This works for me.
    I keep my source footage in a single bin for each Source.
    Then sort the bin on start time.Put all those clips in a Timeline in this bin and renamed to be identifyable with the Source media,
    With this timeline in either Source or Record monitor scroll through the timelin adding a marker roughly in the middle of and point of interest in each clip.   (Add Marker mapped to my keyboard)
    Add logging info to each Marker in the Comments column and press Enter in the numeric keypad to close marker window.
    When all markers are added  Open the Markers window (Open markers mapped to my KB and under both Source and Record monitors.
    Print markers gives me a printed copy of the logged footage.
    I can then duplicate this timeline. Open in the Record monitor and cut out of it any parts I do not want. (Selects timeline for this source) Then use this cut down timeline as my source. The TC on all the markers reflect the TC  of the shortened timeline. (Maybe print this timelines Markers out.
    Toggling between Source and Record lets me edit from a Source timelines with Markers rather than clips. The marker comments are visible on the clips.
    FWIW mapping Go to Previous and Go to Next marker to the KB lets me rapidly move through a source timeline with the Comments showing as I go.
  • Wed, Aug 16 2017 10:43 AM In reply to
    • TrevorA
    • Posts 1,142
    • Points 12,925
    The only way I can get a bin highlighted for entry is to 'create subclip' then return / tab to get to the required clip & column. The idea of having the bin in a fixed position for keyboard maestro to use in a macro would not work for me!
  • Wed, Aug 16 2017 1:45 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,216
    • Points 14,725
    I second my editor pairs here, it would be great to have two different actions from the keyboard on the Return and the Enter keys.
    When you're in highlight mode on a clip name, Return takes you to the next clip name, whereas Enter validates the clip name you typed and selects the clip.
    Would be neat to be able to return to Edit The Clip Name by pressing the Return key (or Enter, whichever) directly from a selected clip.
  • Sat, Aug 19 2017 3:31 AM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 224
    • Points 2,370
    TrevorA:
    to be clear, the bin does not have to be in a fixed position, but the mouse click is positioned relative to the bin, say 60 pixels from the top of the bin, to target the clip.
    So the macro sequence looks like this: find bin- mouse click.
     If you set the bin height small, the find Bin command always highlights  the clip in the same position  in the bin. Then the programmed click will work.
  • Sun, Aug 27 2017 9:26 PM In reply to
    • SR555
    • Posts 218
    • Points 2,455
    Hi all, jsut geting back to this project.   I'll test these out.  Thank you!
  • Sun, Aug 27 2017 11:39 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,409
    • Points 41,145
    Not sure if this would be any help (not in front of machine), but ...
    what if you made a special bin setting with ONLY the column you want to mod.  Then Find in Bin might get you where you want.
    Or not.  Will try tomorrow ....
    Jef
    Jef Huey
