Latest post Wed, Dec 20 2017 9:42 PM by ramz434. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Dec 20 2017 5:01 PM
    • ramz434
    • Long Island
    • Posts 192
    • Points 2,395
    Audio Track numbers on import
    I've got some scratch VO files that have a time stamp in the name - "2017-Dec-20_08-08-12.wav".
    Whenever Avid import or AMA's the file - it assigns the track number to the last digits in the file name. This particular file gets assigned Track 12 - I've also got Track 20 and 33. Modify options wont let me change the track number.
    I know I can rename the file and the track number isnt a real big deal for me in this case - just seems like weird behavior.
    I didnt see anything in the Audio import settings - any one see this before?
    - HP Z400/24gb ram/Windows 10/MC8.9.4/256gb Samsung SSD/ NVidia GTX 1080/HP ZR22 Monitors/ - Macbook Pro/16gb ram/OS 10.13/MC8.9.4/NVIDIA GeForce... [view my complete system specs]
  • Wed, Dec 20 2017 7:00 PM In reply to
    • scocklin
    • Maryland
    • Posts 652
    • Points 7,840
    Re: Audio Track numbers on import
    You need to first unlink the linked AMA media before modifying the tracks.
    With linked AMA clips only (this will not work with transcoded clips)  right click on clip(s), modify, unlink media.  This will unlink all the select clips, right click on all unlinked media clips and select modify clip, from drop down menu inside modify clip menu select set tracks, select the tracks you want, click OK.  Relink all of the unlinked media you created and only the selected tracks will be present.
    HP Z800 2x 3.46GHz Hex Core X5690, 48GB Ram, Windows 10, Samsung SSD 850 Pro 512GB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K,... [view my complete system specs]
  • Wed, Dec 20 2017 7:45 PM In reply to
    That's not what the TS means. TS simply mentions that a monophonic WAVE file with a file name ending at 'xyz-12.wav' will end up as a clip with just A12.
  • Wed, Dec 20 2017 8:37 PM In reply to
    • ramz434
    • Long Island
    • Posts 192
    • Points 2,395
    After a quick test, its seems that any file (audio at least) with a hyphen followed by a number (-12, -20, -33) right before the file type (.wav) gets imported on a track that correlates to that number.
  • Wed, Dec 20 2017 9:27 PM In reply to
    Yes, I think it's the way that multichannel sets of monophonic WAVE files identify track numbers in BWF field recorders.
    Have to say that I'm not a fan of using hyphens etc. in file names at all. Not so relevant to you, obviously.
  • Wed, Dec 20 2017 9:42 PM In reply to
    • ramz434
    • Long Island
    • Posts 192
    • Points 2,395
    I'm an underscore person myself in file names, but our VO just ripped off a quick scratch record into her laptop and thats how the file got named.
    Learned something new today.
