Latest post Tue, Nov 27 2018 2:46 PM by caner. 41 replies.
Page 3 of 3 (42 items) < Previous 1 2 3
  • Tue, Jul 3 2018 6:38 PM In reply to
    • BlueMac
    • Joined on Wed, Apr 30 2008
    • Posts 5
    • Points 65
    Re: Questions RE: "How Avid Media Composer Uses a Computer"
    Actually, I have had personal experience on how much GPU acceleration affects Media Composer...
    When upgrading from 8.3.1 to 8.5.3 there was a new requirement for RAM needed in the GPU for AVIDs ACPL library (which is a big part of how Media Composer utilizes GPU).  We suddenly had all our BorisFX CCC plugins take about 100 times longer to render.
    Should one wish to see the effects on performance, I can suggest you disable ACPL as outlined in the following KB article:
    http://avid.force.com/pkb/articles/en_US/how_to/Disabling-ACPL-GPU-Acceleration-for-Media-Composer-on-Windows
    Apparently there is no noted proceedure on how to do this in MacOS, but I suppose you could temporarily replace your GPU with one that has insufficient RAM for Media Composer to load ACPL.  This is variable based  on Media Composer version, but if your running anything v8.5.3 or above, you need at least 1.5GB of RAM (this requrement increases along the way in more recent versions).
    Find a GPU with 1GB of RAM and you will be able to verify that "This card is not supported" in the Info tab of the Project window.
    Dave Hogan
    Burbank, CA
  • Tue, Jul 3 2018 7:04 PM In reply to
    • flashavid
    • England
    • Posts 307
    • Points 3,800
    I noticed absolutely no difference swapping my 1GB HD5870 to an 8GB RX580 - apart from the message changing from "you don't have enough GPU memory" to "GPU FX acceleration is enabled" .
    But then I don't have any Boris FX anymore - is that all that takes advantage of GPU ?
    MC 8.9.2 Symphony - MacPro 2.66Ghz 12core 48GB ram - OS 10.12.6 - BM 4K Extreme - Sapphire pulse RX580 8GB -SSD boot - 3 x 2TB internal WD caviar black... [view my complete system specs]
  • Tue, Jul 3 2018 8:00 PM In reply to
    • BlueMac
    • Posts 5
    • Points 65
    It would be helpful to know some other system specs, and work flow.  What version of MC are you running?  What kind, frame rate and resolution of media are you using?  Are you using much in the way of real time FX (Keys, Timewarp, etc.)?
    If editing DV footage, cuts only, one shouldn't notice any difference at all.
    If editing AVCHD 4K footage with tons of effects you should see a dramatic difference.
    Dave Hogan
    Burbank, CA
  • Tue, Jul 3 2018 9:40 PM In reply to
    • flashavid
    • England
    • Posts 307
    • Points 3,800
    All my system specs are listed below.
    my particular experiences have been with spectramatte keying, a realtime effect. Key will playback fine until a matte blur/erode/dilate is applied, then playback becomes choppy.
    DNxHD120 media 1080 25p
    this used to work fine in previous versions of MC, but I noticed around the time of moving to MC 8.9.2 it didn't work anymore, the info tab was telling me my GPU had insufficient memory - so I spent some time working out the best replacement GPU options - now it tells me GPU acceleration is enabled, but no improvement is experienced.
    this is why it would be great to have more information from Avid about what GPU acceleration actually is, and how it works.
  • Thu, Jul 5 2018 12:52 PM In reply to
    • BlueMac
    • Posts 5
    • Points 65
    There are a couple things I would investigate if I were in your shoes.  First of all I would try the Nvidia Web driver for your current version of OS.  There are sub versions, which you can determine by clicking on the MacOS version in the "About This Mac" window.  Then check to see which Nvidia Driver is compatible, on macvidcards.com/drivers.  The following is a link, and descrbes determining the sub version of MacOS you are running:
    http://www.macvidcards.com/drivers.html
    If you have done this already, I suggest switching between the Nvidia Web driver and the OS X default graphics driver to see if that makes any difference.
