Latest post Thu, Oct 12 2017 3:54 PM by Marianna. 3 replies.
  • Tue, Oct 10 2017 9:55 PM
    • C-King
    • Joined on Tue, Sep 6 2016
    • Posts 22
    • Points 350
    Script search not searching all scripts
    Running MC 8.9.2 on Mac Pro running 10.11.6.
    Working on a sprawling doc project with 100ish hours of interviews and more to come, all transcribed and scripts imported.
    When I keyword search "Current Script" for "Script A" I get multiple hits, but when I search "Scripts in Project", "Script A" doesn't come up, and nor do several others which I know to contain the keyword.
    Is there anything I can do to get it to re-index the scripts without also reindexing the Phrasefind index, which takes a looong time?
    C King
    MC 8.9.1 on 8-Core trashcan Mac Pro, 32GB RAM, 10.11.6, G-RAID Studio XL TB2 RAID MC 8.9.1 on tbMPB15, 16GB, 10.12.4 [view my complete system specs]
  • Wed, Oct 11 2017 3:28 PM In reply to
    • Posts 8,557
    • Points 111,680
    Re: Script search not searching all scripts
    C-king......
    In each Project folder, you shoud see a folder called SearchData which contains a file called _SearchDB_.
    This file is the database of the indexed bins within your project.
    If you have ScriptSync activated, which you do, you should also see a folder called PhoneticData which contains a number of files with a .pat extension; these files contain the phonetic information for each of the audio clips within your project. One .pat file will be created per clip.
    I suggest you delete the _SearchDB_ when MC is NOT running and restart and let SS redo your search.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Oct 12 2017 3:23 PM In reply to
    • C-King
    • Posts 22
    • Points 350
    Thanks Marianna-
    I did that, and waited until the Bin Index light in the search window was all the way green, and repeated the search. This time I used a term that appears in all or nearly all of the 20+ scripts in the project, but only 9 were found in the search. Is the bin index light a reliable indicator that it has finished indexing? Activity monitor shows AvidBinIndexer to be running, but at less than 1% CPU. Meanwhile AvidPhoeneticIndexer seems to run nonstop (200%+ CPU) but never seems to finish, even left running overnight or weekend, and seems to be creating new .pat files for clips that were ingested nearly a year ago.
    Any thoughts? It would be great to be able to have more control and information about the indexing process; for example, to choose which bins I need Phrasefind to index, and a list of which bins/scripts have been indexed.
    Chyld King
    Edit to add: It does find the terms if I search the missing scripts individually; just not in "Scripts in Project" (which would be more helpful).
  • Thu, Oct 12 2017 3:54 PM In reply to
    • Posts 8,557
    • Points 111,680
    Chyld
    Weird as the light shoud be reliable - let me gab with the engineering guys on this one and get back to you soon.
