Latest post Sun, Jan 21 2018 11:09 PM by Simon_h. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Nov 17 2017 1:33 PM
    • Simon_h
    • Joined on Mon, Jun 20 2011
    • Cambridge, UK
    • Posts 73
    • Points 940
    Background queue won't start
    I'm using Media Composer 8.9.3 and I'm having problems with the background services.
    Initially, it wasn't loading properly so I followed advice already posted on the forum about overcoming this:
    I've already done a clean reinstall of Avid.
    Before that I also deleted the Editor transcode folder
    And I deleted all old files from the User folder - can't recall which now - following the advice of others having the problem.
    I've reached the point where the background queue now loads correctly in a browser, but after a short while completely fails with either one of these errors on apparently random files:
    Exception: Exception: Failed to build pipes for play operation - see console for details.
    Exception: Exception: Cannot create the AMA sample mapper to play this clip - SelectFileMob() failed.
    I can post the console output but I'm unclear about which output is relevant - are the most recent entries at the top or bottom?
    Help much appreciated.
    AVID 2018.12 on HP Z820 MT XEON, 2GhZ, 32GB, Windows 7, Nvidia Quadro 2000, Crucial SSD Hard Drive with several WD Blacks for media. Sorenson 8.5 and... [view my complete system specs]
  • Sun, Nov 19 2017 9:30 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    Re: Background queue won't start
    Open the Console and clear the text, run the background task (consolidate? transcode?) till it aborts, go back to the console, the last bunch of lines should be the relevant ones. It seems to me an AMA issue rather than background services.
    peace luca
  • Sun, Nov 19 2017 1:13 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 73
    • Points 940
    Thanks Luca
    Just done another test now and here are the results:
    First I cleared the console.
    Then I did a test background render on one clip (C100 AVCHD).   The job failed with the error Exception: Exception: Failed to build pipes for play operation - see console for details.
    Then I opened the console but it's completely empty - no messages at all.
    The only thing I can guess that might have created this problem is upgrading from MC 8.9.x to 8.9.3
    Added to this, I am able to transcode the footage using manual transcoding and the same drives and files.
  • Sun, Nov 19 2017 3:37 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    What kind of task You send to the background queue when the error pops up?
    peace luca
  • Mon, Nov 20 2017 2:10 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 73
    • Points 940
    I am transcoding HD AVCHD footage from a C100 to the project settings of DNxHD 120, 25p.
  • Tue, Nov 21 2017 1:20 PM In reply to
    • steve maio
    • New Jersey
    • Posts 30
    • Points 410
    Same issue here, 8.9.3 as well, trying to run 4k footage from a C300 on an external USB 3.0 to DNxHR LB on my media drive (OSX).  The C300 footage fails to run as does some H264 cellphone footage on the same external.  Background services icon is red.  I can Stop them and Start them, but it fails to start properly.  Nothing in Console.
    Mid-2010 MacPro5,1 tower: 2x 2.66 GHz 6-Core Intel Xeon, 16GB 1333MHz DDR3 ECC, ATI Radeon HD 5770, 4x 2TB Hitachi Deskstar, Yosemite 10.10.2, Avid Media... [view my complete system specs]
  • Tue, Nov 21 2017 1:32 PM In reply to
    • Posts 10,219
    • Points 218,265
    Simon....
    Can you email me this information. I cant find your email address and would like to create a case and get support on this for you.
  • Tue, Nov 21 2017 1:33 PM In reply to
    • Posts 10,219
    • Points 218,265
    steve maio:
    Steve
    Can you also email me this info, your specs and I will get a case going.
    marianna
  • Sun, Jan 21 2018 11:09 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 73
    • Points 940
    To complete this thread, I just thought I'd share the solution to this problem, reached with the assistance of Avid Technical Support.  It was found that setting the Windows User Account Control to the lowest setting solved the problem and allowed the background queue to start again.
