Latest post Mon, Sep 25 2017 9:20 AM by tommix. 4 replies.
  • Tue, Sep 19 2017 5:40 PM
    • Tom Cook
    • Joined on Sun, Apr 25 2010
    • Keene, NH
    • Posts 180
    • Points 2,290
    Why can't I Resize a 4K image without break-up?
    Folks:
    I recently purchased a JVC GY-HM170U 4K camcorder. While it seems to record wonderful images, I have found that when editing I cannot push in on the image any further than I sued to be able to with regular old standard resolution images. I had thought/hoped that I would be able to push in quite a ways with a 4K image.
    I record in AVCHD files, transfer those to my drive, then Link using Source Browser in Avid Media Composer. But when I Resize those images, they start to break up at only 140%... I tried directly importing the same file (instead of Source Browsing) and got the same effect.
    Thoughts? Suggestions? Thanks, as always.
    Tom
    Dell XPS720, quadcore 3.6 GHz, 28 GB RAM, Avid Media Composer v8.7.2 [view my complete system specs]
    Filed under: , ,
  • Tue, Sep 19 2017 8:11 PM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 587
    • Points 7,000
    Re: Why can't I Resize a 4K image without break-up?
    How are you doing the resize?
    You should be using FrameFlex which is available in the Source Settings (right-click on the clip in the bin) or once you've edited a clip into the timeline the FrameFlex effect will be available in the Effects Editor for clips that are larger than the project raster.
    8.5 on a mongrel PC, Win 7, QT7.5, Nvidia GTX 970, 16Gb RAM, SSD, NAS for raw media and a Macbook Pro [view my complete system specs]
  • Tue, Sep 19 2017 8:12 PM In reply to
    • gumbycat99
    • Posts 587
    • Points 7,000
    Sorry I just realised you're using MC First, so I don't actually know if this is the same as regular MC.
  • Tue, Sep 19 2017 9:12 PM In reply to
    • Tom Cook
    • Keene, NH
    • Posts 180
    • Points 2,290
    But I'll check it out. About all I've used Frameflex for thus far is reformattijng media that gets imported at the wrong size... Will try it, thanks!
  • Mon, Sep 25 2017 9:20 AM In reply to
    • tommix
    • Joined on Tue, Oct 14 2008
    • Posts 207
    • Points 2,545
    Tom, when I've IMPORTED 4k I see it is always downscaled to FHD which seems to preclude reframing a UHD image into an FHD image.
    I have assumed that if I LINKED to a UHD file the imported would have to be UHD--so zooming in would work using a keyframed Resize FX. Please post what you learn.
    Steve Mullen
