Latest post Mon, Aug 13 2018 10:35 PM by Sam Beckett. 12 replies.
Page 1 of 1 (13 items)
  • Wed, Oct 25 2017 1:41 AM
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,340
    8.9.2 Timeline track audio level adjustment bug?
    Just noticed this one - anyone seeing this?
    • Park the playhead on a clip in the timeline
    • Open the Audio mixer or add a keyframe or open the mini mixer from the timeline (mono track in this case)
    • Adjust the level on the track
    • Play the timeline - audio level hasn't changed but the display correctly shows a new level line and value (-30dB in this case)!
    Restart Avid, problem goes away for a while.  Turn off and then turn on the audio track (not arm/solo etc) and problem goes away for a while.
    I haven't got an exact recipie for how to replicate this!  I know that the clip level line reflects the changes you have made, only the actual playback seems un-affected.  Restarting Avid and the level you set that previoulsy wasn't working is now working and displaying correctly... wierd.
    MC8.10 Win 7 64 with Dongle, Dual 10 core Xeon, Quadro K4000, Adaptec RAID 5-8x3TB, External TB2 4x3TB, 64G RAM, BM Intensity Pro 4K. NewBlue Titler 6... [view my complete system specs]
    Vote 1 - Dongles.
    UME an old engine, now with 4K, mags and furry dice....
  • Wed, Oct 25 2017 7:12 AM In reply to
    • fkurz
    • Joined on Wed, Jan 23 2008
    • Posts 31
    • Points 380
    Re: 8.9.2 Timeline track audio level adjustment bug?
    I also noticed that behaviour in MC 8.8.5 and I also have no exact way to reproduce the bug it happens occasionally. Closing and opening the bin with the sequence solves the problem for me.
    regards
    Florian
    Avid MC 2018.2 symphony option HP Z820 Win 7 64Bit, SP 1 Mojo-DX Interface [view my complete system specs]
  • Wed, Oct 25 2017 10:55 AM In reply to
    hi to all,
    we have a similar problem with audio in version 8.9.2.
    Is there already a ticket at avid?
    reagrds
    rolf
  • Wed, Oct 25 2017 3:30 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 183
    • Points 2,180
    I noticed this yesterday in 8.9.1
    In my case I was working with AMA linked media that was grouped for multicam.
    I cranked the gain up using the mixer and rolled the playhead back a little but the actually level didn't increase.
    I repeated the step and the same thing occurred. Next I just left the playhead where it was and then adjusted the level and then played and the level was as loud as it should be...however, moving the playhead back a little and the level returned to being lower again. The mixer still showed the level being set much hotter.
    Later I committed all the multi-cam edits and transcoded the media and it worked ok.
    MC 2018.4 Dell Precision 7710 mobile workstation, 64GB of memory, Xeon E3-1535M v5 @2.9Ghz, Nvidia Quadro M5000m. Running Win10 64bit. MC 2018.5 Asus... [view my complete system specs]
  • Wed, Oct 25 2017 3:59 PM In reply to
    • Posts 9,905
    • Points 214,275
    Creating a case now. #   03317963
    Erik can you email me your email address?
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Wed, Oct 25 2017 8:40 PM In reply to
    • Erik
    • Austin, TX
    • Posts 183
    • Points 2,180
    Done.
  • Wed, Oct 25 2017 11:09 PM In reply to
    • rksak66
    • Joined on Wed, Oct 25 2017
    • Posts 1
    • Points 15
    Hi.  Have you heard back with a fix?  I'm having the same issue.
    Thanks.
  • Fri, Oct 27 2017 7:40 AM In reply to
    • Gretski
    • Posts 167
    • Points 2,240
    Same issues using clip gain.  Just reloading the sequence will clear the problem.
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
  • Fri, Oct 27 2017 8:33 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,340
    It is logged as a bug, they are aware of it... Fix ETA, who knows. Vey anoying when doing a audio session on a project...
    Vote 1 - Dongles.
  • Tue, Oct 31 2017 12:39 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,340
    Bump
    Can't see anything in the readme that this is addressed in 8.9.3 Can anyone confirm if it is still an issue?  It's probably too soon a release to expect a fix in this release but here's hoping.
    Vote 1 - Dongles.
  • Tue, Oct 31 2017 12:13 PM In reply to
    • Posts 9,905
    • Points 214,275
    Carigmi
    Checing but I dont think a fix was completed yet and rolled in.... checking.
  • Thu, Jul 5 2018 3:49 PM In reply to
    • Roy
    • Joined on Wed, Mar 7 2012
    • Manchester
    • Posts 8
    • Points 120
    I'm at a post house using 8.9.3 and this bug is driving me mad. Almost every time I adjust audio levels in the timeline, they don't actually work - reloading the seq fixes it. What version do I need them to move to to fix this, or is there a way to work around it if they won't update all the suites?
    Custom build Ryzen 7-1700x 8 core 16GB Ram Avid MC 2018.5 Decklink Mini Monitor I/O 1TB SSD 6TB Raid 10 HDD [view my complete system specs]
    Roy Gilbert
    Avid offline editor
    www.avidoffline.co.uk
  • Mon, Aug 13 2018 10:35 PM In reply to
    We're on 8.9.4 and also experiencing this issue.  I added a keyframe to an audio clip and adjusted the volume, and then I used the Audio Mixer to further modify it, but nothing appeared to actually happen.  Removing the keyframe and closing/re-opening the bin seemed to refresh it to start working again.
    Mac Pro Tower (Mid-2010), 2x2.66 GHz 6-core Intel Xeon, 24 GB RAM, NVIDIA GeForce GT 120 512 MB, OS 10.12.6, MC 8.9.4 with Nitris DX [view my complete system specs]
