Latest post Tue, May 14 2019 7:49 PM by JPBU. 12 replies.
Page 1 of 1 (13 items)
  • Sun, Nov 19 2017 6:33 PM
    • ingofoertsch
    • Bavaria, Germany
    • Posts 89
    • Points 1,135
    Canon C200 raw light workflow question
    Hi everybody, maybe anyone here is using a new Canon C200 recording to Canons new RAW light format.
    I just recorded a few scenes as a test to a CFast card, installed Canons Raw ligth AMA plugin for Avid..
    and wow! i could edit the CRL files natively.
    What i dont understand is: while editing the files and color correcting them - do i really chahnge the same values like i could with Canons external RAW light development kit, where i can change white balance and a few more values like for example editing RAW stills in Lightroom.
    Does Avid Color correction really work with the raw files? Or would it be better for me the go through the C-Raw Light development kit?
    What is the best way and how are you guys working with CRL files?
    Thank you!
    Ingo
    1. Imac 27", OSX High Sierra, MC 2018.9.0 2. Imac 27", OSX High Sierra, MC 2018.5.0 [view my complete system specs]
    My system: MC 8.5.3 / Mojo DX / MacPro 2x 2,66 Nehalem / 32 GB Ram / OSX 10.9.5 / NVIDIA GeForce GT 120
  • Thu, Nov 23 2017 1:36 PM In reply to
    • carlone
    • Los Angeles
    • Posts 149
    • Points 1,950
    Re: Canon C200 raw light workflow question
    It’s raw "light" not raw so the files aren’t like true raw files from a Red Camera. I see no difference when white balancing in canon software compared to MC. The main difference I see is the canon software lets you convert the media to formats like CLog2/Cinema and a few others. That's not an option in Camera so If you want C Log2 with CInema Gamut then you'll need to convert it with the canon software. I happen to like the Cinema Gamut look so I convert the files then link to them in Media Composer.
    MC Soft 3.1 on Mac 8 core (6 gigs of ram) MC Soft 3.0 on Macbook Pro (3 gigs of ram) Pro Tools 8 HD or LE installed on both computers [view my complete system specs]
  • Thu, Nov 23 2017 2:39 PM In reply to
    May I ask, what format are you converting the CRL files to?
  • Fri, Nov 24 2017 1:35 PM In reply to
    • carlone
    • Los Angeles
    • Posts 149
    • Points 1,950
    I’ve tried a few of the options but I really like the combination of Clog 3 and cinema Gamut. I like the color of cinema gamut.
  • Fri, Nov 24 2017 6:58 PM In reply to
    Maybe I'm mistaken. I thought with the Canon software you had to convert to totally new file format, like DPX or EXR. Are you saying you can gamma and gamut and keep the file in the CRL .CRM format?
    This what I'm going off of: https://www.provideocoalition.com/canons-cinema-raw-light-codec/
    Thanks so much!
  • Sun, Jan 14 2018 8:56 PM In reply to
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 144
    • Points 1,945
    I would love to get updates on your workflow.
    Anyone did the trip from MC to Resolve ?
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Mon, Jan 15 2018 6:45 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,805
    i've had a C200 for about three months now and my workflow is use Canon Raw Development to de-bayer into C-Log 2 or 3 (depending on the content) and create new 4K Pro-Res 4444 master files and toss the original CRM's once the project is mastered. I find the 4444 files contain everything from the originals, grade beautifully in Resolve and are generally much easier to deal with.
    2017 27" iMac i7 4.2, 2TB PCI memory, 64GB RAM, OS 10.13.6, MC 2018.10 [view my complete system specs]
  • Thu, Jan 25 2018 8:39 PM In reply to
    • carlone
    • Los Angeles
    • Posts 149
    • Points 1,950
    I do the same. Pro Res 4444 bakes in the "log" look and the files are easier to work with.
  • Thu, Jan 25 2018 9:01 PM In reply to
    • JPBU
    • Canada
    • Posts 144
    • Points 1,945
    Great thank you. I'il give it a try next week.
  • Thu, Jan 25 2018 9:14 PM In reply to
    • JPBU
    • Canada
    • Posts 144
    • Points 1,945
    Are you talking ProRes 4444 XQ or ProRes 4444  ? (for 4k) Any ideas how bit these files are compared to original Canon raw light ?
    If using Media Composer, don't you think it would make more sense to simply link to the RAW, transcode to whatever offline editing format you want and link it back to original prior to exporting it to Pro Res 4444 for grading in Resolve ?
  • Fri, Jan 26 2018 10:32 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,805
    Yes, I am with you and normally that's what I'd do but Canon Raw Light is a little different.
    The only 4K ProRes option in the Mac version of Canon Raw Development is 4444. The others are DPX RGB 16 & 10 bit and open EXR (Aces 1.0). In the Windoze version it's the same except no ProRes of course. It will do all the other file types in the ProRes family but only in 1080.
    4K ProRes 4444 files are slightly bigger than the original Raw lite files but not by much.
    At the moment, I feel like using the Canon software is the only way I know to be sure of the correct colour space conversion when de-bayering from Raw light. I don't actually know what Resolve is doing because the Raw controls are greyed out and unavailable - which is annoying. The  generated ProRes files are truly awesome. All the detail, colour and dynamic range is retained. It feels every bit the same as the Raw - effectively it is since the Raw controls are totally unavailable. The ProRes files are MUCH more manageable and less demanding for your computer to play and for final grading in Resolve.
    My initial testing showed that transcoding in Avid using the Canon plugin was painfully slow.
    I shoot quite a bit of 4K 50p that needs to be conformed to a 25 base for slo-motion playback. Resolve does that beautifully and I like to watch my rushes and do a quick one-light grade as I go rather than slap a Rec.709 LUT onto everything. Resolve is quite fast at rendering out to ProRes proxy or DNxHD 36 for editing and it also makes the matchback for final grade very simple. I keep the camera originals until the job is finished and then delete them.
  • Sat, Jan 27 2018 8:30 AM In reply to
    If only the C200 could record sync'd timecode, it would be pretty much perfect.
  • Tue, May 14 2019 7:49 PM In reply to
    • JPBU
    • Canada
    • Posts 144
    • Points 1,945
    I was wondering if any of you had a 2019 update on your workflow in MC using C200 Raw Light ?