    The second area I would check is to see if your CPUs are compatible.  Though you indicate your system specs are in your forum signature, that doesn't come through in the e-mails I received or in the reply dialogue.  Logging into the forum I see that you have a MacPro 2.66Ghz 12 core.  Is that a Mac Pro tower or the cylinder (trashcan).  I assume it has to be a Tower, since you were able to swap out GPUs, but which one (what year release, and is it a MacPro 5,1, 4,1 or 3,1)?  Several of the 12 core CPUs have had issues with Media Composer software and are not certified to work properly with it.  Here is the Mac system requireents:
    http://resources.avid.com/supportfiles/attach/Mac_Current_CPU_Specifications.pdf
    It indicates that only the Westmere 12 core 2.66Ghz cpus are compatible.  Additionally, I would check that your ram is 1333Ghz ram, not 1066Ghz ram, and that they are all matched the same size, brand and lot.
  • Fri, Jul 6 2018 7:00 AM In reply to
    • flashavid
    • England
    • Posts 307
    • Points 3,800
    I'm not using an Nvidia card - it's an AMD Sapphire Pulse RX580 8GB - I got this because I didn't want the hassle with the Nvidia drivers
    this machine was bought, is used, and has been upgraded specifically for Avid Media Composer - so the CPUs have been qualified for years - 6x8GB matched 1333 Ghz RAM etc - it's a mid 2010 5.1 tower, all by the book, apart from this GPU
    this is a dedicated work machine, very clean system, hardly ever connected to Internet - I've spent a lot of time trying to make the correct upgrade decisions.
  • Sat, Jul 7 2018 2:08 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,328
    • Points 53,495
    I have noted over the years that a high clock speed CPU is preferable over core counts for MC.
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Fri, Aug 24 2018 11:06 PM In reply to
    • cls105
    • los angeles
    • Posts 438
    • Points 5,700
    Media Composer will use 100% of cores when transcoding linked files and ama file export.  It's the greatest feeling to see 14+ cores at 100%.
    But not when rendering (at least most of the time).
    Are there plans to improve this in the near future?  Rendering could go so much faster with more core usage.
    Consumer cpu's have 6+ cores now, and soon will be hitting 8.
    I don't even care about real time fx, I dont mind rendering, but seeing more core usage (with or without gpu acceleration) when rendering would definitely help.
    MC 2018.12.1, diy x299 7940x 4.7ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
  • Wed, Nov 14 2018 10:11 PM In reply to
    Good to see on your computer usues all the HW. What kind of files are you transcoding? Here with 4K RED files it only uses 40% of the CPU and 7.5% of the GPU, Premiere is it ten times faster with RED files
    HP Z840 Windows 10 Samsun 840 SSD 128 GB Ram GFORCE GTX Titan Black 160 TB DDP over 10GigE [view my complete system specs]
  • Mon, Nov 26 2018 1:49 PM In reply to
    • caner
    • Joined on Mon, Nov 26 2018
    • Posts 2
    • Points 20
    Hi Chris,
    Thank you for all the effort and the guide, it is a great work.
    I have passed read through all of it, as well as all the messages in this post, and looked it up for a while. However, couldn't find the information I have been looking for. Maybe you or other users know it.
    Do you know if MC requires more computer resources at the latest releases compared to older ones? For instance does MC 8.5 require more CPU, memory, GPU compared to MC 6.5?
    Thanks in advcance!
    Caner
  • Mon, Nov 26 2018 6:21 PM In reply to
    • Pixel Monkey
    • Posts 1,246
    • Points 15,765
    I haven't seen too many individual processes inside of MC that use more or less of the computer between MC 6.5 and MC 8.2.x.
    However yes indeed, once MC8.3.x came out, and certainly all of the incremental releases since they switched over to the MC 2018.x naming structure. Some of that has to do with MC's lessening dependence on QuickTime for its AMA linkages, but mostly in the efficiencies behind the processes. For example, if you compared the overall Memory Pressure and bandwidth usage of MC2018.5 to that of MC6.5, you would see a LOT less memory being used by MC. However that "savings" go down a bit once MC2018.7.1 came out, which added the "Live Timeline" feature. That feature alone saw such a dramatic hit to the bandwidth usage, that it forced the engineers to de-list ALL silver MacPro models from Avid's qualified machine list.
    Does that answer your question? I know I can only speak in broad terms, not being an engineer myself.
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
    WWLD (What Would Larry Do?)
    WWND (What Would Norman Do?)
  • Tue, Nov 27 2018 2:46 PM In reply to
    • caner
    • Posts 2
    • Points 20
    Hi Chris,
    Thanks for the reply, that's what I asked. Will use your guide for the rest.
    Kind Regards,
    Caner
