Latest post Mon, Mar 26 2018 8:31 PM by anamorphic. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Sep 28 2017 10:40 PM
    • anamorphic
    • Posts 99
    • Points 1,255
    Breakout box suggestions?
    My Matrox MX02 mini was rendered obsolete by El Capitan.  I'm looking at the MOTU HD Express as a replacement.  Has anyone had experience with that equipment or success with another?
    I'm on MC 8.9.1
    MacPro 2x2.4 GHz Quad-Core Intel Xeon / 64 Gig RAM / OS 10.11.6 / MC 2018.3, Symphony, PhraseFind, ScriptSync, BCC 8 AVX; Mocha [view my complete system specs]
  • Fri, Sep 29 2017 9:20 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,214
    • Points 14,695
    Re: Breakout box suggestions?
    It all depends on your work. If you're mainly doing HD, you should try to get a second hand Mojo DX or Nitris DX (noisier but more connectors), it has built in drivers and is the most stable/enjoyable with Media Composer.
  • Fri, Sep 29 2017 9:32 AM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Aberystwyth, Wales
    • Posts 441
    • Points 5,105
      Avid Certified User
    I lean towards the Blackmagic boxes at the mo because I find Resolve to be an invaluable addition to the suite so the ability to have broadcast monitoring from it is a big plus.
    MC Symphony 8.8.5 on MacPro 3GHz 8-Core Xeon 12GB RAM, OS 10.12.6, Blackmagic Ultrastudio 4K MC Symphony 8.8.1 on iMac [view my complete system specs]
  • Fri, Sep 29 2017 10:39 AM In reply to
    Big downside of the BMD boxes is that they don't do proper 5.1/7.1 channel mapping over HDMI. The Avid branded version of the BMD boxes have this covered, though.
  • Fri, Sep 29 2017 11:05 AM In reply to
    • fsm
    • Joined on Tue, Nov 24 2009
    • Germany
    • Posts 161
    • Points 1,975
    i was a MOTU HDX SDI user, i sold this box as MC 7.x came out. its solid on MC 6 but newer MC versions caused dropped frames. they arent update their drivers, the actual driver is from 2012-10-30. the max resolution is 1080p30/i60, no 4K, no 50p/60p in HD. so if u ask me: NO, DONT BUY A MOTU IO for an actual Avid MC system. on a windows system i'll recommed the BM IO hardware. dont know about their mac performance.
    MC 2018.5 & SYM / BM Monitor4K / Windows 10 prof. 64 bit / i7 3930k / Quadro M4000 [view my complete system specs]
  • Fri, Sep 29 2017 8:04 PM In reply to
    • anamorphic
    • Posts 99
    • Points 1,255
    Thanks to all for your insights!  I'm sure more info on my workflow would have helped, sorry!
    I edit from my home.  90% of the footage I work with is offline (HD) and I leave the finishing to others.  I just need a card to playback to my client monitor.  Although I do a fair amount of 5.1 mixing out of Media Composer, so that is a consideration, HDMI-wise.
    MOTU support wrote me back to say that the HD Express does not support El Capitan, so that's that.
    I'm leaning toward the Blackmagic Intensity Pro 4K, which is simple enough for my needs and appears to support embedded HDMI audio.
  • Sat, Sep 30 2017 7:58 PM In reply to
    Again, if you're doing 5.1, that's an issue with the BMD's (although the Avid-branded versions have it right). Simply put, it center and LFE are reversed. If you go straight into an HDMI preamp, you may not be able to correct for that.
  • Sat, Sep 30 2017 11:47 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,373
    • Points 40,745
    One other option to consider:  AJA
    They built their rep on superior engineering and customer support.  More expensive but worth it if you value support.
    But ....
    BMD has really cut their legs out from under them with Resolve free.  I worry how long AJA will be able to stay in the IO market.
    If all you are doing is feeding a broadcast monitor, BMD can be ok.  And they are cheap enough that you can spend extra money to address the HDMI 5.1 issues in other inventive ways.  Just don't expect the amazing support that you get with AJA.
    Jef
    Jef Huey
  • Mon, Mar 26 2018 8:31 PM In reply to
    • anamorphic
    • Posts 99
    • Points 1,255
    btw, thanks, you're absolutely right about the center and Lfe channel swapping with the Blackmagic card.  Their technical support told me THEIR way was industry standard for SDI.  I (and others) have suggested their MacOS Blackmagic Desktop Video System Preference control panel should have the ability to reassign audio channels.
    It's not a problem with Digital Performer (my music software) because I can reassign the channels in the app.  Avid, however, does not let me reassign so I can not edit/mix in surround.  Silly.
