Latest post Tue, Aug 14 2018 7:28 AM by bferah. 32 replies.
Page 1 of 3 (33 items) 1 2 3 Next >
  • Wed, Nov 8 2017 1:48 PM
    • Qburak
    • Joined on Wed, Nov 8 2017
    • Posts 1
    • Points 15
    How Fix you do not have a media composer first entitlement plase register my.avid.com/mcfirst for a free media composer first entitlement
    I get this error
    I've done all the operations, but when I open the application I get such an error
  • Wed, Nov 8 2017 2:52 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,569
    • Points 17,140
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: How Fix you do not have a media composer first entitlement plase register my.avid.com/mcfirst for a free media composer first entitlement
    Hi Qburak,
    Please try to reset the AppMan Cache files, click the drop-down arrow next to the email address, then select "Preferences" tab select "Clear Cache files" then wait for the AppMan to sync, do the same with the 'Restart AppMan Helper.
    RalphC
    This is a test. Media Composer 8.8 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Wed, Apr 11 2018 6:26 AM In reply to
    I'm also having this issue.  I have cleared the cache and logged in.  After the update a message tells me to go to the app store to purchase a subscrition.
  • Wed, Apr 11 2018 6:28 AM In reply to
    After I do this I still have the problem.  After logging back in the app manager tells me to go to the app store to purchaes a license.
  • Wed, Apr 11 2018 2:38 PM In reply to
    • RalphC
    • Posts 1,569
    • Points 17,140
      Avid Employee
    Hi markerikson,
        The message " None of your product can be license via Application Manager. Please visit the Avid Store to buy a new one" is just normal for MC|First, after the installation the program is automatically activated via the AppMan, to launch the program select the "Apps tab" then click the Open.
    RalphC
  • Thu, Apr 12 2018 6:09 AM In reply to
    In the Apps tab of the Application Manager I click "open" for Media Composer First.  I get the following.
    The window is titled "Avid Media Composer First" You do not have a Media Composer | First engitlement. Please register at my-avid.com/mcfiles for a free Media Composer | First entitlement.
  • Sun, Apr 15 2018 3:40 AM In reply to
    Any response to this?  I'm running MacOS High Sierra.
    I have uninstalled and reinstalled the apps.  But I still get the message that I'm not entitled.
  • Sun, Apr 15 2018 7:06 AM In reply to
    Same problem here..
    http://community.avid.com/forums/t/184196.aspx
    Would be grateful for a solution, Thanks!
    MacPro (Late 2013) / 3.5 GHz 6-Core Intel Xeon E5 / 32 GB 1866 MHz DDR3 ECC [view my complete system specs]
  • Sun, Apr 15 2018 3:54 PM In reply to
    In Avid Application Manager-> (purple drop down menu) Prefernces-> Clear Chache Files.
    Quit it, then restart it.
    (take a minute for the MC|F to launch properly)
  • Sun, Apr 15 2018 9:18 PM In reply to
    I ended up doing a number of things.  I cleared the cache and restarted and then I got the spinning wait sprite.  after 10min I figured something else was wrong.
    For my master account it appears that I have 2 setup due to a typo.  Chrome and Safari had different setups when looking at my account.
    My media manager must have used one login, and Safari used the other.  I canceled the autologin of Safari and then logged into the correct account.  Auto login is currently off.
    I ended up re-installing averything at that point and Composer First now loads correctly.
  • Fri, Jul 20 2018 12:38 AM In reply to
    • Muhittin
    • Joined on Fri, Jul 20 2018
    • Posts 4
    • Points 60
    Hi
    I am also having the same issues. I have tried every solution that is written here but it's no good.
    Also when I enter the Application Manager it gets stuck saying "Getting subscription data". However when I restart my computer it is logged in.
  • Fri, Jul 20 2018 12:45 AM In reply to
    • Posts 9,520
    • Points 209,350
    Hi there
    What version do you have running of MC First?  What operating system?  Also what Comuter is this on?
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Sun, Jul 22 2018 4:21 AM In reply to
    • Muhittin
    • Posts 4
    • Points 60
    Hi
    I have the v2018.7 version and the operating system is Windows. And the computer is a MSI laptop.
  • Sun, Jul 22 2018 2:51 PM In reply to
    • Posts 9,520
    • Points 209,350
    markerikson:
    Markerikson
    First you want to be using the 2018.7.1 version ( Mac ) as we discovered an issue with Mac OS 10.13.4 and higher on 2018.7. You should be able to get that via AppMan or your My Avid.
    Secondly, I see you also have access to PT First. Is this installed on the same computer?  There is a specific co-install for them so that might be it depending on what you have on the system.
    Lastly... I want you to make sure your AppMan is the latest version and if not then go here and replace it with the latest also check the troubleshoting scoop.
    http://avid.force.com/pkb/articles/en_US/FAQ/Application-Manager-stuck-at-initializing
    Report back.
  • Sun, Jul 22 2018 2:52 PM In reply to
    • Posts 9,520
    • Points 209,350
    Muhittin
    Windows what?  Exacts please?   Computer is MSI...  Exacts please as any little part of that whch doesnt meet spec could be causing this.
